Author Topic: Purge & Audit  (Read 22130 times)
daron
Purge & Audit
« Reply #15 on: October 03, 2003, 03:04:29 PM »
Because they both mean the same thing. T
rugaroo
  • The Other CAD Guy
Purge & Audit
« Reply #16 on: October 03, 2003, 03:22:52 PM »
I understand that they are both the same, but when using VL commands, why would you have limited abilities as to which arguements you can use. In other words, if you wanted to use a T staement with lisp, you just are able to use T, and vice versa with the :VLAXtrue. You see what I am saying...this was just a minor observation.
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
