Author Topic: AECC_Points  (Read 11991 times)
rugaroo
  • The Other CAD Guy
AECC_Points
« Reply #15 on: November 20, 2003, 03:35:58 PM »
Mark-
i was unable to get yours to work with insertion of blks. this is what i got, but no go...any ideas'????
(DEFUN c:ptt ()
  (SETQ lts   (GETVAR "LTSCALE")
ent   (ENTGET "\nSelect ACAD point block: ")
inspt (CDR (ASSOC 10 (ENTGET ent)))
eleva (CAR (REVERSE (ASSOC 11 (ENTGET ent))))
descr (CAR (REVERSE (ASSOC 11 (ENTGET ent))))
  (COMMAND "INSERT" "GTC"     inspt
  lts ""       ""     eleva
  descr
  (PRINC)
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
AECC_Points
« Reply #16 on: November 20, 2003, 05:06:40 PM »
Rug, what I gave you returns a list containing all the necessary point data you need to insert your blocks.
*sample* (1 (480.127 760.395 0.0) 12.0 "top of bank")
1=point number
(480.127 760.395 0.0) = insertion point of block
12.o = elevation
"top of bank" = description
AECC_Points
« Reply #17 on: November 20, 2003, 05:22:30 PM »
Like this Rug.
;; it breaks down like this
 ; return list of data from user selection
 (setq p-data (pt_data))
 ; list of point data
 (setq pt1 (car p-data))
  return = (24 (1119.64 1066.54 0.0) 12.0 "tmp")
 ; insetion point of block
 (setq insert-pt (cadr pt1))
  return = (1119.64 1066.54 0.0)
 ; elevation
 (caddr pt1)
  return = 12.0
 ; description
  (last pt1)
  return = "tmp"
So your program will look like this
(defun c:ptt (/ lts p-data)
      (prompt "\nSelect AECC Points")
      (setq lts (getvar 'ltscale))
      (if p-data
        (foreach item p-data
          (command "_insert" "GTC" (cadr item) lts "" "" (caddr item) (last item))
AECC_Points
« Reply #18 on: November 20, 2003, 06:07:14 PM »
Here, try this one.
;;; example (setq p-data (pt_data))
;;; all data based on AECC points in the dwg NOT the database
(defun pt_data (/ PointData ss output)
  (defun PointData (ss / ent)
      ((setq ent (ssname ss 0))
       (setq output ; <-- global variable to this function
             (cons
               (list
                 (cdr (assoc 90 (entget ent)))           ; point number
                 (cdr (assoc 10 (entget ent)))           ; insertion point
                 (car (reverse (assoc 11 (entget ent)))) ; elev
                 (cdr (assoc 303 (entget ent)))          ; description
               output
               ) ; cons
             ) ; setq
       (PointData (ssdel ent ss))
      (T nil)
      ) ; cond
    ) ; defun PointData
  ;; (1 (480.127 760.395 0.0) 12.0 "top of bank") *sample*
  (if (setq ss (ssget '((0 . "AECC_POINT"))))
    (PointData ss)
    ) ; if
  output
  ) ; defun
;;   main function
  (setq p-data (pt_data));; call pt_data
  ;; block scale
  (if p-data
    (foreach
      item
      p-data
      (setq el (rtos (caddr item) 2 2)); round off the elev.
      (command "_insert" "GTC" (cadr item) lts "" "" el (last item))
  (princ (strcat "\n"(itoa (length p-data))" Blocks Inserted"))
rugaroo
  • The Other CAD Guy
AECC_Points
« Reply #19 on: November 21, 2003, 03:41:57 PM »
Mark - sorry it took me a bit to get back, but it works great....now I was geting a little froggish again, and was thinking of adding a datum removal. here is what I did...any comments/ideas?
;; datum removal
(defun datrem ()
  (setq datum0 (el)
datum1 (/ el 1000)
datum2 (rtos (datum1) 2 0)
datum3 (* datum2 1000)
datum (datum3)
el (- datum0 datum3)
;;   main function
  (setq cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  ;; block scale
  (if p-data
    (foreach
      item
      p-data
      (datrem)
      (command "_insert" "GTC" (cadr item) lts "" "" datum (last item))
  (setvar "cmdecho" cmd)
Rug
rugaroo
  • The Other CAD Guy
AECC_Points
« Reply #20 on: November 21, 2003, 04:15:37 PM »
I have also noticed that when I try to use this on another persons machine the dialog for the attrib edit dialog comes up. I tried setting cmdecho and initdia, but still no go...any idea?
