Author Topic: Swap block that resides in nest  (Read 5522 times)
ArgV
Re: Swap block that resides in nest
« Reply #15 on: August 11, 2009, 09:46:10 PM »
May be this one ?
;; MBLOCKREPLACE (gile)
;; Replace one or more blocks by another one
(defun c:MBlockReplace (/ *error* acdoc blst target source)
  (defun *error* (msg)
    (vla-EndUndoMark acdoc)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vlax-for b (vla-get-Blocks acdoc)
    (if (and
          (= (vla-get-IsLayout b) :vlax-false)
          (= (vla-get-IsXref b) :vlax-false)
          (not (wcmatch (setq name (vla-get-Name b)) "`**,*|*"))
      (setq blst (cons (vla-get-Name b) blst))
  (setq target (ListBox "MBlockReplace"
                        "Select the block(s) to be replaced"
                        (mapcar 'cons blst blst)
                        2
  (setq source (ListBox "MBlockReplace"
                        "Select a block to replace block(s)"
                        1
  (vla-StartUndoMark acdoc)
  (vlax-for blk
            (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
    (vlax-for obj blk
      (if (and
            (= (vla-get-ObjectName obj) "AcDbBlockReference")
            (vl-position (vla-get-Name obj) target)
        (vla-put-Name obj source)
  (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports)
;; ListBox (gile)
;; DialogBox which allows one more choices in a list
;; Arguments
;; title : The dialog title (STR)
;; msg ; message (STR), "" or nil for none
;; keylab : an association list which type is ((key1 . label1) (key2 . label2) ...)
;; flag : 0 = popup list
;;        1 = single choice list
;;        2 = multipe choices list
;; Return : the option key (flag = 0 or 1) or the option keys list (flag = 2)
;; Example
;; (listbox "Layout" "Choos a layout" (mapcar 'cons (layoutlist) (layoutlist)) 1)
(defun ListBox (title msg keylab flag / tmp file dcl_id choice)
  (setq tmp  (vl-filename-mktemp "tmp.dcl")
file (open tmp "w")
  (write-line
    (strcat "ListBox:dialog{label=\"" title "\";")
    file
  (if (and msg (/= msg ""))
    (write-line (strcat ":text{label=\"" msg "\";}") file)
  (write-line
      ((= 0 flag) "spacer;:popup_list{key=\"lst\";")
      ((= 1 flag) "spacer;:list_box{key=\"lst\";")
      (T "spacer;:list_box{key=\"lst\";multiple_select=true;")
    file
  (write-line "}spacer;ok_cancel;}" file)
  (close file)
  (setq dcl_id (load_dialog tmp))
  (if (not (new_dialog "ListBox" dcl_id))
    (exit)
  (start_list "lst")
  (mapcar 'add_list (mapcar 'cdr keylab))
  (end_list)
  (action_tile
    "accept"
    "(or (= (get_tile \"lst\") \"\")
    (if (= 2 flag) (progn
    (foreach n (str2lst (get_tile \"lst\") \" \")
    (setq choice (cons (nth (atoi n) (mapcar 'car keylab)) choice)))
    (setq choice (reverse choice)))
    (setq choice (nth (atoi (get_tile \"lst\")) (mapcar 'car keylab)))))
    (done_dialog)"
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete tmp)
  choice
Hey Gile, thanks for the help. I tried to run this, it dies as soon as I hit "ok" on the dialog box, and I don't feel like fixing any more stuff today.. did enough of that at work. :)
thanks,
-ArgV
« Reply #16 on: August 11, 2009, 10:49:00 PM »
If you could post some test DWGs I'm sure a solution would be found.
gile
  • Marseille, France
« Reply #17 on: August 12, 2009, 04:44:40 AM »
Sorry, one more time I forgot to join a sub routine.
Here's the complete code
    (if (and
                        2
                        1
  (vlax-for blk
    (vlax-for obj blk
      (if (and
;; ListBox (gile)
;; Arguments
;; Example
file (open tmp "w")
  (write-line
    file
  (write-line
    file
  (close file)
    (exit)
  (start_list "lst")
  (end_list)
  (action_tile
    "accept"
    (done_dialog)"
  (start_dialog)
  choice
;; Str2Lst
;; Transforms a string with separator into a list of strings
;; Arguments
;; str = the string
;; sep = the separator pattern
(defun str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
    (cons (substr str 1 pos)
  (str2lst (substr str (+ (strlen sep) pos 1)) sep)
    (list str)
« Reply #18 on: August 12, 2009, 09:01:27 AM »
David,
Took a look at your routine & found some bugs.
Revised code:
(defun c:rnblk (/ bl   ; Block List
                tdef ; Table Definition
                bn   ; Block Name existing
                bnt
                fe
                fd  ;
                nn  ; New Name
  ;;"old_name"  . "new_name"
  (setq bl '(("Drillbit5" . "Drillbit")
             ("Drillbit3" . "Drillbit")
             ("Drillbit7" . "Drillbit")
  ;;  itterate the Block Collection
  (while (setq tdef (tblnext "BLOCK" (not tdef)))
    (setq bn (cdr (assoc 2 tdef))
          fe (cdr (assoc -2 tdef))
    (princ (strcat "\n" bn))
    (while fe
      (and (setq fd (entget fe))
           (= "INSERT" (cdr (assoc 0 fd)))
           (setq bnt (cdr(assoc 2 fd)))
           (setq nn (cdr (assoc bnt bl)))
           (tblsearch "BLOCK" nn)
           (entmod (subst (cons 2 nn) (assoc 2 fd) fd))
      (setq fe (entnext fe))
  (command "REGENALL")
  (prin1)
David Bethel
« Reply #19 on: August 12, 2009, 12:28:26 PM »
I probably should have made a sample dwg to test it on,  Thanks  -David
R12 Dos - A2K
« Reply #20 on: August 12, 2009, 01:11:09 PM »
A couple of tweaks and it worked well in my test.
Note that the new block must exist in the DWG.
ArgV
« Reply #21 on: August 13, 2009, 12:56:06 AM »
I've heard about the difference between blocks and inserts, but have never really 'understood' the difference. However, this works great for nested blocks. Thanks. :)
-ArgV
« Reply #22 on: August 13, 2009, 08:06:07 AM »
There is a lot of information about the differences in this thread:
http://www.cadtutor.net/forum/showthread.php?t=36729
