I found it on the web, I hope it's of your use
(defun c:pc ( / acdoc acspc acsel pl bl ) (vl-load-com)
(setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
(if (ssget '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1)))
(vlax-for obj (setq acsel (vla-get-ActiveSelectionSet acdoc))
(vlax-invoke acspc 'addpoint
(trans
(setq pl nil bl nil)
(foreach a (reverse (entget (vlax-vla-object->ename obj)))
(cond ((= (car a) 10) (setq pl (cons (cdr a) pl)))
((= (car a) 42) (setq bl (cons (cdr a) bl)))
); _ cond
); _ foreach
;;;(eea-centroid-solid-lw pl bl)
[color="red"] (reverse(cons (vla-get-elevation obj)(reverse (eea-centroid-solid-lw pl bl))));;;VVA MOD 2015-03-29[/color]
1 0)
(vla-delete acsel)
(defun eea-centroid-solid-lw (pl bl / A1)
by ElpanovEvgeniy
Library function,
Centroids (center of masses) of region, inside [polilinii], which has arched segments.
pl - list of the apexes of [polilinii] (code 10)
bl - list of tangents fourth of angle of the arched segments of [polilinii] (code 42)
Date of the creation 2000 - 2005
Last editorial staff 08.06.2009
URL
http://elpanov.com/index.php?id=46*********************************************************************
Library of function.
Centroid (the of center of of weights) of region, inside of a of polyline, having of arc of segments
pl - list of point
bl - list of bulge
Date of of creation 2000 - 2005 years.
Last of edit 08.06.2009
(setq e (car (entsel "\n Select LWPOLYLINE "))
pl nil
bl nil
) ;_ setq
(foreach a (reverse (entget e))
) ;_ cond
) ;_ foreach
(defun c:test (/ e bl pl)
(setq e (car (entsel "\n Select LWPOLYLINE ")))
) ;_ cond
) ;_ foreach
(entmakex (list '(0 . "point")
'(62 . 1)
(cons 10 (eea-centroid-solid-lw pl bl))
(assoc 210 (entget e))
) ;_ list
) ;_ entmakex
) ;_ defun
(setq a1 0)
(mapcar
(function /)
(apply
(function mapcar)
(cons
(function +)
(mapcar
(function
(lambda (p1 p2 b / A BB C I S)
(setq i (/ (- (* (car p1) (cadr p2)) (* (car p2) (cadr p1))) 2)
a1 (+ i a1)
i (/ i 3)
) ;_ setq
(if (zerop b)
(mapcar (function (lambda (a b) (* (+ a b) i))) p1 p2)
(setq c (distance p1 p2)
bb (* b b)
a (/ (* c c (- (* (atan b) (1+ bb) (1+ bb)) (* b (- 1 bb)))) (* 8 bb))
a1 (+ a a1)
s (/ (- (* b c c) (* 3 a (- 1 bb))) (* 12 a b))
) ;_ setq
(mapcar (function (lambda (a b c d) (+ (* (+ a b) i) (* d (+ (/ (+ a b) 2) c)))))
p1
p2
(list (* (- (cadr p2) (cadr p1)) s) (* (- (car p2) (car p1)) -1 s))
(list a a)
) ;_ mapcar
) ;_ progn
) ;_ if
) ;_ lambda
) ;_ function
(cons (last pl) pl)
pl
(cons (last bl) bl)
) ;_ mapcar
) ;_ cons
) ;_ apply
(list a1 a1)
) ;_ mapcar
) ;_ defun
