Author Topic: (DCL) How do you set a value in a popup_list?  (Read 16025 times)
« on: November 19, 2003, 12:22:28 PM »
I want to set the value of the popup_list to something other than "0" depending on the users last selection. I've tried the following but it locks up ACAD when I run it.
(start_list "selections")
(mapcar 'add_list lst)
(end_list)
 (if (setq pos (vl-position mst-last-sel lst))
   (set_tile "selections" (itoa pos))
   (set_tile "selections" "0"); default
mst-last-sel = string
lst = list of strings
: popup_list {
label = "Select Override:";
allow_accept = true;
is_tab_stop = true;
key = "selections";
value = ""; // <-- here
edit_width = 30;
ELOQUINTET
« Reply #1 on: November 19, 2003, 12:39:37 PM »
hmmm that looks familiar  :wink:
dan
Columbia
« Reply #2 on: November 19, 2003, 01:11:13 PM »
When you run your program code, does AutoCAD show the dialog and then refuse to let it go?  Or does it not get that far and break on trying to stuff the list?
« Reply #3 on: November 19, 2003, 01:15:41 PM »
Yep.
SMadsen
« Reply #4 on: November 19, 2003, 01:56:28 PM »
Just made a short test of it. This works ok:
(setq lst '("aaa" "bbb" "ccc" "ddd" "eee"))
(cond ((new_dialog "poptest" dcl_id)
       (end_list)
         (set_tile "selections" "0")  ; default
       (action_tile "selections"
           "(setq mst-last-sel (nth (atoi $value) lst))")
       (start_dialog)
Columbia
« Reply #5 on: November 19, 2003, 02:11:12 PM »
Mark,
It would be a good bet that you forgot to use (start_dialog).  I do it all the time and it locks AutoCAD up tighter than drum.
Craig
« Reply #6 on: November 19, 2003, 02:21:20 PM »
Thats what I was gonna say.
« Reply #7 on: November 19, 2003, 02:29:41 PM »
I don't know! This is what I'm using, am I missing something?
(defun DimTextOverRide (lst obj / *error* dcl_id str sel cur output)
  ;; error function
  (defun *error* (msg)
    (if (not
          (member
            msg
            '("console break" "Function cancelled" "quit / exit abort")
      ) ; if
    ) ; end error funtion
  ;load dialog
  (setq dcl_id (load_dialog "dcl_popup_list.dcl"))
  (if (not (new_dialog "dcl_popup_list" dcl_id))
    (exit)
    ) ;if
  (setq str (vlax-get-property obj 'TextOverride))
  (set_tile "curt" str)
  (end_list)
;  (if (setq pos (vl-position mst-last-sel lst))
;    (set_tile "selections" (itoa pos))
;    (set_tile "selections" "0"))
  (action_tile
    "accept"
    (strcat
      "(progn
         (setq sel (atoi (get_tile \"selections\")))"
         "(setq cur (get_tile \"curt\"))"
         "(done_dialog)
      ) ;strcat
    ) ;action tile
    (action_tile "cancel" "(done_dialog)(exit)")
    ;action_tile
    (start_dialog)
    (unload_dialog dcl_id)
    (if (/= cur str); edit box changed, so ignore the list box
      (setq output cur)
      (setq output (nth sel lst))
    output
Craig
« Reply #8 on: November 19, 2003, 02:43:19 PM »
Is your dialog box coming up at all?
If not, is this the correct name for the .dcl file and is the dcl_id correct?
DParcon
« Reply #9 on: November 19, 2003, 02:43:24 PM »
Try this:
 popup : dialog  {
   label  = "SAMPLE POP-UP LIST" ;
     : row {
         : column {
              : popup_list {
                  label       = "Flange Ratings" ;
                  key         = "rating" ;
                  edit_width  = 12 ;
                  list        = "" ;
     ok_cancel ;
  ;;;Save above dcl as popup.dcl
   (defun C:POPUP ()
    (setq rlist '("150" "300" "400" "600" "900" "1200")
          dcl_id (load_dialog "popup.dcl")
    (if (not (new_dialog "popup" dcl_id))
      (exit)
    (start_list "rating")
    (mapcar 'add_list rlist)
    (end_list)
    (if #val
      (set_tile "rating" (itoa (setq val #val)))
      (set_tile "rating" (itoa (setq val 0)))
    );if
    (action_tile "rating" "(setq val (atoi $value))")
    (action_tile "accept" "(setq #val val)(done_dialog 1)")
    (action_tile "cancel" "(done_dialog 0)")
    (start_dialog)
Craig
« Reply #10 on: November 19, 2003, 02:49:11 PM »
Mark, post your DCL file
SMadsen
« Reply #11 on: November 19, 2003, 03:10:41 PM »
Mark,
Do you normally put everything into the OK and Cancel buttons? Why force an error in the Cancel button with EXIT?
See if this runs (probably not the behavior you want - the popup sets the edit_box - but you can just change that):
(defun DimTextOverRide (lst obj / *error* dcl_id str sel cur output action)
  ;; error function
    (if (not
          (member
            msg
    ) ;_ if
  ) ;_ end error function
  (defun setValue (val alist / ret)
    (setq ret (nth (atoi val) alist))
    (set_tile "curt" (strcat "<> " ret))
    ret
  ;; load dialog
    (exit)
  ) ;_ if
  (end_list)
  (action_tile "selections" "(setq mst-last-sel (setValue $value lst) cur (get_tile \"curt\"))")
  (action_tile "curt" "(setq cur $value)")
;;;    (strcat
;;;      "(progn
;;;         (setq sel (atoi (get_tile \"selections\")))"
;;;      "(setq cur (get_tile \"curt\"))"
;;;      "(done_dialog)
;;;    )                                   ;strcat
;;;  )                                     ;action tile
;;;  (action_tile "cancel" "(done_dialog)(exit)") ;action_tile
  (setq action (start_dialog))
  (cond ((= action 1)
         (if (/= cur str)               ; edit box changed, so ignore the list box
           (setq output cur)
  output
SMadsen
« Reply #12 on: November 19, 2003, 03:19:06 PM »
Action_tile for "selections" changed to this since last posting (makes a bit more sense):
Columbia
« Reply #13 on: November 19, 2003, 03:20:05 PM »
Mark,
here's a quick edit of your file...
Please notice a couple of quick things
1.) I pulled the strcat out of your action_tile call because you don't really need it.
2.) I'm also pulled the (exit) call out of your "cancel" action_tile call, because I'm using the optional integer call on done_dialog.  And that way I'm getting the same results without crashing out of the routine.
(defun DimTextOverRide (lst obj / *error* dcl_id str sel cur output start)
  ;; error function
    (if (not (member msg '("console break" "Function cancelled" "quit / exit abort")))
    ) ; if
  ;load dialog
  (if (not (new_dialog "dcl_popup_list" dcl_id)) (exit)) ;if
  (end_list)
  (action_tile "selections" "(setq sel $value)")
    "(setq sel (atoi (get_tile \"selections\")) cur (get_tile \"curt\")) (done_dialog 1)"
  (action_tile "cancel" "(done_dialog 2)")
  (setq start (start_dialog))
    ( (= start 1)
        (setq output cur)
  output
Darn it All!!!!!  I was beat again by too fast typing coders!!!! AGGHHHH!!!
However, as you can see from above I agree with SM whole heartedly. :D
« Reply #14 on: November 19, 2003, 03:22:58 PM »
Well, that's how I've always done it. I've never taken the time to learn it properly.
Works very well Stig, thanks.
- DParcon
thanks for the insight.
