Author Topic: ** Error: "LispFromPtr failed. The type is not supported:" 10 **  (Read 4117 times)
I keep getting the above error when trying to read data from an Excel Spreadsheet, but I do not know what is causing the error, as I have run my program on other spreadsheets and all seems fine.
Have any of you experienced this?
Thanks,
Lee
Patrick_35
Re: ** Error: "LispFromPtr failed. The type is not supported:" 10 **
« Reply #1 on: August 24, 2009, 11:01:59 AM »
Hi
The simplest is to provide an example.
« Reply #2 on: August 24, 2009, 11:24:54 AM »
Hi
Thank you for your response Patrick.
I have recently found that this error occurs when reading a cell that contains an invalid formula, and have resolved the issue.
Thanks,
Lee
ahankhah
  • Mosquito
« Reply #3 on: April 20, 2021, 09:35:38 AM »
Hi Lee, Just now (12 years after you sent this post  :2funny:) I found that this error occures when an "Excel" cell is containing a numeric value with a "point" as "period".
AFAIK it is not Excel related problem. It is due to "Windows" settings when "/" is assigned to "Decimal Symbol".
Enclosed Clip shows how I got rid of the error. But I don't know why this incompatibility occures. When using "/" to write a decimal number like1.5 obviously it must be typed as: 1/5, but surprisingly Excel changes that to 0/2 (It divides 1 to 5).
I am sure you can write a Visual LISP code to solve this problem automatically.
