Author Topic: Add Dtext to get Total  (Read 10435 times)
GDF
Re: Add Dtext to get Total
« Reply #15 on: July 30, 2009, 11:27:29 AM »
Lee
I could not get yours to work in placing the new dtext total in the drawing.
Hmmm... Seems to work fine for me  :?
I'm using version 2008 and 2010
Command: dpick
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects:
Command:
The routine just stops without placing any text.
GDF
« Reply #16 on: July 30, 2009, 11:34:55 AM »
Lee
Never mind. It works but it placed the text way off or at the first text selected.
Thanks for sharing it.
Alan
I did a search first before I posted. I remember your routine now. I need to learn how to do a proper search.
Thanks for sharing your routine to.
« Reply #17 on: July 30, 2009, 11:36:38 AM »
Lee
I'm not sure why that would be, but oh well.  :-)
« Reply #18 on: July 30, 2009, 11:59:34 AM »
Maybe a trans would help? [Throwing Darts]
;;  By Lee
;;  Sum the text selected & add new text with the total
(defun c:dPick (/ ss doc spc sel lst tStr tObj gr)
  (if (setq ss (ssget '((0 . "TEXT"))))
      (setq doc (vla-get-ActiveDocument
                  (vlax-get-Acad-Object))
            spc (if (zerop (vla-get-activespace doc))
                  (if (= (vla-get-mspace doc) :vlax-true)
                    (vla-get-modelspace doc)
                    (vla-get-paperspace doc))
                  (vla-get-modelspace doc)))
      (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet doc))
        (setq lst (cons (distof (vla-get-TextString Obj) 4) lst)))
      (setq tStr (rtos (apply '+ (vl-remove-if 'null lst)) 4 2))
      (vla-put-Alignment
        (setq tObj (vla-addText spc tStr
                     (vla-getVariable doc "VIEWCTR")
                     (*(getvar "DIMSCALE")(getvar "DIMTXT"))))
        acAlignmentMiddleCenter)
      (while (eq 5 (car (setq gr (grread 't 5 0))))
        (vla-move tObj
          (vla-get-TextAlignmentPoint tObj) (vlax-3D-point ([color=red]trans[/color] (cadr gr) 1 0))))
      (vla-delete sel)))
  (princ))
« Reply #19 on: July 30, 2009, 12:16:40 PM »
Yeah, nice idea Alan, could well be that  :-)
GDF
« Reply #20 on: July 30, 2009, 03:25:14 PM »
Alan
Lee's routine and your fix still will not let me pick the location for the new added text. The text jumps to 0,0.
« Reply #21 on: July 30, 2009, 03:44:38 PM »
I can't understand that.
My routine just adds the Text using at the point defined by the VIEWCTR sys var, then moves this text using mouse positions retrieved through the GrRead loop - I can't see where it is failing...   :|
As an error catching exercise, what does your command line look like after running this?
;;  By Lee
      (princ "\nText About to be Placed.")
      (vla-put-Alignment
      (princ "\nGrRead commences here. ")
        (vla-move tObj
                  (vlax-3D-point (trans (cadr gr) 1 0))))
      (princ "\nGrRead Complete.")
      (vla-delete sel)))
  (princ))
GDF
« Reply #22 on: July 30, 2009, 05:13:37 PM »
Command: (LOAD "E:/Arch_WorkOn/architettura/dpick2.lsp") C:DPICK
Command: dpick
Select objects:
GrRead Complete.
Command:
The routine will still not let me place the dtext. THe routine places it at 0,0 still.
« Last Edit: July 30, 2009, 05:16:46 PM by GDF »
« Reply #23 on: July 30, 2009, 05:21:38 PM »
That is crazy... no errors whatsoever, and yet, I cannot get it to fail here  :-(
« Reply #24 on: July 30, 2009, 05:27:48 PM »
Happens here the same as Gary pretty much.  Once you select the text, the code ends, and the new text is placed at 0,0
DPICK
Select objects: Specify opposite corner: 4 found
Select objects:
GrRead Complete.
« Reply #25 on: July 30, 2009, 05:33:41 PM »
Another version to test:
;;  By Lee
      (setq tObj (vla-addText spc tStr (vlax-3d-point '(0 0 0))
      (vla-put-Alignment tObj acAlignmentMiddleCenter)
          (vla-put-TextAlignmentPoint tObj (vlax-3D-point (trans (cadr gr) 1 0)))
  (princ))
« Reply #26 on: July 30, 2009, 05:36:41 PM »
The problem seems to be with the grread loop.  Exit the selection with hitting the right click, and then exit hitting enter.  If I hit enter I can see the text, and place it, but if I hit the right click, then it just places.
edit:  Added code to show what works here
      (while (not (eq 3 (car (setq gr (grread 't 5 0)))))
« Reply #27 on: July 30, 2009, 05:36:52 PM »
Lee, no need to position the new text other than '(0 0) as it will only remain there a nano second. :)
No need for the MOVE, just update the text object position.
« Reply #28 on: July 30, 2009, 05:38:33 PM »
I think my version solved that problem. No?
« Reply #29 on: July 30, 2009, 05:44:52 PM »
Nope.
Only mine.... I win.... :-)
