Author Topic: Add Dtext to get Total  (Read 10369 times)
GDF
« on: July 29, 2009, 02:59:48 PM »
Does anyone have a routine for adding dtext in architectural units "feet" and "inches" to get a total?
The one below only does decimal without reading the inches.
14'-0" + 12'-4" = 26.00
(defun ADD-TXT  (/ s1 lg index count c x a d totalarea atext apoint)
  (setq S1    (ssget)
        LG    (sslength S1)
        INDEX 0
        COUNT 0
        C     0)
  (while (/= INDEX LG)
    (setq X (ssname S1 INDEX)
          A (entget X)
          D (cdr (assoc 0 A)))
    (if (= D "TEXT")
      (progn (setq B     (atof (cdr (assoc 1 A)))
                   C     (+ C B)
                   COUNT (1+ COUNT))))
    (setq INDEX (1+ INDEX)))
  (setq TOTALAREA (rtos C 2 2))
  (setq ATEXT (strcase (strcat "" TOTALAREA "")))
  (while (not apoint)
    (setq APOINT (getpoint "\n* Pick Location for Text in Drawing... *"))
    (command "text" "j" "bl" APOINT 9 0 ATEXT))
  (princ))
Spike Wilbury
Re: Add Dtext to get Total
« Reply #1 on: July 29, 2009, 03:19:04 PM »
Hi Gary
Maybe if it is used something like:
(rtos (+ (distof "14'-0" 4)(distof "12'-4" 4)) 4 2) ;; having dimzin=3
"26'-4\""
GDF
« Reply #2 on: July 29, 2009, 03:25:48 PM »
Luis
I'm looking to pick the dtext objects in a drawing to get the total, then place that total as dtext in the drawing.
;;;this code will do it for dimensions
;;;Peter Jamtgaard
(defun ADIMIT  (/ CNT ENAM EOBJ SSET)
  (prompt "\n* Select All Dimensions to Total in Imperial Units *")
  (setq CNT 0
        SUM 0)
  (if (setq SSET (ssget (list (cons 0 "DIMENSION"))))
    (progn (command ".dim1" "update" SSET "")
           ;;added this line
           (repeat (sslength SSET)
             (setq ENAM (ssname SSET CNT)
                   CNT  (1+ CNT)
                   EOBJ (vlax-ename->vla-object ENAM))
             (vl-catch-all-apply
               '(lambda (X) (setq SUM (+ SUM (vla-get-measurement X))))
               (list EOBJ)))
           ;;(princ (strcat "\n" (rtos SUM 4 6)))
           (princ (strcat "\n* Total Dimension = " (rtos SUM 4 6) " *"))))
  (prin1))
Spike Wilbury
« Reply #3 on: July 29, 2009, 03:36:43 PM »
need to practice.... there you go sir - super mickey mouse stuff - and assumes the strings are valid dimension data(s)
(defun C:ATXT ()
  (setq total 0.0)
  (while (setq ent (car (entsel "\nSelect text: ")))
      (setq obj (vlax-ename->vla-object ent))
      (setq str (vla-get-textstring obj))
      (setq total (+ (distof str 4) total))
  (princ "\nTotal=") (princ (rtos total 4 2)) (princ)
« Reply #4 on: July 29, 2009, 03:38:27 PM »
Just a quickie  :lol:
(defun c:dPick (/ ss doc spc sel lst tStr tObj gr)
  (if (setq ss (ssget '((0 . "TEXT"))))
      (setq doc (vla-get-ActiveDocument
                  (vlax-get-Acad-Object))
            spc (if (zerop (vla-get-activespace doc))
                  (if (= (vla-get-mspace doc) :vlax-true)
                    (vla-get-modelspace doc)
                    (vla-get-paperspace doc))
                  (vla-get-modelspace doc)))
      (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet doc))
        (setq lst (cons (distof (vla-get-TextString Obj) 4) lst)))
      (setq tStr (rtos (apply '+ (vl-remove-if 'null lst)) 4 2))
      (vla-put-Alignment
        (setq tObj (vla-addText spc tStr
                     (vla-getVariable doc "VIEWCTR")
                       (* (getvar "DIMSCALE") (getvar "DIMTXT"))))
        acAlignmentMiddleCenter)
      (while (eq 5 (car (setq gr (grread 't 5 0))))
        (vla-move tObj
          (vla-get-TextAlignmentPoint tObj) (vlax-3D-point (cadr gr))))
      (vla-delete sel)))
  (princ))
« Last Edit: July 30, 2009, 08:14:28 AM by Lee Mac »
GDF
« Reply #5 on: July 29, 2009, 03:39:04 PM »
This would work fine if it read dtext objects in imperial units and got a total in imperial units.
;;;I am just wondering it it is possible to create a lisp routine that could be used to
;;;tabulate a total distance from text values.  I would like to be able to click each piece
;;;of text and then have AutoCAD return the total
;;;by: Tim Willey
(defun TXCALCIT (/ app cal n l nu1 nu2 nu3 nu4 nu5 tx1 tx2 tx3 tx4)
  (defun get_info ()
    (setq nu1 (entget (ssname cal n)))
    (setq nu2 (cdr (assoc 1 nu1)))
    (setq nu3 (atof nu2))
  (defun addc ()
    (get_info)
    (setq nu4 nu3)
    (setq n (+ 1 n))
    (while (/= l n)
      (get_info)
      (setq nu5 (+ nu4 nu3))
      (setq nu4 nu5)
      (setq n (+ 1 n))
  (defun subc ()
    (get_info)
    (setq nu4 nu3)
    (setq n (+ 1 n))
    (while (/= l n)
      (get_info)
      (setq nu5 (- nu4 nu3))
      (setq nu4 nu5)
      (setq n (+ 1 n))
  (defun multc ()
    (get_info)
    (setq nu4 nu3)
    (setq n (+ 1 n))
    (while (/= l n)
      (get_info)
      (setq nu5 (* nu4 nu3))
      (setq nu4 nu5)
      (setq n (+ 1 n))
  (defun divdc ()
    (get_info)
    (setq nu4 nu3)
    (setq n (+ 1 n))
    (while (/= l n)
      (get_info)
      (setq nu5 (/ nu4 nu3))
      (setq nu4 nu5)
      (setq n (+ 1 n))
  (initget "+ - * /")
  (setq app (getkword
     "\n* What application would you like to do:\(+,-,*,/)"
  (if (or (= app "-") (= app "/"))
    (princ "\n* Don't forget order counts. So pick carefully. *"
  (princ "\nSelect numbers to calculate:")
  (setq cal (ssget '((0 . "TEXT"))))
  (setq n 0)
  (setq l (sslength cal))
  (while (/= l n)
    (get_info)
    (if (= nu3 0.0)
(ssdel (ssname cal n) cal)
(setq l (- l 1))
(setq n (- n 1))
    (setq n (+ n 1))
  (setq n 0)
    ((= app "+")
     (addc)
    ((= app "-")
     (subc)
    ((= app "*")
     (multc)
    ((= app "/")
     (divdc)
  (initget "Replace Write")
  (princ "\nAnswer= ")
  (princ nu5)
  (setq tx1
(getkword
  "\n* What do you want do with the answer\(Replace, Write to screen):"
    ((= tx1 "Replace")
     (setq tx2 (ssget '((0 . "TEXT"))))
     (setq n 0)
     (setq l (sslength tx2))
     (while (/= n l)
       (setq tx3 (entget (ssname tx2 n)))
       (setq tx4 (subst (cons 1 (rtos nu5 2 1)) (assoc 1 tx3) tx3))
       (entmod tx4)
       (setq n (+ 1 n))
    ((= tx1 "Write")
     (setq nu5 (rtos nu5 2 1))
     (princ "\n* Pick point for text insertion")
     (command "text" "j" "m" pause "" "" nu5)
GDF
« Reply #6 on: July 29, 2009, 03:44:03 PM »
Perfect
Thank you Luis
(defun C:ATXT ()
  (setq total 0.0)
GDF
« Reply #7 on: July 29, 2009, 03:49:02 PM »
Lee
I could not get yours to work in placing the new dtext total in the drawing.
« Reply #8 on: July 29, 2009, 06:45:50 PM »
Lee
Hmmm... Seems to work fine for me  :?
« Reply #9 on: July 29, 2009, 09:11:14 PM »
« Reply #10 on: July 29, 2009, 11:23:30 PM »
Lee.
Nice routine! The text was too small in my environment.
FYI, Typically 5 units for text size here and DIMSCALE of 48 and DIMTXT of 0.125
Usually I use (* (getvar "DIMSCALE)(getvar "DIMTXT")) for text Size.
« Last Edit: July 29, 2009, 11:26:45 PM by CAB »
« Reply #11 on: July 30, 2009, 08:15:11 AM »
Lee.
Thanks Alan  :-)
I normally use "TEXTSIZE", but I have seen "DIMTXT" used recently, but thanks for the heads-up, code updated.
Lee
« Reply #12 on: July 30, 2009, 09:35:29 AM »
As you know DIMTXT comes form the Current Dimension Style. The actual dim text size is derived
by (* DIMTXT DIMSCALE) and some use DIMSCALE of ONE but many do not use ONE.
DIMSIZE is the last used text size. Not sure which is more reliable for getting the most desired
text size. I suspect the dimension style may be somewhat constant. Hard to say.
« Reply #13 on: July 30, 2009, 09:50:14 AM »
True, I am always wondering which to use, and normally, whichever method I choose, people seem to always come back and say "The Text is to big/small...".
Thanks for the information about the sys vars, I suppose the choice is either TEXTSIZE or (* (getvar "DIMSCALE") (getvar "DIMTXT")), depending on the consistency of either Dimension Style or Text Style.
Lee
« Reply #14 on: July 30, 2009, 10:15:59 AM »
That's why I usually ask for a sample DWG. Seems I guess wrong too much of the time.  8-)
