Hi folks, I realise this is Inventor related so please feel free to move this post to wherever it needs to go. (If there is indeed somewhere else for it to go that is?)
For whatever reason, our client can't view pdfs created by the native pdf printer in Inventor 2009, so I had to come up with a method of printing the contents of the DrawingDocument (DrawDoc) using
PDFCreator.
I have cobbled together the following code that seems to work, based on the examples that are provided upon installation of the latest package, yet for some reason I can almost never get it to print the first page from the DrawDoc.
I think the problem lies with how the PDFCreator is initialized, but I can't seem to figure it out and thought perhaps one of you might be able to help me.
Here's the code: -
Option Explicit
Public Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long)
Public tmpstr As String
Public revisions(8, 4) As String ' 10 is the maximum number of revisions the border can have
' Add a reference to PDFCreator
Public pdfcreator1 As PDFCreator.clsPDFCreator
Public ReadyState As Boolean
Public DefaultPrinter As String
Public ProjectLocation As String
Public ProjectName As String
Public Project As String
Public pErr As PDFCreator.clsPDFCreatorError
Public StartTime As Date
Public Sub PlotPdf()
Dim killit
Dim numsheets As Integer
Dim parameters As String
Set pErr = New PDFCreator.clsPDFCreatorError
Set pdfcreator1 = New clsPDFCreator
pdfcreator1.cPrinterStop = False
pdfcreator1.cVisible = True
numsheets = 0
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
With pdfcreator1
.cVisible = True
parameters = "/NoProcessingAtStartup"
If .cStart(parameters) = False Then
If .cStart(parameters, True) = False Then
.cClearCache
.cOption("UseAutoSave") = 0
' killit = Shell("taskkill /f /im PDFCreator.exe", VbAppWinStyle.vbHide)
' MsgBox ("There was an error starting the pdf printer, please try (click) again!")
' Debug.Print "Can't initialize PDFCreator."
' Exit Sub
End If
AddStatus "Use an existing running instance!"
.cVisible = True
End If
End With
' Debug.Print "PDFCreator initialized."
Dim oDrgDoc As DrawingDocument
Set oDrgDoc = ThisApplication.ActiveDocument
UserForm1.ComboBox1.AddItem ("Aliquot")
' UserForm1.ComboBox1.AddItem ("EDD")
UserForm1.Show
' Set reference to drawing print manager
Dim oDrgPrintMgr As DrawingPrintManager
Set oDrgPrintMgr = oDrgDoc.PrintManager
' Set the printer name
oDrgPrintMgr.Printer = "PDFCreator"
Dim shts As sheets
Dim sht As sheet
Dim outName As String
Dim i As Integer
Dim j As Integer
Dim Latestrev As Integer
Dim sheetsize As PaperSizeEnum
sheetsize = kPaperSizeA0
sheetsize = kPaperSizeA1
' shts = oDrgDoc.sheets
For Each sht In oDrgDoc.sheets
sht.Activate
'Set the paper size , scale and orientation
oDrgPrintMgr.ScaleMode = kPrintFullScale ' kPrintBestFitScale
' Change the paper size to a custom size. The units are in centimeters.
Dim shtsize As Long
shtsize = sht.Size
oDrgPrintMgr.PaperSize = kPaperSizeCustom
If shtsize = 9993 Then ' A0
oDrgPrintMgr.PaperHeight = 84.1
oDrgPrintMgr.PaperWidth = 118.9
ElseIf shtsize = 9994 Then ' A1
oDrgPrintMgr.PaperHeight = 59.4
oDrgPrintMgr.PaperWidth = 84.1
ElseIf shtsize = 9995 Then ' A2
oDrgPrintMgr.PaperHeight = 42
oDrgPrintMgr.PaperWidth = 59.4
ElseIf shtsize = 9996 Then ' A3
oDrgPrintMgr.PaperHeight = 29.7
oDrgPrintMgr.PaperWidth = 42
End If
oDrgPrintMgr.PrintRange = kPrintCurrentSheet
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.AllColorsAsBlack = False
oDrgPrintMgr.Rotate90Degrees = True
Latestrev = RetrieveRev
outName = RetrievePE("<Drawing Number>", sht) & " REV " & Latestrev & ".pdf"
With pdfcreator1
.cOption("UseAutosave") = 1
.cOption("UseAutosaveDirectory") = 1
.cOption("AutosaveDirectory") = "\\bas059\Aliquot\pdfs\" ' Project
.cOption("AutosaveFilename") = outName
.cOption("AutosaveFormat") = 0 ' 0 = PDF
.cClearCache
End With
oDrgPrintMgr.SubmitPrint
StartTime = Now
Do Until pdfcreator1.cCountOfPrintjobs = 1
DoEvents
Sleep 1000
Loop
Sleep 1000
For i = 1 To 8
For j = 1 To 4
revisions(i, j) = ""
Next j
Next i
numsheets = numsheets + 1
AddStatus pdfcreator1.cOutputFilename & " was created! (" & _
DateDiff("s", StartTime, Now) & " seconds)"
Next
Else
MsgBox ("You aren't using an Inventor drawing!")
Exit Sub
End If
MsgBox ("Done Printing " & numsheets & " sheets!")
pdfcreator1.cClose
End Sub
'--- the code hereafter is simply for populating the filename with the correct information/ setting the sheetsize etc.
Public Function Setsheetsize(shtsize As PaperSizeEnum) As PaperSizeEnum
Setsheetsize = kPaperSizeA0
Setsheetsize = kPaperSizeA1
Setsheetsize = kPaperSizeA2
Setsheetsize = kPaperSizeA3
End If
End Function
Public Function RetrievePE(searchstring As String, oSheet As sheet) As String
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Dim oSheet As sheet
' Set oSheet = oDrawDoc.ActiveSheet
' Get the prompted text value from the title block.
' This is done by first getting the text box in the title
' block definition that defines the prompted text. Then
' you can use this to get the value specified for this
' particular title block instance.
Dim oBorderDef As BorderDefinition
Set oBorderDef = oSheet.Border.Definition
Dim oTextBox As TextBox
Dim bFound As Boolean
bFound = False
For Each oTextBox In oBorderDef.Sketch.TextBoxes
If GetPromptField(oTextBox.FormattedText) = searchstring Then
bFound = True
Exit For
End If
Next
If bFound Then
' oSheet.Name = oSheet.Border.GetResultText(oTextBox)
RetrievePE = oSheet.Border.GetResultText(oTextBox)
Else
MsgBox "Specified formatted text was not found in the title block."
End If
End Function
Public Function RetrieveRev() As Integer ' will only work whilst the revision is numeric!
Dim oSheet As sheet
bFound = False
Dim Revision As String
Dim cnt As Integer
Dim i As Integer
Dim j As Integer
i = 1
cnt = 0
Revision = GetPromptField(oTextBox.FormattedText)
If Revision Like "*REV*" Then
If Revision Like "*REV*Change*" Or Revision Like "*REV*CHANGE*" Then
revisions(i, 1) = oSheet.Border.GetResultText(oTextBox) ' Change
cnt = cnt + 1
ElseIf Revision Like "*REV*Date*" Or Revision Like "*REV*DATE*" Then
revisions(i, 3) = oSheet.Border.GetResultText(oTextBox) ' Date
cnt = cnt + 1
ElseIf Revision Like "*REV*" And Len(Revision) < 13 Then
revisions(i, 2) = oSheet.Border.GetResultText(oTextBox) ' Rev
cnt = cnt + 1
End If
revisions(i, 4) = oSheet.Name
If cnt = 3 Then
cnt = 0
i = i + 1
End If
End If
Next
For i = LBound(revisions) To UBound(revisions)
If revisions(i, 1) <> "" Then
' Debug.Print revisions(i, 1) & "|" & revisions(i, 2) & "|" & revisions(i, 3)
End If
Next i
Bubblesort
End If
Next i
If revisions(i, 2) <> "" Then
RetrieveRev = revisions(i, 2)
If revisions(i + 1, 2) = "" Then ' we reached the highest revision.
Exit For
End If
End If
Next i
End Function
' Get the text value of the prompted text. It extracts this from the' formatted text. If there's a failure then an empty string is =returned.
Private Function GetPromptField(ByVal FormattedText As String) As String
On Error GoTo ErrorFound
' Verify that this is a prompt field.
If Left$(FormattedText, 7) <> "<Prompt" Then
GetPromptField = ""
Exit Function
End If
' Get the text that is to the right of the first ">" symbol
' and to the left of the last "<" symbol.
' Debug.Print FormattedText
GetPromptField = Right$(FormattedText, Len(FormattedText) - InStr(FormattedText, ">"))
GetPromptField = Left$(GetPromptField, InStr(GetPromptField, "<") - 1)
' Replace any < or > with < and > symbols.
GetPromptField = Replace(GetPromptField, "<", "<")
GetPromptField = Replace(GetPromptField, ">", ">")
Exit Function
ErrorFound: GetPromptField = ""
End Function
Public Sub Bubblesort()
Dim i As Integer
Dim j As Integer
Dim temp As String
Dim iOuter As Long
Dim iInner As Long
Dim iLbound As Long
Dim iUbound As Long
Dim iTemp As String
iLbound = LBound(revisions)
For i = iLbound To UBound(revisions) ' - 1
iUbound = i
End If
Next i
For iOuter = iLbound To iUbound ' - 1
'Which comparison
For iInner = iLbound To iUbound - iOuter - 1
'Compare this item to the next item
If revisions(iInner, 2) <> "" Then ' Continue
' Debug.Print "About to sort " & revisions(iInner, 4)
If CInt(revisions(iInner, 2)) > CInt(revisions(iInner + 1, 2)) Then
'Swap
iTemp = revisions(iInner, 1)
revisions(iInner, 1) = revisions(iInner + 1, 1)
revisions(iInner + 1, 1) = iTemp
iTemp = revisions(iInner, 2)
revisions(iInner, 2) = revisions(iInner + 1, 2)
revisions(iInner + 1, 2) = iTemp
iTemp = revisions(iInner, 3)
revisions(iInner, 3) = revisions(iInner + 1, 3)
revisions(iInner + 1, 3) = iTemp
iTemp = revisions(iInner, 4)
revisions(iInner, 4) = revisions(iInner + 1, 4)
revisions(iInner + 1, 4) = iTemp
End If
End If
Next iInner
Next iOuter
' MsgBox ("Done Sorting!")
End Sub
Private Sub PrintPage(PageNumber As Integer)
Dim cPages As Long
cPages = Selection.Information(wdNumberOfPagesInDocument)
If PageNumber > cPages Then
MsgBox "This document has only " & cPages & " pages!", vbExclamation
End If
DoEvents
ActiveDocument.PrintOut Background:=False, Range:=wdPrintFromTo, From:=CStr(PageNumber), To:=CStr(PageNumber)
DoEvents
End Sub
Private Sub PDFCreator1_eError()
pErr = pdfcreator1.cError
AddStatus ("Status: Error[" & pErr.Number & "]: " & pErr.Description)
End Sub
Private Sub PDFCreator1_eReady()
AddStatus "File'" & pdfcreator1.cOutputFilename & "' was saved."
pdfcreator1.cPrinterStop = True
' CommandButton1.Enabled = True
End Sub
Private Sub AddStatus(Str1 As String)
Debug.Print vbCrLf & Now & ": " & Str1
End Sub
Also, I would ideally like to run this from a toolbar within IV2009 - can someone please provide an example of how to accomplish this?
Thanks.
