Author Topic: Add Dtext to get Total  (Read 10438 times)
GDF
Re: Add Dtext to get Total
« Reply #30 on: July 30, 2009, 05:47:04 PM »
I think my version solved that problem. No?
Nope.
Only mine.... I win.... :-)
Nope, still same problem...
« Reply #31 on: July 30, 2009, 05:51:55 PM »
Thanks for the pointers Alan  :-)
How 'bout this approach:
;;  By Lee
;;  Sum the text selected & add new text with the total
(defun c:dPick (/ ss doc spc sel lst tStr tObj gr)
  (if (setq ss (ssget '((0 . "TEXT"))))
      (setq doc (vla-get-ActiveDocument
                  (vlax-get-Acad-Object))
            spc (if (zerop (vla-get-activespace doc))
                  (if (= (vla-get-mspace doc) :vlax-true)
                    (vla-get-modelspace doc)
                    (vla-get-paperspace doc))
                  (vla-get-modelspace doc)))
      (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet doc))
        (setq lst (cons (distof (vla-get-TextString Obj) 4) lst)))
      (setq tStr (rtos (apply '+ (vl-remove-if 'null lst)) 4 2))
      (setq tObj (vla-addText spc tStr (vlax-3d-point '(0 0 0))
                     (*(getvar "DIMSCALE")(getvar "DIMTXT"))))
      (vla-put-Alignment tObj acAlignmentMiddleCenter)
      (while
          (setq gr (grread 't 5 0))
          (cond ((eq 5 (car gr))
                 (vla-put-TextAlignmentPoint tObj
                   (vlax-3D-point (trans (cadr gr) 1 0))) t)
                (t nil))))))
  (princ))
« Reply #32 on: July 30, 2009, 05:52:18 PM »
Nope.
Did you change the ' while ' line in Lee's code to mine?  It worked here once I did that.
« Reply #33 on: July 30, 2009, 05:54:03 PM »
Try this.
      (princ "\nText About to be Placed.")
      (vla-put-Alignment
                     (vla-getVariable doc "VIEWCTR")
      (princ "\nGrRead commences here. ")
[color=red]      (while (not (eq 3 (car (setq gr (grread 't 5 0)))))[/color]
        (vla-move tObj
          (vla-get-TextAlignmentPoint tObj)
                  (vlax-3D-point (trans (cadr gr) 1 0))))
      (princ "\nGrRead Complete.")
      (vla-delete sel)))
  (princ))
« Reply #34 on: July 30, 2009, 05:55:18 PM »
Tim, did you try my version?
It will exit with left or right click or Enter. The text is updated to the last known cursor position.
Mine doesn't work for you?
« Reply #35 on: July 30, 2009, 05:56:33 PM »
Could it be the varying speeds of our PC's that are affecting this? If the grread is being evaluated too quickly after the ssget input is completed, meaning that the right-click or enter is being swept into the grread loop?
Just a theory :P
Spike Wilbury
« Reply #36 on: July 30, 2009, 05:59:00 PM »
Tim,
just tried the routine and returns this:
DPICK
Select objects: 1 found
Select objects:
GrRead commences here. ; error: bad argument type: 2D/3D point: 13
if I hit enter
(so please return the prize that was given away of $100,000,000 swamp dollars  :-P)
« Reply #37 on: July 30, 2009, 06:00:42 PM »
The latest one didn't work unless I hit enter or the space bar.  If I use the right click to end the ssget call, then it would just place it at 0,0.
Just a theory :P
That is what I was thinking.  That is why I changed it the way I did, so it will only exit once you pick a point, instead of stop moving the mouse.  Yours would stop if you hit any button while moving the text.
« Reply #38 on: July 30, 2009, 06:02:33 PM »
Tim,
DPICK
Select objects:
if I hit enter
Hey!!  That wasn't the issue, therefore should not affect my winning... that is a whole new problem by the way it is coded..... :oops:
Spike Wilbury
« Reply #39 on: July 30, 2009, 06:04:12 PM »
Tim,
DPICK
Select objects:
if I hit enter
if i run the first one posted by Lee... it works here using A2009
« Reply #40 on: July 30, 2009, 06:05:50 PM »
Tim,
DPICK
Select objects:
if I hit enter
Even if you right click to end the text selection?  I didn't test it in my '09, only '06.
« Reply #41 on: July 30, 2009, 06:08:58 PM »
One more 8-)
;;  By Lee
      (while (and(/= 3 (car (setq gr (grread 't 5 0)))) (listp (cadr gr)))
          (vla-put-TextAlignmentPoint tObj (vlax-3D-point (trans (cadr gr) 1 0)))
  (princ))
« Reply #42 on: July 30, 2009, 06:10:11 PM »
Thanks a winner Alan!!!!  You can have my prize...  :oops:
Spike Wilbury
« Reply #43 on: July 30, 2009, 06:12:09 PM »
yep... right,left or enter works
« Reply #44 on: July 30, 2009, 06:17:29 PM »
Too much virtual beer I think.  8-)
Off to play some tennis if this rain will hold off.
