Author Topic: (Challenge) Number of Different Positions  (Read 2936 times)
« on: July 16, 2009, 09:38:18 AM »
Define a procedure that takes two lists of symbols, equal in length, and determines the number of positions at which they contain different values in 0(n) [a single pass].
For instance, given the lists (a b c e f g) and (a b d e g h), the procedure should return 3.
Re: (Challenge) Number of Different Positions
« Reply #1 on: July 16, 2009, 09:47:29 AM »
Coded quick and blind:
(defun foo ( a b )
    (apply '+ (mapcar '(lambda (i j) (if (eq i j) 1 0)) a b))
Maybe it works, maybe it doesn't.
« Reply #2 on: July 16, 2009, 09:50:07 AM »
Yep, she works. Good job.
« Reply #3 on: July 16, 2009, 09:52:56 AM »
(defun foo ( a b )
Do you think you could get it a little more concise?
« Reply #4 on: July 16, 2009, 09:56:15 AM »
*lol* yeah i was kinda taken aback as well ...but anyways, thats up to [you]. So get to work!!
« Reply #5 on: July 16, 2009, 09:57:43 AM »
Actually, now that I look at it, it doesn't work as requested ... but it does work exactly opposite as requested ;)
You asked for the number of different positions, the code returns the number of equal positions.
But no harm, no foul .. flip the 1 0 bits in the if evaluation like so:
(defun foo ( a b )
    (apply '+ (mapcar '(lambda (i j) (if (eq i j) 0 1)) a b))
« Reply #6 on: July 16, 2009, 09:58:31 AM »
busy, headache, apathy, sorry
« Reply #7 on: July 16, 2009, 10:00:32 AM »
Whoa?! Good spot Keith.
VovKa
  • Ukraine
« Reply #8 on: July 16, 2009, 11:18:58 AM »
(defun test (lst1 lst2)
  (if (and lst1 lst2)
    (+ (if (equal (car lst1) (car lst2))
0
1
       (test (cdr lst1) (cdr lst2))
    0
« Reply #9 on: July 16, 2009, 11:25:20 AM »
(defun foo ( a b )
    (length (vl-remove nil (mapcar '= a b)))
« Reply #10 on: July 16, 2009, 11:37:32 AM »
(defun foo ( a b )
interesting solution CAB, but it also is opposite of the challenge .. to return the number that is different
Either of the next edits would meet the requirement
(defun foo ( a b )
    (length (vl-remove nil (mapcar '/= a b)))
or
(defun foo ( a b )
    (length (vl-remove T (mapcar '= a b)))
incidently, I am not providing a solution because quite honestly I can't best what is already provided as viable solutions
« Reply #11 on: July 16, 2009, 11:45:34 AM »
I never was one for reading the instructions.  8-)
« Reply #12 on: July 16, 2009, 11:46:08 AM »
Ah, so what?! Mine was about as straight forward as you can get. Its just for fun anyways. Everyone's initial reaction will have a different spin and each offers a new learning experience. Post what you got.
Mine:
( (lambda ( a e / i )
    (setq i 0)
    (mapcar
      '(lambda ( o u )
         (if (not (eq o u))
           (setq i (1+ i))))
      a e)
    i)
 '(a b c e f g)
 '(a b d e g h))
« Reply #13 on: July 16, 2009, 12:03:59 PM »
Working on my recursive skills.
(defun foo ( a b c )
    (if (car a)
        (if (equal (car a) (car b))
            (foo (cdr a) (cdr b) c)
            (foo (cdr a) (cdr b) (1+ c))
        c
Command: (foo '(1 2 3 4 5 6) '(1 2 5 6 3 6) 0)
3
« Reply #14 on: July 16, 2009, 01:44:14 PM »
I'm not too good with recursive stuff, but maybe:
(defun foo (a b)
  (apply '+
    (if a
      (list
        (if (eq (car a) (car b)) 0 1)
          (foo (cdr a) (cdr b))))))
