Author Topic: plotting lisp  (Read 21490 times)
ELOQUINTET
plotting lisp
« on: November 19, 2003, 12:47:25 PM »
i have this lisp for plotting all the tabs in the order they appear left to right in a drawing. it works pretty good but there's a couple things that i'd like to tweak. first off, it sometimes doesn't set the filedia and cmddia variables back to 1. the main feature i am hoping to add is the ability to do multiple sets, is this possible? thanks
dan
(Defun C:PT
     (/ PLO_LAYOUTS PLO_CNTR PLO_CNTR2 PLO_LIST PLO_LAYOUTTAB)
  (setvar"FILEDIA"0)
  (setvar"CMDDIA"0)
  (setq  PLO_LAYOUTS (vla-get-layouts
                   (vla-get-activedocument(vlax-get-acad-object)))
        PLO_CNTR 0 PLO_CNTR2 0)
  (repeat(vla-get-count PLO_LAYOUTS)
    (setq PLO_LIST (cons(setq PLO_CNTR (1+ PLO_CNTR)) PLO_LIST)))
  (vlax-for PLO_LAYOUT PLO_LAYOUTS
    (setq PLO_LIST (subst(vla-get-name PLO_LAYOUT)
                             (vla-get-taborder PLO_LAYOUT)PLO_LIST)))
  (setq PLO_LIST (reverse PLO_LIST))
  (while(/= PLO_CNTR2 (1- PLO_CNTR))
    (setq PLO_LAYOUTTAB (nth PLO_CNTR2 PLO_LIST))
    (command "-PLOT" "n" PLO_LAYOUTTAB "" "" "" "" "" "")
    (setq PLO_CNTR2 (1+ PLO_CNTR2)))
  (setvar"FILEDIA"1)
  (setvar"CMDDIA"1)
  (princ))
daron
plotting lisp
« Reply #1 on: November 19, 2003, 12:53:31 PM »
Using the code tags doesn't just make it pretty, it keeps smiley's out of your code too, so you don't end up with :P instead of :P
As far as your code problem, take out the filedia and cmddia areas and see what happens. ActiveX functions won't call up dialogs unless you specify them, so many of the setvar's aren't as necessary anymore.
ELOQUINTET
plotting lisp
« Reply #2 on: November 19, 2003, 03:37:52 PM »
ok so what about the multiple sets part? how would i go about incorporating that? that was my main intenetion of the post the variable issue just came to mind also. thanks
dan
daron
plotting lisp
« Reply #3 on: November 19, 2003, 03:44:23 PM »
Don't quote me on this. I haven't even tried it.
;;; File    : PLOTALL.LSP
;;; Purpose : Provides PLOTALL and -PLOTALL commands to plot all paper space
;;;           layouts in the current drawing, thereby working around the
;;;           "Layout of order" item in January 2003 Bug Watch.
;;; Author  : Steve Johnson for Cadalyst magazine.
;;; Notes   : Expects to find PLOTALL.DCL in search path.
;;;           Uses AutoCAD 2000+ Visual LISP functions.
;;;           Only tested on AutoCAD 2002.
;; Function: C:PLOTALL
;; Purpose : Dialogue box version of command to plot all paper space layouts
;;           in the current drawing.
;; Global  : PLOTALL-DEVICE: string containing name of plot device, e.g.
;;                           "\\\\server\\plotter" or
;;                           "plotter.pc3"
;;           PLOTALL-QTY:    number of each layout to plot
;;           PLOTALL-ORDER:  order in which to plot (string)
;;           PLOTALL-REV:    reverse order? (boolean: T = reverse)
;; Local   : dclfile:        full filename of "PlotAll.dcl" file
;;           dcl#:           DCL ID number
;;           device-list:    list of available plot devices
;;           order-list:     list of order strings
;;           device#:        index number of chosen device in device-list
;;           order#:         index number of chosen order in order-list
;;           quantity:       temporary number of each layout to plot
(defun C:PLOTALL (/ ; Functions
                   init_vars init_tiles call_ok
                    ; Variables
                   dclfile dcl# device-list order-list device# order# quantity
;; Function: init_vars
;; Purpose : Sets up variables prior to invoking dialogue box.
  (defun init_vars ()
    (if (not PLOTALL-DEVICE) (setq PLOTALL-DEVICE "None"))
    (if (not PLOTALL-QTY) (setq PLOTALL-QTY 1))
    (if (not PLOTALL-ORDER) (setq PLOTALL-ORDER "Alpha"))
    (setq
      device-list (plotall_device_list)
      order-list '("Alpha" "Numeric" "Tab")
      order# (- (length order-list) (length (member PLOTALL-ORDER order-list)))
      quantity PLOTALL-QTY
    (if (and PLOTALL-DEVICE (member PLOTALL-DEVICE device-list))
      (setq
        device#
         (- (length device-list) (length (member PLOTALL-DEVICE device-list)))
      (setq device# 0)
  ) ; End init_vars
;; Function: init_tiles
;; Purpose : Sets up dialogue box tiles prior to invoking dialogue box.
  (defun init_tiles ()
    (action_tile "accept" "(call_ok)")
    (start_list "device_list")
    (foreach one device-list
      (add_list one)
    (end_list)
    (start_list "order_list")
    (foreach one order-list
      (add_list one)
    (end_list)
    (set_tile "device_list" (itoa device#))
    (set_tile "order_list" (itoa order#))
    (set_tile "reverse" (if PLOTALL-REV "1" "0"))
    (set_tile "quantity" (itoa quantity))
  ) ; End init_tiles
;; Function: call_ok
;; Purpose : Callback function for OK button. Ensures a quantity greater than
;;           0 and a device other than "None".
  (defun call_ok ()
    (if (> (setq quantity (atoi (get_tile "quantity"))) 0)
      (if (> (setq device# (atoi (get_tile "device_list"))) 0)
          (setq
            PLOTALL-DEVICE (nth device# device-list)
            PLOTALL-ORDER (nth (atoi (get_tile "order_list")) order-list)
            PLOTALL-REV (= (get_tile "reverse") "1")
            PLOTALL-QTY quantity
          (done_dialog 1)
        (set_tile "error" "Must choose a plot device")
      (set_tile "error" "Quantity must be 1 or more")
  ) ; End call_ok
;; Start C:PLOTALL -----------------------------------------------------------
    ((not (findfile (setq dclfile "PlotAll.dcl")))
      (alert "Cannot find PlotAll.dcl")
    ((< (setq dcl# (load_dialog dclfile)) 0) ; Error
      (prompt (strcat "\nCannot load " dclfile "."))
    ((not (new_dialog "plotall_main" dcl#)) ; Error
      (prompt (strcat "\nProblem with " dclfile "."))
    (T ; No DCL problems: fire it up
      (init_vars)
      (init_tiles)
      (setq action (start_dialog))
      (unload_dialog dcl#)
      (if (= action 1)
        (plotall_layouts PLOTALL-DEVICE PLOTALL-QTY PLOTALL-ORDER PLOTALL-REV)
) ; End C:PLOTALL
;; Function: C:-PLOTALL
;; Purpose : Command line version of command to plot all paper space layouts
;; Local   : device:         temporary string containing name of plot device
;;           order:          temporary order in which to plot (string)
;;           rev:            temporary reverse order? (boolean: T = reverse)
(defun C:-PLOTALL (/ device device-list order rev quantity)
  (setq device (getstring T (strcat "\nPlot device <" PLOTALL-DEVICE ">: ")))
  (if (= device "") (setq device PLOTALL-DEVICE))
    ((= device "None")
      (prompt "\nMust specify a plot device.")
    ((not
       (member
         (strcase device)
         (mapcar 'strcase (setq device-list (plotall_device_list)))
        (if (/= one "None")
          (prompt (strcat one "\n"))
      (prompt "Must specify one of the above plot devices.\n")
      (initget "Alpha Numeric Tab")
      (setq
        order
         (getkword
           (strcat
             "\nPlot order [Alpha/Numeric/Tab] <" PLOTALL-ORDER ">: "
      (if order (setq PLOTALL-ORDER order))
      (initget "Yes No")
      (setq
        rev
         (getkword
           (strcat
             "\nReverse order [Yes/No] <" (if PLOTALL-REV "Yes" "No") ">: "
      (if rev (setq PLOTALL-REV (= rev "Yes")))
      (initget 6) ; Positive integer
      (setq
        quantity
         (getint (strcat "\nNumber of copies <" (itoa PLOTALL-QTY) ">: "))
      (if quantity (setq PLOTALL-QTY quantity))
) ; End C:-PLOTALL
;; Function: plotall_device_list
;; Purpose : Returns list of strings of all available plot devices.
;; Local   : curdwg:   current drawing object
;;           pslayout: paper space layout object
(defun plotall_device_list (/ curdwg pslayout)
  (setq
    curdwg (vla-get-ActiveDocument (vlax-get-Acad-Object))
    pslayout (vla-get-Layout (vla-get-PaperSpace curdwg))
  ; Call RefreshPlotDeviceInfo before GetPlotDeviceNames
  (vla-RefreshPlotDeviceInfo pslayout)
  (vlax-safearray->list (vlax-variant-value (vla-GetPlotDeviceNames pslayout)))
) ; End plotall_device_list
;; Function: plotall_layouts
;; Purpose : Plots all paper space layouts in current drawing to a specified
;;           plot device, in the specified quantity.
;; Params  : DEVICE:       string containing name of plot device
;;           QTY:          number of each layout to plot
;;           ORDER:        order in which to plot ("Alpha" "Numeric" "Tab")
;;           REV:          boolean: if T, reverse plot order
;;           layout-array: safearray of a single layout name string
;;           layout-list:  list of layout name strings
;;           plot:         plot object (needed to actually perform plot)
;;           errmsg:       returned object from failed plot attempt
(defun plotall_layouts (DEVICE QTY ORDER REV /
                        ; Functions
                          delnth sortlist str_num_sort tab_sort
                        ; Variables
                         curdwg layout-array layout-list plot errmsg)
;; Function: delnth
;; Purpose : Returns a list with the Nth item deleted
;; Params  : N:    index number of item to delete (0 is first item in list)
;;           LST:  list to delete from
;; Local   : #:    item counter
;;           tlst: temporary list
  (defun delnth (N LST / # tlst)
    (setq # 0)
    (while (and LST (/= # N))
      (setq
        tlst (cons (car LST) tlst)
        LST (cdr LST)
        # (1+ #)
    (reverse (append (reverse (cdr LST)) tlst))
  ) ; End delnth
;; Function: sortlist
;; Purpose : Sorts a list, allowing any function to be used for item comparison.
;; Params  : LST: list to sort
;;           FUN: name of function to apply to test for "lower": could be a
;;                built-in function (e.g. >) or a user defined function,
;;                possibly defined on the spot using lambda.
  (defun sortlist (LST FUN / size # pos high item tmplst)
    (repeat (1- (setq size (length LST)))
      (setq
        #   1             ; Position of 1st item to compare with highest item
        pos 0             ; Position of initial highest item
        high (nth 0 LST)  ; Value of initial highest item
      (while (< # size)   ; Walk through the whole list, finding the highest item
        (if (apply FUN (list high (setq item (nth # LST)))) ; Test for higher
          (setq           ; Found a higher item, so record its:
            high item     ;  value,
            pos  #        ;  position
        (setq # (1+ #))   ; Test next item
      (setq
        tmplst (cons high tmplst)  ; Stick highest item at start of temp list
        LST    (delnth pos LST)    ; Delete highest item from main list,
        size   (- size 1)          ;  and reduce size of main list
    (cons (car LST) tmplst)        ; Add last (lowest) item to start and return
  ) ; End sortlist
;; Function: str_num_sort
;; Purpose : Sorts a list of layouts into tab number order.
;; Params  : LST:    list of sublists to sort. Each sublist contains a tab
;;                   number index integer and a layout name string.
  (defun str_num_sort (LST / split_str_num str_num_compare)
;; Function: split_str_num
;; Purpose : Divides a string into 3 parts: string prefix, numeric middle and
;;           string suffix.
;; Params  : STR: string to split
;; Local   : #: loop counter/character index
;;           ch: current character
;;           slen: string length
;;           s1: string prefix
;;           s2: string containing numeric middle
;;           s3: string prefix
;; Returns : Always a list containing a string, a real and a string. If any of
;;           these elements do not exist, defaults of "", 0.0 and "" are used.
    (defun split_str_num (STR / # ch slen s1 s2 s3)
      (setq
        # 0
        slen (strlen STR)
        s1 ""
      (while (and (<= (setq # (1+ #)) slen) (not s3))
        (if (wcmatch (setq ch (substr STR # 1)) "[0123456789.]")
          (if s2
            (setq s2 (strcat s2 ch))
            (setq s2 ch)
          (if s2
            (setq s3 (substr STR # 1))
            (setq s1 (strcat s1 ch))
      (list s1 (if s2 (atof s2) 0.0) (if s3 s3 ""))
    ) ; End split_str_num
;; Function: str_num_compare
;; Purpose : Compares 2 lists. Each list contains a tab number index integer
;;           and a layout name string. The tab number is ignored and the
;;           layout name string is divided into 3 parts: string prefix,
;;           numeric middle and string suffix. The comparison is then performed
;;           on the first then second, then third items, then on the string as
;;           a whole.
;; Params  : X, Y: lists to compare
;; Local   : xlist: list of 3 parts derived from X layout name string
;;           ylist: list of 3 parts derived from Y layout name string
;; Returns : T if X < Y, else nil.
    (defun str_num_compare (X Y / xlist ylist)
      (setq
        xlist (split_str_num (cadr X))
        ylist (split_str_num (cadr Y))
      (if (= (car xlist) (car ylist))         ; if 1st are equal
        (if (= (cadr xlist) (cadr ylist))     ;  if 2nd are equal
          (if (= (caddr xlist) (caddr ylist)) ;   if 3rd are equal
            (< (cadr X) (cadr Y))             ;    then ascending on whole string
            (< (caddr xlist) (caddr ylist))   ;    else ascending on 3rd
          (< (cadr xlist) (cadr ylist))       ;    else ascending on 2nd
        (< (car xlist) (car ylist))           ;  else ascending on 1st
    ) ; End str_num_compare
;; Start str_num_sort --------------------------------------------------------
    (reverse (sortlist LST 'str_num_compare))
  ) ; End str_num_sort
;; Function: tab_sort
;; Local   : #:      index integer counter
;;           retlst: sorted list to return
  (defun tab_sort (LST / # retlst)
    (setq # 1)
    (while (< (length retlst) (length LST))
      (foreach one LST
        (if (= (car one) #)
          (setq
            retlst (cons one retlst)
            # (1+ #)
    retlst
  ) ; End tab_sort
;; Start plotall_layouts -----------------------------------------------------
  (setq
    layout-array (vlax-make-safearray vlax-vbString '(0 . 0))
  (vlax-for layout (vla-get-Layouts curdwg)
    (if (/= (vla-get-Name layout) "Model")
      (setq
        layout-list
         (cons
           (list (vla-get-TabOrder layout) (vla-get-Name layout))
           layout-list
    ((= ORDER "Numeric")
      (setq layout-list (str_num_sort layout-list))
    ((= ORDER "Tab")
      (setq layout-list (tab_sort layout-list))
  (if (not REV) ; Layout list to be reversed?
    (setq layout-list (reverse layout-list))
  (foreach layout layout-list
    (prompt
      (strcat
        "\nPlotting layout " (itoa (car layout)) ", \""
        (cadr layout) "\"...\n"
    (setq
      layout-array (vlax-safearray-fill layout-array (cdr layout))
      plot (vla-get-Plot curdwg)
    (vla-SetLayoutsToPlot plot layout-array)
    (vla-put-NumberOfCopies plot QTY)
    (setq errmsg (vl-catch-all-apply 'vla-PlotToDevice (list plot DEVICE)))
    (if (vl-catch-all-error-p errmsg)
      (prompt
        (strcat
          "\nERROR: Plot failed due to following condition:\n       "
          (vl-catch-all-error-message errmsg)
          "\n"
) ; End plotall_layouts
;;; End PLOTALL.LSP
Comes with a dialog box too.
//// File     : PlotAll.dcl
//// Author   : Steve Johnson
//// Purpose  : Dialogue box definition for PLOTALL command.
/// Turn off error checking
dcl_settings : default_dcl_settings { audit_level = 0; }
/// Widget: plotall_main
/// This is the main PLOTALL dialogue box.
plotall_main : dialog {
  label = "PlotAll.lsp - Plots all layouts in current drawing";
  : popup_list {
    key = "device_list";
    label = "Device  ";
  spacer;
  : row {
    : popup_list {
      key = "order_list";
      label = "Order    ";
    : toggle {
      key = "reverse";
      label = "Reverse";
  spacer;
  : edit_box {
    key = "quantity";
    label = "Quantity";
  spacer;
  ok_cancel;
  errtile;
/// End PlotAll.dcl
ELOQUINTET
plotting lisp
« Reply #4 on: November 19, 2003, 04:07:28 PM »
mmm doesn't seem to do what i want. i created a drawing with 2 layouts (1 and 2) then i tried to print 2 sets using the numeric function. it printed everything but it printed (2) #1 layouts then (2) #1 layouts. i want it for printing multiple coallated sets of shop and production drawings. any ideas?
dan
daron
plotting lisp
« Reply #5 on: November 19, 2003, 04:12:19 PM »
Sorry. I was told that it is supposed to plot all layouts in order. I've got a few plotting utilities I've written, but not to do that.
plotting lisp
« Reply #6 on: November 19, 2003, 05:34:59 PM »
Wouldn't this work?  (not tested)
(Defun C:PT
  (setvar "FILEDIA" 0)
  (setvar "CMDDIA" 0)
  (initget 3) ; disallow 0 or <0
  (setq nofc (getint "Enter number of sets: <1>"))
  (setq nofc (if nofc nofc 1 ))
  (while (> nofc 1)
    (setq PLO_LAYOUTS
  (vla-get-layouts
 PLO_CNTR 0
 PLO_CNTR2 0
    (repeat (vla-get-count PLO_LAYOUTS)
      (setq PLO_LIST (cons (setq PLO_CNTR (1+ PLO_CNTR)) PLO_LIST))
      (setq PLO_LIST (subst (vla-get-name PLO_LAYOUT)
   PLO_LIST
    (while (/= PLO_CNTR2 (1- PLO_CNTR))
    (setq nofc (1- nofc))
  (setvar "FILEDIA" 1)
  (setvar "CMDDIA" 1)
ELOQUINTET
plotting lisp
« Reply #7 on: November 20, 2003, 08:46:48 AM »
hey cab just tried, didn't work  :(
it just printed one set. thanks for trying
dan
plotting lisp
« Reply #8 on: November 20, 2003, 07:35:51 PM »
dan
lets try again.
changed some of your code.
(Defun C:PT
   (/ PLO_LAYOUTS PLO_CNTR PLO_LIST PLO_LAYOUTTAB)
  (setvar "CMDDIA" 0)
  (initget 6) ; disallow 0 or <0
  (setq nofs (getint "Enter number of sets: <1>"))
  (setq nofs (if (or nofs (= nofs 0)) nofs  1))
  (setq PLO_LAYOUTS
(vla-get-layouts
    (setq plo_list (cons (vla-get-name PLO_LAYOUT) plo_list))
  (while (>= nofs 1)
    (setq plo_cntr 0)
    (repeat (1- (length plo_list)) ; plot all but MODEL
      (setq PLO_LAYOUTTAB (nth PLO_CNTR PLO_LIST))
    (prompt "\nPlot Set Complete")
    (setq nofs (1- nofs))
  (setvar "CMDDIA" 1)
SMadsen
plotting lisp
« Reply #9 on: November 21, 2003, 06:09:27 AM »
Not that I want to encourage the "gimme" mentality but if anyone can use it in their own effort to write code, below is an ActiveX approach to the problem. It's just a minimum solution that can be expanded to give more control.
(defun C:PLOTSETS (/ lst llst numCopies name acapp doc layouts plotobj)
  (setq acapp   (vlax-get-acad-object)
        doc     (vla-get-activeDocument acapp)
        layouts (vla-get-layouts doc)
        plotobj (vla-get-plot doc))
  (vlax-for layout layouts
    (if (/= (setq name (vla-get-name layout)) "Model")
      (setq lst (cons (list (vla-get-tabOrder layout)
                            name
                            (vla-get-configName layout)
                      ) lst))))
  (setq lst  (vl-sort lst (function (lambda (a b) (< (car a) (car b)))))
        llst (mapcar 'cadr lst))
  (cond ((> (setq numCopies (getint "\nNumber of copies: ")) 0)
         (vla-setLayoutsToPlot
           plotobj
           (vlax-make-variant
               (vlax-make-safearray vlax-vbString (cons 0 (1- (length llst))))
               llst)))
         (vla-startBatchMode plotobj (length llst))
         (vla-put-numberOfCopies plotobj numCopies)
         (vla-plotToDevice plotobj)
         (vla-put-numberOfCopies plotobj 1))
        (T (princ "\nNo plots specified"))
  (mapcar 'vlax-release-object (list plotobj layouts doc acapp))
SMadsen
plotting lisp
« Reply #10 on: November 21, 2003, 06:13:35 AM »
Oops, violation of the Daron Act spotted! Throw in a (vl-load-com) somewhere in the beginning of C:PLOTSETS.
Sorry, Daron!
ELOQUINTET
plotting lisp
« Reply #11 on: November 21, 2003, 08:41:48 AM »
cab your last post works great. just to let you know madsen i wanted the sets to be coallated. much thanks
dan
SMadsen
plotting lisp
« Reply #12 on: November 21, 2003, 08:58:46 AM »
Quote from: eloquintet
Don't know what that word means (foreigner here) but just to let you know, if it means arranged like 1-2-3, 1-2-3 etc., it would be very very easily modified with a minimum of effort.
ELOQUINTET
plotting lisp
« Reply #13 on: November 21, 2003, 09:10:48 AM »
yes that's what it means 1-2-3 1-2-3 but cabs lisp does just that so i'm fine just wanted to let you know why yours didn't work for me. thanks
dan
plotting lisp
« Reply #14 on: November 21, 2003, 09:21:17 AM »
I think I can find a use for it. :D
thanks Mr. Madsen.
