Author Topic: script plotting to pdf  (Read 2212 times)
Amsterdamned
« on: July 29, 2009, 09:11:42 AM »
Hello there,
is there a way to plot to pdf in Acad 2006 through a script? The Cutepdf  and the Pdf creator i use always come up with a dialog and ask for the filename.
Thanks in advance
Bernd
Re: script plotting to pdf
« Reply #1 on: July 29, 2009, 09:26:13 AM »
Not sure what exactly it is you are looking for but have a look at some of the 'ghostscript' topics from this.
http://www.theswamp.org/index.php?board=66.20
« Reply #2 on: July 29, 2009, 09:27:18 AM »
BTW ... if you are who I think you are .... long time no see!! :-)
rkmcswain
« Reply #3 on: July 29, 2009, 10:04:19 AM »
Whether or not a dialog appears is a function of the driver. Most of the freebies don't give you many choices. AcroPlot works great.
Amsterdamned
« Reply #4 on: July 31, 2009, 02:22:49 PM »
Mark,
i was busy on a big job designing only, so i had no time for the "nice" work.
i have downloaded a trial of AcroPlot. It looks nice, but i want to print out of lisp, like that
[code(command "-plot"          "y"              ""
                   "DWF6 ePlot.pc3"
                   "ISO A3 (297.00 x 420.00 MM)"     "m"
                   "P"              "n"              "W"
                   lio              reb              "fit"
                   "0,0"            "Y"              "W.ctb"
                   "y"  ""   NAME        "y"   "y"    "y")
Anybody any ideas, please?
rkmcswain
« Reply #5 on: July 31, 2009, 03:51:42 PM »
Then you need a PDF driver that you can configure to withhold the dialog.
Amsterdamned
« Reply #6 on: August 03, 2009, 03:19:10 AM »
I see. But which one??
