Author Topic: error message when running lisp  (Read 8310 times)
ELOQUINTET
« Reply #15 on: November 05, 2004, 02:29:55 PM »
keith i did a search and downloaded regsrv32. idropped my .dll on it and i get this message what do you think i should do
http://www.theswamp.org/screens/dan/regsrv32%20error%20message.doc
« Reply #16 on: November 05, 2004, 02:43:14 PM »
Dan, post the code for the lisp routines and we should be able to give you a better idea.
ELOQUINTET
« Reply #17 on: November 05, 2004, 02:55:54 PM »
the only ones i've noticed the problem occuring on so far is these three but i haven't tested them all. I did test most of the ones i have which gather information about the drawing like layer or layout based on these two and all the others seem to be ok. i also modified plottabs for creating plt files recently so i have suspiscions it may be that one. here they are:
(defun c:SL
(/ layer_string ent enlay entlst ename olderr selset enum objlen dent layent layset lay pt1 pt2 ss ss1 ss2 en osm)
(if (null myerr)(load "myerr"))
(setq olderr *error* *error* myerr)
(setq osm (getvar "osmode"))
(if (null setvars)(load "setvars"))
(setq syslst
(setvars '(("cmdecho" . 0) ("osmode" . 0) ("trimmode" . 1)) )
(while (setq ent (entsel "\nSelect entity on layer..."))
(setq layer_string
(if layer_string
(strcat layer_string ","
(vla-get-layer (vlax-ename->vla-object (car ent)))
(princ "\nSelect objects to stretch by crossing-window or crossing-polygon...")
(command "._stretch" (ssget (list (cons 8 layer_string))) "")
(setvars syslst)
(setq *error* olderr)
(defun myerr (msg)
(if (or (= msg "quit / exit abort")
(= msg "Function cancelled"))
(if (and ctl undo_err) ; if undo_start used and returned value saved
(undo_err ctl)) ; in ctl then undo everything done so far.
(princ msg))
(if (and setvars syslst) ; if usual system var handler and variable exist
(setvars syslst)) ; then restore system vars
(setq *error* OLDERR ctl nil)
(defun setvars (syslst / oldlst)
(foreach dp syslst
(setq oldlst (cons
(cons (car dp) (getvar (car dp)))
oldlst)))
(foreach dp syslst
(setvar (car dp) (cdr dp))
oldlst
;;;            PlotTabs.lsp
;;;      Created by C. Alan Butler
;;;        Version 1  12/04/2003
;;;        Version 1.01 12/17/2003 Bug repairs
;;;  Requires PlotTabs.dcl file to run
;;;  Routine to plot paperspace tabs
;;;  Pick Page Set Up to use
;;;  Sort by Alpha, Numeric, or Tab order
;;;  Reverse sort order
;;;  Ignore Tabs with flag character
;;;  Enter quantity of copies
;;;  Option to collate
;;;  Enter PLotTabs to run from the command line
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
(defun c:Plottabs (/    plo_list      plo_layout
         config-list    Plot-config   Plot-order
         Plot-qty    order-list    order#
         config#    RevOrder
  ;; Function: init_vars
  ;; Purpose : Sets up variables prior to invoking dialogue box.
  (defun init_vars ()
    (if   (not Plot-Config)
      (setq Plot-Config "Current")
    (if   (not Plot-QTY)
      (setq Plot-QTY 1)
    (if   (not Plot-order)
      (setq Plot-order "Tab")
    (setq config-list (Plot_config_list) ;get list of page setups
     RevOrder    nil ; Reverse the order
     Quantity    Plot-QTY ; number of sets
     SaveLayout  T
     CollateSets T
     ExcludeTab  T ; Flag to exclude tabs
     ExcludeChr  "~" ; Character marker for exclude tabs
     PlotToFile  F
    ) ;_ end of setq
    (if   (and Plot-config (member Plot-config PlotConfigs))
      (setq config#
        (-   (length config-list)
      (length (member Plot-Config config-list))
        ) ;_ end of -
      ) ;_ end of setq
      (setq config# 0)
    ) ;_ end of if
  ) ; end defun init_vars
  ;; Function: init_tiles
  ;; Purpose : Sets up dialogue box tiles prior to invoking dialogue box.
  (defun init_tiles ()
    (setq yes "1")
    (action_tile "accept" "(call_ok)")
    (start_list "PlotConfigs")
    (foreach one config-list
      (add_list one)
    ) ;_ end of foreach
    (end_list)
    (set_tile "PlotConfigs" (itoa config#))
    (action_tile "SaveLayout" "(setq SaveLayout (= $value \"1\"))")
    (action_tile "rb1" "(setq Plot-order \"Alpha\")")
    (action_tile "rb2" "(setq Plot-order \"Numeric\")")
    (action_tile "rb3" "(setq Plot-order \"Tab\")")
    (action_tile "reverse" "(setq RevOrder (= $value \"1\"))")
    (action_tile "quantity" "(QuanCtrl)")
    (action_tile "CollateSets" "(setq CollateSets (= $value \"1\"))")
    (action_tile "ExcludeTab"  "(ExTab)")
    (set_tile "ExcludeChr" ExcludeChr)
    (action_tile "ExcludeChr" "(setq ExcludeChr $value)")
    (action_tile "PlotToFile" "(setq PlotToFile (= $value \"0\"))")
  ) ; End init_tiles
  (defun ExTab() ; enable/disable flag character input
    (setq ExcludeTab (if(= (get_tile "ExcludeTab")"0")T nil)); get current value
    (if ExcludeTab
      (mode_tile "ExcludeChr" 1);enabled
      (mode_tile "ExcludeChr" 0);disabled
  ) ; end defun ExTab
  (defun QuanCtrl()
    (if   (> (setq quantity (atoi (get_tile "quantity"))) 1)
      (mode_tile "CollateSets" 0);enabled
      (mode_tile "CollateSets" 1);disabled
  ;; Function: call_ok
  ;; Purpose : Callback function for OK button. Ensures a quantity greater than
  ;;           0 and a device other than "None".
  (defun call_ok ()
    (if   (> (setq quantity (atoi (get_tile "quantity"))) 0)
   (setq
     config#     (atoi (get_tile "PlotConfigs"))
     Plot-cfg    (nth config# config-list)
     Plot-QTY    quantity
   ) ;_ end of setq
   (done_dialog 1)
      ) ;_ end of progn
      (set_tile "error" "Quantity must be 1 or more")
    ) ;_ end of if
  ) ; End call_ok
  ;; Function: Plot_Config_list
  ;; Purpose : Returns list of strings of all user page set ups.
  ;; Local   : curdwg:   current drawing object
  ;;           pslayout: paper space layout object
  (defun Plot_config_list (/ curdwg pslayout names x)
    (setq
      curdwg   (vla-get-ActiveDocument (vlax-get-Acad-Object))
      DwgName  (vl-string-right-trim ".dwg" (vla-get-fullname curdwg))
      pslayout (vla-get-Layout (vla-get-PaperSpace curdwg))
    ) ;_ end of setq
     ; Call RefreshPlotDeviceInfo before GetPlotDeviceNames
    (vla-RefreshPlotDeviceInfo pslayout)
    (cons '"Current" ; add Current as a choice
     (reverse
       (vlax-for x   (vla-get-Plotconfigurations curdwg)
         (setq names (cons (vla-get-name x) names))
       ) ;_ end of vlax-for
     ) ;_ end of reverse
    ) ;_ end of cons
  ) ; End Plot_config_list
  ;; Function: plot_tab
  ;; Purpose : plot one lauout tab
  ;; Params  : tab:    name of the layout tab to plot
  ;; Local   :
  ;; Returns : nil
  (defun Plot_Tab (TabToPLot)
      ((= TabToPLot "Model")
       nil ; skip Model Space
      ) ; end cond 1
      ((and ExcludeTab (vl-string-search ExcludeChr TabToPLot))
       nil ; skip if ~ in tab name
      ) ; end cond 2
      (T
    (PlotToFile
           (command "-Plot"
      "n"
      TabToPLot ; tab name
      (if (= Plot-cfg "Current") "" Plot-cfg); page setup name
      "" ; output device name <current>
      "N" ; plot to file
      (strcat Dwgname "-" TabToPLot) ;; not used if no plot to file
      (if SaveLayout "Y" "N") ; save page setup to layout
      "Y" ; yes do the plot
           ) ;_ end of command
         ) ; end cond 1
    (T
           (command "-Plot"
      "n"
      "N" ; plot to file
      ; File Name not used if no plot to file
           ) ;_ end of command
     ) ;end cond T
       ) ; end cond
      ) ; end cond 3
    ) ; end cond
  ) ; end defun
  ;; Function: num_sort
  ;; Purpose : sort list of strings by the first numbers found in them
  ;; Params  : lst:    list of strings to sort
  ;; Local   :
  ;; Returns : sorted list
  (defun Num_Sort
    (lst / begin elist end estr n ndx newstring rval strlist)
    (setq numlst (list)) ; empty list
    (foreach one lst
      (setq ndx       1
       rval    nil
       strlist (list)
      ) ;_ end of setq
      (if (/= one nil)
   (repeat   (strlen one)
     (setq strlist (append strlist (list (substr one ndx 1))))
     (setq ndx (1+ ndx))
   ) ;_ end of repeat
      ) ;_ end of if
      (setq begin nil
       end   nil
       ndx   1
      ) ;_ end of setq
      (foreach n strlist
     ((and (not begin) (not end))
      (if (/= nil (distof n))
        (setq begin ndx
         rval   n
        ) ;_ end of setq
      ) ;_ end of if
     ((and begin (not end))
      (if (= nil (distof n))
        (setq end ndx)
        (setq rval (strcat rval n))
      ) ;_ end of if
   ) ;_ end of cond
   (setq ndx (1+ ndx))
      ) ;_ end of foreach
      (if (not rval)
   (setq rval "0")
      ) ;_ end of if
      (setq numlst (cons (cons rval one) numlst))
    ) ; end foreach
    (setq lst (vl-sort numlst '(lambda (E1 E2) (< (car E1) (car E2)))))
    (setq lst (mapcar 'cdr lst)) ;remove the numbers
    lst
  ) ; end defun
;;; Start C:PlotTabs -----------------------------------------------------------
    ((not (findfile (setq dclfile "PlotTabs.dcl")))
     (alert "Cannot find PlotTabs.dcl")
    ((< (setq dcl# (load_dialog dclfile)) 0) ; Error
     (prompt (strcat "\nCannot load " dclfile "."))
    ((not (new_dialog "PlotTabs" dcl#)) ; Error
     (prompt (strcat "\nProblem with " dclfile "."))
    (T ; No DCL problems: fire it up
     (init_vars)
     (init_tiles)
     (setq action (start_dialog))
     (unload_dialog dcl#)
     (if (= action 1) ; Ok to Plot
    (setq plo_layouts
      (vla-get-layouts
      ) ;_ end of vla-get-layouts
    ) ;_ end of setq
    (vlax-for plo_layout plo_layouts ; get list of layout tabs
      (if (= Plot-Order "Tab") ; create with TabOrder numbers
        (setq plo_list (cons (cons   (vla-get-TabOrder plo_layout)
               (vla-get-name plo_layout)
              ) ;_ end of cons
              plo_list
             ) ;_ end of cons
        ) ;_ end of setq
        (setq plo_list (cons (vla-get-name plo_layout) plo_list))
      ) ;_ end of if
      ((= Plot-Order "Alpha")
       (setq plo_list (vl-sort plo_list '<))
      ) ; end cond 1
      ((= Plot-Order "Numeric")
       (setq plo_list (Num_Sort plo_list))
      ) ; end cond 2
      ((= Plot-Order "Tab")
       (setq plo_list
         (vl-sort plo_list
         ) ;_ end of vl-sort
       ) ;_ end of setq
       (setq plo_list (mapcar 'cdr plo_list)) ;remove the taborder numbers
      ) ; end cond 3
    ) ; end cond
    (if Plot-REV (Reverse plo_list)) ;_ end of if
    (if CollateSets
      (repeat Plot-QTY
        (foreach tab plo_list ; plot one complete set at a time
          (Plot_Tab tab)
        ) ;_ end of foreach
      ) ;_ end of repeat
        (repeat Plot-QTY ; plot the quantity of each sheet
          (Plot_Tab tab)
        ) ;_ end of repeat
      ) ;_ end of foreach
    ) ; endif
    (prompt "\nPlot Sets Complete")
       ) ; end progn
       ;; ELSE
       (alert "   Plot aborted.")
     ) ;_ end of if
    ) ; end cond T
  ) ; end cond
) ; End defun C:PlotTabs
(prompt "Plot Tabs is loaded, Enter PLotTabs to run.")
;;; End C:PlotTabs -----------------------------------------------------------
;;;            Plt.lsp
;;;  Requires plt.dcl file to run
;;;  Enter plt to run from the command line
(defun c:plt (/    plo_list      plo_layout
         config#    RevOrder
  (defun init_vars ()
    (if   (not Plot-QTY)
      (setq Plot-QTY 1)
     SaveLayout  F
     CollateSets T
     PlotToFile  T
    ) ;_ end of setq
      (setq config#
        ) ;_ end of -
      ) ;_ end of setq
      (setq config# 0)
    ) ;_ end of if
    (setq yes "1")
      (add_list one)
    ) ;_ end of foreach
    (end_list)
    (action_tile "SaveLayout" "(setq SaveLayout (= $value \"0\"))")
    (action_tile "PlotToFile" "(setq PlotToFile (= $value \"1\"))")
  ) ; End init_tiles
    (if ExcludeTab
  ) ; end defun ExTab
  (defun QuanCtrl()
  (defun call_ok ()
   (setq
     Plot-QTY    quantity
   ) ;_ end of setq
   (done_dialog 1)
      ) ;_ end of progn
    ) ;_ end of if
  ) ; End call_ok
    (setq
    ) ;_ end of setq
     (reverse
     ) ;_ end of reverse
    ) ;_ end of cons
  ;; Purpose : plot one layout tab
  ;; Local   :
  ;; Returns : nil
      ) ; end cond 1
      ) ; end cond 2
      (T
    (PlotToFile
           (command "-Plot"
      "n"
      "Y" ; plot to file
      "N" ; yes do the plot
           ) ;_ end of command
         ) ; end cond 1
    (T
           (command "-Plot"
      "n"
      "Y" ; plot to file
           ) ;_ end of command
     ) ;end cond T
       ) ; end cond
      ) ; end cond 3
    ) ; end cond
  ) ; end defun
  ;; Local   :
  (defun Num_Sort
    (foreach one lst
      (setq ndx       1
       rval    nil
       strlist (list)
      ) ;_ end of setq
      (if (/= one nil)
     (setq ndx (1+ ndx))
   ) ;_ end of repeat
      ) ;_ end of if
      (setq begin nil
       end   nil
       ndx   1
      ) ;_ end of setq
      (foreach n strlist
        (setq begin ndx
         rval   n
        ) ;_ end of setq
      ) ;_ end of if
        (setq end ndx)
      ) ;_ end of if
   ) ;_ end of cond
   (setq ndx (1+ ndx))
      ) ;_ end of foreach
      (if (not rval)
   (setq rval "0")
      ) ;_ end of if
    ) ; end foreach
    lst
  ) ; end defun
;;; Start C:plt -----------------------------------------------------------
    ((not (findfile (setq dclfile "plt.dcl")))
     (alert "Cannot find Plt.dcl")
    ((not (new_dialog "plt" dcl#)) ; Error
     (init_vars)
     (init_tiles)
    (setq plo_layouts
      (vla-get-layouts
    ) ;_ end of setq
              ) ;_ end of cons
              plo_list
             ) ;_ end of cons
        ) ;_ end of setq
      ) ;_ end of if
      ) ; end cond 1
      ) ; end cond 2
       (setq plo_list
         (vl-sort plo_list
         ) ;_ end of vl-sort
       ) ;_ end of setq
      ) ; end cond 3
    ) ; end cond
    (if CollateSets
      (repeat Plot-QTY
          (Plot_Tab tab)
        ) ;_ end of foreach
      ) ;_ end of repeat
          (Plot_Tab tab)
        ) ;_ end of repeat
      ) ;_ end of foreach
    ) ; endif
       ) ; end progn
       ;; ELSE
     ) ;_ end of if
    ) ; end cond T
  ) ; end cond
) ; End defun C:plt
(prompt "Plt is loaded, Enter PLT to run.")
;;; End C:Plt -----------------------------------------------------------
« Reply #18 on: November 05, 2004, 02:59:31 PM »
The dll you dropped on regsrv32 was only your menu dll...
The code will offer the best clue as to the problem.
ELOQUINTET
« Reply #19 on: November 05, 2004, 03:00:57 PM »
i use both of these alot so i'm having major withdrawals  :lol:
ELOQUINTET
« Reply #20 on: November 09, 2004, 03:57:46 PM »
sigh still can't get the error to stop. i downloaded the new plottabs routine and still the same error. i've also found another routine that doesn't work. it's marks routine i believe which changes all objects color to bylayer. i really wish i knew what happened this sux.
« Reply #21 on: November 09, 2004, 08:02:42 PM »
Dan, After searching other places on this subject, it appears the only solution I could find is to do a Repair Install......something got munged in your registry I suspect......
ELOQUINTET
« Reply #22 on: November 10, 2004, 08:11:54 AM »
jeff how would that affect my autocad setup? would i have to reconfigure everything?
daron
« Reply #23 on: November 10, 2004, 08:19:03 AM »
No, go to add/remove programs, find your acad setup and there should be a repair button. Hit that, put your acad install cd in and it will repair your install without messing with your user setup. Don't know what OS you have, so the above might not be quite right, but I think in Windows 2000, you hit remove and it will ask if you want to repair or remove the program. Can't remember exactly.
ELOQUINTET
« Reply #24 on: November 10, 2004, 08:58:21 AM »
ok doing a repair now will let you know the outcome thanks for the advice all
ELOQUINTET
« Reply #25 on: November 10, 2004, 10:26:11 AM »
ok i went to repair it and it proceeded to reinstall it. it's not that big of a deal to reconfigure everything. the only thing is now it is asking me to autorize it eveytime i open. the good news is so far as i can tell this seems to have fixed the problem so i can deal with setting up my stuff again. thanks guys
« Reply #26 on: November 10, 2004, 04:07:08 PM »
Quote from: eloquintet
the only thing is now it is asking me to autorize it eveytime i open. ..... thanks guys
You should write down the authorization code somewhere so it can be re-entered in a case like this.....The newer versions this doesn't work for, but I'm pretty sure the ADT3.3 does.
You're welcome, I'm glad it worked for ya.
ELOQUINTET
« Reply #27 on: November 11, 2004, 07:58:13 AM »
yeah we actually have a file with the info i just didn't know where it was now i'm cool
daron
« Reply #28 on: November 11, 2004, 08:10:34 AM »
Sorry you did reinstall. Repair, as I remember it, isn't the same thing. Anyway, I guess you fixed it, so get back to work now.
