Author Topic: Profile/Section Segment Labels - Weeding Factor?  (Read 1531 times)
dfarris75
« on: August 11, 2009, 09:44:30 AM »
Is there a way to weed out segment labels in profiles and sections? I sorta like the idea posed in this article, but I'm having a difficult time implementing it.
Re: Profile/Section Segment Labels - Weeding Factor?
« Reply #1 on: August 11, 2009, 10:42:55 AM »
why are you not just setting the weeding factor for the band set being applied to the section views?
The Code Set method is going all the way back to your assemblies, and the corridor object having the desired code set applied.
Then you can use the labels from the point link and shape codes within the assemblies for labels within your section views.
