Author Topic: Purge excess scales  (Read 18200 times)
gile
  • Marseille, France
Re: Purge excess scales
« Reply #15 on: August 03, 2009, 11:44:32 AM »
You're welcome.
Hope it helps...
3dwannab
« Reply #16 on: April 24, 2024, 05:42:25 PM »
Thanks Gile, I was trying to remove a corrupt scale with the name of 1:1000 and at a ratio of 1:1 and your code was the only one that removed it and kept remaining objects and their scale intact.  See the attached file for your reference.
How do I call the function to create the scale list after purging?
I've tried:
(setq lst '(("20:1" 20 1)
            ("10:1" 10 1)
            ("5:1" 5 1)
            ("2:1" 2 1)
            ("1:1" 1 1)
            ("1:2" 1 2)
            ("1:5" 1 5)
            ("1:10" 1 10)
            ("1:20" 1 20)
            ("1:25" 1 25)
            ("1:50" 1 50)
            ("1:75" 1 75)
            ("1:100" 1 100)
            ("1:200" 1 200)
            ("1:250" 1 250)
            ("1:400" 1 400)
            ("1:500" 1 500)
            ("1:1000" 1 1000)
            ("1:1250" 1 1250)
            ("1:2500" 1 2500)
            ("1:5000" 1 5000)
) ;_ end of setq
(SetScaleList lst)
I get the error:
error: bad argument type: lentityp nil
« Last Edit: April 24, 2024, 06:23:57 PM by 3dwannab »
