Author Topic: Profile directory name with AutoCAD 2009?  (Read 1820 times)
KewlToyZ
« on: July 28, 2009, 01:51:30 PM »
I'm trying to write a profile for AutoCAD 2009.
I only AutoCAD MEP 2009 and it looks like this:
C:\\Documents and Settings\\All Users\\Application Data\\Autodesk\\ACD-MEP 2009\\enu\\
I could assume AutoCAD 2009 instead of ACD-MEP 2009 but I wanted to be sure.
Thanks :wink:
Crank
Re: Profile directory name with AutoCAD 2009?
« Reply #1 on: July 28, 2009, 06:28:35 PM »
I'm wondering why you want this folder, but for Acad2009 it looks like this:
C:\\Documents and Settings\\All Users\\Application Data\\Autodesk\\AutoCAD 2009\\R17.2\\enu\\
KewlToyZ
« Reply #2 on: July 30, 2009, 09:15:23 AM »
Thank you sir. I was building a test version of an open mep system to let a friend try out.
I needed the directory structure names to "find & replace" my MEP paths with Vanilla paths on the arg file.
It's sort of a starter kit for customizing.
