Author Topic: [Question]Select Multi Files  (Read 2459 times)
kraz
« on: August 02, 2009, 09:24:19 PM »
I want to know how can i Select Files without dcl or dos_filem..
as it possible, I Want to use WMI method like " (setq ShlObj (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application")  Folder(vlax-invoke-method ShlObj 'BrowseForFolder 0 msg 0)) "
thanks all...
Re: [Question]Select Multi Files
« Reply #1 on: August 02, 2009, 11:47:07 PM »
kraz
« Reply #2 on: August 02, 2009, 11:51:52 PM »
Did you do a SEARCH?
This Search for BrowseForFolder
hmm...I don't want BrowseforFolder...this is for Select Folder. but I want multi select files...
« Reply #3 on: August 03, 2009, 12:03:04 AM »
Have you tried?
(setq file+path (getfiled "Select a File you want" "" "" 4))
« Reply #5 on: August 03, 2009, 12:19:16 AM »
I've been down this road & never found one that worked with Windows 2000.
Here is a DCL option.
http://www.theswamp.org/index.php?topic=14536.msg177095#msg177095
kraz
« Reply #6 on: August 03, 2009, 02:07:52 AM »
thanks CAB..
most of all , I had Searched with many keyword like files, multi select files, wmi bla bla bla~...., but i Couldn't Found....anyway sorry.
filebox func, you found, is nice to me.. but i can't understand, wmi has browseforfolder method but have not files method....I want to know there is another method ...or any other good functions...
god bless you~~ :angel:
gile
  • Marseille, France
« Reply #7 on: August 03, 2009, 02:35:21 AM »
AFAIK, there're no way working fine without an external arx or dll.
"acet-ui-getfile" function from the express tools works the same as "userAccounts.CommonDialog" (IOW: as bad as).
I made a little .NET DLL to which implements 4  LISP functions to open Windows standard dialog boxes, you can found it here
