I was just thinking....when i break down my procedure and ask for the user to select the line, the code works fine; however, in my code, i loop through a set of polygons.
for each polygon, i use SelectCrossingPolygon(myPtColl, filter) to give me a list of lines that are inside it.
for each line i then draw boxes for each end in order to find lines close to it. I pass the crossing window params like this:
<code>
Dim resW As PromptSelectionResult = Nothing
resW = doc.Editor.SelectCrossingWindow(myVectorYStartPt, myVectorY2StartPt, filter)
</code>
do you think that this has something to do w/ why it's not giving me the correct results?
thanks
proctor
