Author Topic: Error on Import of Shapefile  (Read 1478 times)
dfarris75
« on: August 21, 2009, 10:42:25 AM »
I'm trying to import a shapefile and C3D crashes with a fatal error. Here are 3 from the error log:
FATAL ERROR:  Unhandled Access Violation Reading 0x0000 Exception at 1dac10cch
FATAL ERROR:  Unhandled Access Violation Reading 0x0004 Exception at 19965609h
FATAL ERROR:  Unhandled Access Violation Reading 0x0000 Exception at 1c8310cch
If I try to connect via data connect I get this message:
There was a problem accessing the connection's schema information.
If I try to connect via data connect, then OK out of said error message, then go back to Map > Tools > Import it appears to begin importing the data, then crashes after some time.
Corrupted data files? What?
Re: Error on Import of Shapefile
« Reply #1 on: August 21, 2009, 10:45:15 AM »
we (you) will need to find out where that SHP file originated, AND or ensure that you have the rest of the databases that normally accompany SHP files.
and or post a copy of the SHP file so that we me test the file and possible solutions to the error
dfarris75
« Reply #2 on: August 21, 2009, 12:37:08 PM »
I believe I figured it out. I went back to the ftp I downloaded it from and compared file sizes. Apparently my ftp download got interrupted about midway through the download. I'm finishing it and will then try to reimport.
I actually told it to save the last time it crashed and when I went back to recover the file only 1/2 the data was there so I had a hunch something went awry with the download.
Thx
