Author Topic: Join Lines to Polylines  (Read 14326 times)
Crank
Re: Join Lines to Polylines
« Reply #15 on: August 24, 2009, 02:44:39 PM »
You can add this to your list:
:N Call ssnamex for additional information on container blocks and transformation matrices for any entities selected during the ssget operation. This additional information is available only for entities selected through graphical selection methods such as Window, Crossing, and point picks. Unlike the other object selection methods, :N may return multiple entities with the same entity name in the selection set. For example, if the user selects a subentity of a complex entity such as a BlockReference, PolygonMesh, or old style polyline, ssget looks at the subentity that is selected when determining if it has already been selected. However, ssget actually adds the main entity (BlockReference, PolygonMesh, and so on) to the selection set. The result could be multiple entries with the same entity name in the selection set (each will have different subentity information for ssnamex to report).
:R Allows entities in a long transaction to be selected.
:U Enables subentity selection. Cannot be combined with the duplicate (":D") or nested (":N") selection modes. In this mode, top-level entities are selected by default, but the user can attempt to select subentities by pressing the CTRL key while making the selection. This option is supported only with interactive selections, such as window, crossing, and polygon. It is not supported for all, filtered, or group selections.
:V Forces subentity selection. Treats all interactive, graphic selections performed by the user as subentity selections. The returned selection set contains subentities only. This option cannot be combined with the duplicate (":D") or nested (":N") selection modes. This option is supported only with interactive selections, such as window and crossing. It is not supported for all, filtered, or group selections.
« Reply #16 on: August 24, 2009, 06:49:38 PM »
Thanks Crank - never heard of half of those!   :lol:
alanjt
  • Standby for witty remark...
« Reply #17 on: August 24, 2009, 07:09:45 PM »
nice crank, i added those to my ssget options txt file.
we're still missing "_F".
Dropbox
« Reply #18 on: August 24, 2009, 09:41:55 PM »
Here is my text file, well part of it. :evil:
SSGET
the underscore (_) is needed with W, F, WP, :S but not with X, A, C, CP, I, L, P, :E ...
(ssget '(2 2))
Create a selection set of the object passing through (2,2):
+.  The undocumented “+.” mode forces (ssget) to remain in “point” mode, similar to
    setting PickAuto to 0.... the "+." puts (ssget) into "point" mode. It helps the ":S"
    single-mode act just like (entsel) by avoiding implied selection windows.
A  All like "X" but filters frozen out
   Selects all objects on thawed layers.
B  Box
   Selects all objects inside or crossing a rectangle specified by two points. If
   the rectangle's points are specified from right to left, Box is equivalent to
   Crossing. Otherwise, Box is equivalent to Window.
C  Crossing  Simular to Window selection
   Selects objects within and crossing an area defined by two points. A crossing
   selection is displayed as dashed or otherwise highlighted to differentiate it
   from window selection. Specifying the corners from right to left creates a
   crossing selection. *** (Specifying the corners from left to right creates a window
   selection.)  (ssget "_C" '(0 0) '(1 1))
   Caution: the area must be on the screen for this to work properly - CAB
CP Crossing Polygon
   Selects objects within and crossing a polygon defined by specifying points. The
   polygon can be any shape but cannot cross or touch itself. AutoCAD draws the
   last segment of the polygon so that it is closed at all times. CPolygon is not
   affected by the PICKADD system variable.
   (ssget "_CP" '((1 1)(3 1)(5 2)(2 4)))
   Example with filters (ssget "_CP" '(Point list) '(Filter List))
   (setq ss (ssget "_CP" '((0 0)(10 0)(10 10)(0 10)) '((0 . "INSERT") (66 . 1))  ))
   (vl-cmdf "._zoom" "_E") ; Extents
:D Duplicates OK, else duplicates are ignored
:E Everything in aperture
   Everything within the cursor's object selection pickbox.
F Fence
  Selects all objects crossing a selection fence. The Fence method is similar to
  CPolygon except that AutoCAD does not close the fence, and a fence can cross
  itself. Fence is not affected by the PICKADD system variable.
G Groups
  Selects all objects within a specified group.
I Implied
  Implied selection (objects selected while PICKFIRST is in effect).
L Last
  Last visible object added to the database
:L Rejects locked layers
M  Multiple
   Specifies multiple points without highlighting the objects, thus speeding up
   the selection process for complex objects. The Multiple method also selects two
   intersecting objects if the intersection point is specified twice.
:N Nested
   information is available only for entities selected via graphical selection
   (BlockReference, PolygonMesh, etc.) to the selection set. The result could be
P  Previous
   Selects the most recent selection set. The Previous selection set is cleared by
   operations that delete objects from the drawing. AutoCAD keeps track of whether
   each selection set was specified in model space or paper space. The Previous
   selection set is ignored if you switch spaces.
:P Rejects Viewport
:S Force single object selection only
:U Enables subentity selection - 2006+
selections.
:V Forces subentity selection - 2006+
W  Window
   Selects all objects completely inside a rectangle defined by two points.
   Specifying the corners from left to right creates a window selection.
   (Specifying the corners from right to left creates a crossing selection.)
WP Window Polygon
   Selects objects completely inside a polygon defined by points. The polygon can
   be any shape but cannot cross or touch itself. AutoCAD draws the last segment of
   the polygon so that it is closed at all times. WPolygon is not affected by the
X  Extended search (search whole database)
   Entire database. If you specify the X selection method and do not provide a
   filter-list, ssget selects all entities in the database, including entities on
   layers that are off, frozen, and out of the visible screen.
   Also at the command prompt "Select objects:" you can enter
   Add, Remove, Undo,
Systen Var
  PICKADD controls whether subsequent selections replace the current selection set or add to it.
I've reached the age where the happy hour is a nap. (°Ώ°)
« Reply #19 on: August 24, 2009, 09:44:14 PM »
Note on the :N flag, can't remember but it does not work in all versions of ACAD, should have recorded that.
It's here in the swamp somewhere. 8-)
alanjt
« Reply #20 on: August 24, 2009, 10:03:50 PM »
that's what i'm talking about. you can always count on Alan (not me) to provide well documented info. :)
thanks Alan.
Dropbox
« Reply #21 on: August 25, 2009, 06:30:51 AM »
Thanks Alan!  8-)
Definitely gonna keep hold of that one!  :-)
« Reply #22 on: August 25, 2009, 06:37:51 AM »
Just been studying it, and I'm not too sure on the ":R" mode - what are entities in long transactions?   :?
« Reply #23 on: August 25, 2009, 09:00:06 AM »
I can't explain it, xRef mumbo jumbo. 8-)
But go here :
http://dml.chania.teicrete.gr/mathimata/Simeiwseis/Cad/AutoCAD%202000%20Migration%20Guide.pdf
Search on long transaction
« Reply #24 on: August 25, 2009, 09:04:40 AM »
Thanks Alan,
That explains it... not that I could understand too much  :ugly:
KewlToyZ
« Reply #25 on: August 25, 2009, 10:45:47 AM »
Much more elegant than this.
(defun c:join (/     a    b ai    va    vb    dst1 dst2  a1
       b1    a2    b2 ent1  ent2  ce    end1 end2  dst3
       dst4  oldlst newlst
  (princ "\nJoins two line entities.")
  (defun mid (w z)
    (list (/ (+ (car w) (car z)) 2) (/ (+ (cadr w) (cadr z)) 2))
  (setq a (cadr (entsel "\nSelect first line: ")))
  (setq b (cadr (entsel "\nSelect second:")))
  (setq ai (mid a b))
  (setq va (ssget a))
  (setq vb (ssget b))
  (setq a1 (cdr (assoc 10 (entget (setq ent1 (ssname va 0))))))
  (setq b1 (cdr (assoc 11 (entget (ssname va 0)))))
  (setq a2 (cdr (assoc 10 (entget (setq ent2 (ssname vb 0))))))
  (setq b2 (cdr (assoc 11 (entget (ssname vb 0)))))
  (setq dst1 (distance ai a1))
  (setq dst2 (distance ai b1))
  (if (< dst1 dst2)
    (setq end1 b1)
    (setq end1 a1)
  (setq dst3 (distance ai a2))
  (setq dst4 (distance ai b2))
  (if (< dst3 dst4)
    (setq end2 b2)
    (setq end2 a2)
  (setq oldlst (entget ent1))
  (setq newlst (subst (cons 10 end1) (assoc 10 oldlst) oldlst))
  (setq newlst (subst (cons 11 end2) (assoc 11 newlst) newlst))
  (entdel ent2)
  (entdel ent1)
  (entmake (cdr newlst))
  ;(end)
alanjt
« Reply #26 on: August 25, 2009, 11:04:10 AM »
       dst4  oldlst newlst
  (defun mid (w z)
  (setq ai (mid a b))
  (setq va (ssget a))
  (setq vb (ssget b))
  (if (< dst1 dst2)
    (setq end1 b1)
    (setq end1 a1)
  (if (< dst3 dst4)
    (setq end2 b2)
    (setq end2 a2)
  (entdel ent2)
  (entdel ent1)
  ;(end)
mmm, Glue
Dropbox
