Author Topic: Join Lines to Polylines  (Read 14353 times)
POCKETS
« on: August 20, 2009, 05:27:00 PM »
The included list joins lines to polylines.
Since I am forced to use R2008 it doesn't work.  It worked great in R2002 but as I said not now.  :x
;;;;8:18 AM 05/09/2008 theexchange
;;The user selects a line, arc or polyline and then several lines, arcs or polylines and then the function joins all that touch into one polyline.
(defun c:JP (/ EntType SS)
  (princ "\nSelect lines, arcs or polylines to be joined into a polyline.")
  (if (setq SS (ssget))
      (setq EntType (cdr (assoc 0 (entget (ssname SS 0)))))
      (if (or (= EntType "LINE")(= EntType "ARC"))
        (command ".PEDIT" SS "Y" "J" SS "" "X")
      (if (or (= EntType "POLYLINE")(= EntType "LWPOLYLINE"))
        (command ".PEDIT" SS "J" SS "" "X")
    (princ "\nNo lines, arcs or polylines selected.")
Re: Join Lines to Polylines
« Reply #1 on: August 20, 2009, 05:44:10 PM »
Perhaps:
(defun c:jp (/ ope ss)
  (setq ope (getvar "PEDITACCEPT"))
  (if (setq ss (ssget '((0 . "ARC,*POLYLINE,LINE"))))
      (setvar "PEDITACCEPT" 1)
      (command "_.pedit" "_M" ss "" "_J" "" "")))
  (setvar "PEDITACCEPT" ope)
  (princ))
alanjt
  • Standby for witty remark...
« Reply #2 on: August 20, 2009, 10:10:00 PM »
(defun c:JP (/ ss)
  (and (setq ss (ssget ":L" '((0 . "ARC,*POLYLINE,LINE"))))
       (if (zerop (getvar "peditaccept"))
         (command "_.pedit" "_m" ss "" "_y" "_j" "" "")
         (command "_.pedit" "_m" ss "" "_j" "" "")
       ) ;_ if
  ) ;_ and
) ;_ defun
don't have to change any variables & objects on locked layers are ignored.
Dropbox
« Reply #3 on: August 21, 2009, 06:47:24 AM »
Much better  :wink:
Chris
« Reply #4 on: August 21, 2009, 07:52:49 AM »
(defun c:JP (/ ss)
       ) ;_ if
  ) ;_ and
) ;_ defun
please forgive my ignorance, but what is the : in front of the L for?  and wouldn't it work better if selection method wasn't specified?
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #5 on: August 21, 2009, 07:56:43 AM »
:L means ignore objects on locked layers  :-)
alanjt
« Reply #6 on: August 21, 2009, 08:37:37 AM »
selection method? are you talking about the filter in ssget?
(defun c:JP (/ ss)
       ) ;_ if
  ) ;_ and
) ;_ defun
Dropbox
« Reply #7 on: August 22, 2009, 03:55:11 PM »
It appears that Chris mistook the :L for Last selection method when in fact it is as Lee said "Reject Locked Layers".
Nice one Alan.
alanjt
« Reply #8 on: August 22, 2009, 03:57:49 PM »
Nice one Alan.
Thanks Alan.
Dropbox
Chris
« Reply #9 on: August 24, 2009, 07:51:34 AM »
Nice one Alan.
I get it, it's one of those undocumented things. (or if it is documented, could someone please point it out?)
Win 10
« Reply #10 on: August 24, 2009, 07:58:03 AM »
Check out Page 8 of this from AU - quite interesting. :-)
« Last Edit: August 24, 2009, 08:13:25 AM by Lee Mac »
Krushert
  • FREE BEER Tomorrow!!
« Reply #11 on: August 24, 2009, 08:11:14 AM »
Check out Page 8 of this from AU - quite interesting:
POCKETS
« Reply #12 on: August 24, 2009, 08:14:57 AM »
My thanks to one and all
Pockets
« Reply #13 on: August 24, 2009, 08:16:42 AM »
Pockets
Not a problem guys, you're welcome   8-)
alanjt
« Reply #14 on: August 24, 2009, 08:55:02 AM »
here's some of them i had in a text file
    *  (ssget "_:S") - selecting a single object
    * (ssget "_:E") - selecting all objects crossing the selection box (can be also combined to e.g. (ssget "_:E:S")
    * (ssget "_:N") - selecting objects including nested/child objects - e.g. with block references
    * (ssget "_:D") - duplicate objects counted separately (2x selected object = 2 selections)
    * (ssget "_:L") - stops users from selecting objects on locked layers
    * (ssget "_:P") - rejects selection of viewports
    * (ssget "+.") - allows window selection even in the single selection mode - (ssget "+.:E:S") (may not work in localized versions)
Dropbox
