Author Topic: Whats wrong with this Lisp?  (Read 10598 times)
efernal
Re: Whats wrong with this Lisp?
« Reply #30 on: March 24, 2010, 01:33:41 PM »
;;;   HI, I have some routines for this
;;;   See in
;;;   http://www.gr-acad.com.br/Pacote/ipontos.html
;;;   http://www.gr-acad.com.br/Pacote/azimute/azimute.html
;;;   and more in
;;;   http://www.gr-acad.com.br/pac.htm
;;;   e.fernal
;;;   Here is my version for your need...
   please, adjust
   (LOAD_DIALOG
          (STRCAT gr-pack-usb-char-drive
             ":\\Gr-Pack-Usb\\Dlg\\DCL0110.dcl"
   according your paths...
and here is the necessary dcl file contents...
efpac0110:dialog{label="E.Fernal Software";key="efernal";width=54;fixed_width=true;initial_focus="numero";
:spacer{height=0.5;}
:text{label="Dados para pontos";alignment=centered;fixed_width_font=true;height=1.5;fixed_height=true;}
:column{alignment=centered;fixed_width=true;fixed_height=true;
:edit_box{label="Número inicial";key="numero";edit_width=12;edit_limit=6;}
:edit_box{label="Altura da fonte";key="hfonte";edit_width=12;edit_limit=5;}}
:row{alignment=centered;fixed_width=true;fixed_height=true;
:button{label="Como &usar";key="help";mnemonic="u";width=15;height=2.5;fixed_width=true;fixed_height=true;alignment=top;}
:button{label="&Cancelar";key="cancel";is_cancel=true;mnemonic="C";width=15;height=2.5;
:button{label="&Prosseguir";key="accept";mnemonic="P";width=15;height=2.5;
fixed_width=true;fixed_height=true;alignment=top;}}}
(DEFUN c:pts (/   pt arq sn cn dh   w@
         ;; setvars
         attreq attdia
         ;; parâmetros necessários
         numero hfonte
         ;; funçoes locais...
         exec ajuda verif make_block efernal_acet)
  (DEFUN efernal_acet (s)
    (IF   ACET-UI-MESSAGE
      (ACET-UI-MESSAGE s "E.Fernal Software")
      (ALERT s)
  (DEFUN exec (/ arq file lista p1)
    (SETQ arq (OPEN (STRCAT (GETVAR "TempPrefix") "EFPAC0110.TXT") "w"))
    (WHILE (SETQ
        p1   (GETPOINT
        (STRCAT "\r-> Clique no ponto [ " (ITOA numero) " ] : ")
      (ENTMAKE (LIST (CONS 0 "POINT") (CONS 10 p1)))
      (ENTMAKE (LIST (CONS 0 "TEXT")
           (CONS 1 (ITOA numero))
           (CONS 10
            (LIST (+ (CAR p1) (* 2.0 hfonte))
             (- (CADR p1) (* 2.0 hfonte))
             (CADDR p1)
           (CONS 40 hfonte)
           (CONS 50 0.0)
           (CONS 71 0)
           (CONS 72 0)
           (CONS 73 0)
      (SETQ numero (1+ numero))
      (IF (AND arq (= (TYPE arq) 'file))
   (PROGN (PRINC "(" arq)
          (PRINC (CHR 34) arq)
          (PRINC numero arq)
          (PRINC (CHR 32) arq)
          (PRINC (CAR p1) arq)
          (PRINC (CADR p1) arq)
          (PRINC (CADDR p1) arq)
          (PRINC ")\n" arq)
   nil
      (CLOSE arq)
    (SETQ arq nil)
    (IF   (SETQ
     arq (FINDFILE (STRCAT (GETVAR "TempPrefix") "EFPAC0110.TXT"))
      (IF (SETQ   p1
       (GETPOINT "\n-> Ponto de inserção da tabela descritiva : ")
   (IF (SETQ file (OPEN arq "r"))
     (PROGN (IF (NULL (TBLSEARCH "BLOCK" "EFPAC0110"))
         (make_block)
       (SETQ attreq (GETVAR "ATTREQ")
             attdia (GETVAR "ATTDIA")
       (SETVAR "ATTREQ" 1)
       (SETVAR "ATTDIA" 0)
       (COMMAND "._-INSERT" "EFPAC0110" "_NON"
           p1         hfonte     hfonte
           0.0         "PT. Número"
           "Leste"     "Norte"     "Cota"
       (SETQ p1
         (LIST (CAR p1) (- (CAR p1) (* 2.0 hfonte)) (CADDR p1))
       (WHILE   (SETQ linha (READ-LINE file))
         (SETQ lista (READ linha))
         (IF (AND (= (TYPE lista) 'LIST) (= (LENGTH lista) 4))
           (PROGN (COMMAND "._-INSERT"
                 "EFPAC0110"
                 "_NON"
                 p1
                 hfonte
                 hfonte
                 0.0
                 (CAR lista)
                 (CADR lista)
                 (CADDR lista)
                 (CADDDR lista)
             (SETQ p1 (LIST (CAR p1)
                  (CADDR p1)
           nil
       (CLOSE file)
       (SETVAR "ATTREQ" attreq)
       (SETVAR "ATTDIA" attdia)
     (efernal_acet
       (STRCAT
         "Erro:\n\n\t"
         "Não foi possível abrir o arquivo para leitura!\t\n\n"
   (PRINC "\n-> Ponto de inserção não foi fornecido...")
      (efernal_acet
   (STRCAT   "Erro:\n\n\t"
      "Não foi possível encontrar o arquivo\t\n\t"
      "com os dados dos pontos coletados...\t\n\n"
  (DEFUN verif ()
    (IF   (AND (SETQ numero (GET_TILE "numero"))
        (NUMBERP (READ numero))
        (= (TYPE (READ numero)) 'int)
        (> (ATOI numero) 0)
        (SETQ hfonte (GET_TILE "hfonte"))
        (NUMBERP (READ hfonte))
        (> (ATOF hfonte) 0.0)
      (PROGN (SETQ numero (ATOI numero)
         hfonte (ATOF hfonte)
        (DONE_DIALOG 1)
      (efernal_acet
   (STRCAT
     "Erro:\n\n\t"
     "Verifique os campos\n\t"
     "\"Número inicial\" e \"Altura da fonte\".\t\n\t"
     "O número deve ser um número inteiro e\t\n\t"
     "maior que zero e a altura da fonte deve\t\n\t"
     "ser um número, inteiro ou real, maior que\t\n\t"
     "zero.\n\n\tTente novamente...\n\n"
  (DEFUN make_block ()
      (PROGN
   (IF (NULL (TBLSEARCH "STYLE" "Verdana"))
     (ENTMAKE '((0 . "STYLE")
           (100 . "AcDbSymbolTableRecord")
           (100 . "AcDbTextStyleTableRecord")
           (2 . "Verdana")
           (70 . 0)
           (40 . 0.0)
           (41 . 1.0)
           (50 . 0.0)
           (71 . 0)
           (42 . 1.0)
           (3 . "verdana.TTF")
           (4 . "")
   (ENTMAKE
     '((0 . "BLOCK") (2 . "EFPAC0110") (70 . 2) (10 0.0 0.0 0.0))
   (ENTMAKE '((0 . "LWPOLYLINE")
         (100 . "AcDbEntity")
         (67 . 0)
         (8 . "0")
         (100 . "AcDbPolyline")
         (90 . 4)
         (70 . 1)
         (43 . 0.0)
         (38 . 0.0)
         (39 . 0.0)
         (10 40.0 -2.0)
         (40 . 0.0)
         (41 . 0.0)
         (42 . 0.0)
         (91 . 0)
         (10 0.0 -2.0)
         (40 . 0.0)
         (41 . 0.0)
         (42 . 0.0)
         (91 . 0)
         (10 0.0 0.0)
         (40 . 0.0)
         (41 . 0.0)
         (42 . 0.0)
         (91 . 0)
         (10 40.0 0.0)
         (40 . 0.0)
         (41 . 0.0)
         (42 . 0.0)
         (91 . 0)
         (210 0.0 0.0 1.0)
   (ENTMAKE '((0 . "LINE")
         (67 . 0)
         (8 . "0")
         (100 . "AcDbLine")
         (10 10.0 0.0 0.0)
         (11 10.0 -2.0 0.0)
         (210 0.0 0.0 1.0)
         (67 . 0)
         (8 . "0")
         (100 . "AcDbLine")
         (10 20.0 0.0 0.0)
         (11 20.0 -2.0 0.0)
         (210 0.0 0.0 1.0)
         (67 . 0)
         (8 . "0")
         (100 . "AcDbLine")
         (10 30.0 0.0 0.0)
         (11 30.0 -2.0 0.0)
         (210 0.0 0.0 1.0)
   (ENTMAKE '((0 . "ATTDEF")
         (67 . 0)
         (8 . "0")
         (100 . "AcDbText")
         (10 1.0 -1.5 0.0)
         (40 . 1.0)
         (1 . "")
         (50 . 0.0)
         (41 . 1.0)
         (51 . 0.0)
         (7 . "Verdana")
         (71 . 0)
         (72 . 0)
         (11 0.0 0.0 0.0)
         (210 0.0 0.0 1.0)
         (100 . "AcDbAttributeDefinition")
         (280 . 0)
         (3 . "Número do ponto")
         (2 . "1")
         (70 . 0)
         (73 . 0)
         (74 . 0)
         (280 . 0)
         (67 . 0)
         (8 . "0")
         (100 . "AcDbText")
         (10 11.0 -1.5 0.0)
         (40 . 1.0)
         (1 . "")
         (50 . 0.0)
         (41 . 1.0)
         (51 . 0.0)
         (7 . "Verdana")
         (71 . 0)
         (72 . 0)
         (11 0.0 0.0 0.0)
         (210 0.0 0.0 1.0)
         (280 . 0)
         (3 . "Coordenada X")
         (2 . "2")
         (70 . 0)
         (73 . 0)
         (74 . 0)
         (280 . 0)
         (67 . 0)
         (8 . "0")
         (100 . "AcDbText")
         (10 21.0 -1.5 0.0)
         (40 . 1.0)
         (1 . "")
         (50 . 0.0)
         (41 . 1.0)
         (51 . 0.0)
         (7 . "Verdana")
         (71 . 0)
         (72 . 0)
         (11 0.0 0.0 0.0)
         (210 0.0 0.0 1.0)
         (280 . 0)
         (3 . "Coordenada Y")
         (2 . "3")
         (70 . 0)
         (73 . 0)
         (74 . 0)
         (280 . 0)
         (67 . 0)
         (8 . "0")
         (100 . "AcDbText")
         (10 31.0 -1.5 0.0)
         (40 . 1.0)
         (1 . "")
         (50 . 0.0)
         (41 . 1.0)
         (51 . 0.0)
         (7 . "Verdana")
         (71 . 0)
         (72 . 0)
         (11 0.0 0.0 0.0)
         (210 0.0 0.0 1.0)
         (280 . 0)
         (3 . "Coordenada Z")
         (2 . "4")
         (70 . 0)
         (73 . 0)
         (74 . 0)
         (280 . 0)
   (ENTMAKE '((0 . "ENDBLK")))
      nil
  (DEFUN ajuda ()
    (efernal_acet
      (STRCAT "Como usar:\n\n\t"
         "Esta rotina permite inserir dados em uma\t\n\t"
         "série de pontos clicados e, ao fim, gerar\t\n\t"
         "uma tabela descritiva destes pontos.\t\n\n"
  (IF (> (SETQ dh (LOAD_DIALOG
    0
    (IF   (NEW_DIALOG "efpac0110" dh)
      (PROGN (ACTION_TILE "accept" "(Verif)")
        (ACTION_TILE "cancel" "(DONE_DIALOG 0)")
        (ACTION_TILE "help" "(Ajuda)")
        (SETQ w@ (START_DIALOG))
        (UNLOAD_DIALOG dh)
        (COND ((= w@ 0) (PRINC "\n-> Cancelado..."))
         ((= w@ 1) (exec))
      nil
    (efernal_acet
         "Não foi possível carregar o arquivo DCL!\t\n\n"
  (PRINC)
e.fernal
efernal
« Reply #31 on: March 24, 2010, 01:39:01 PM »
PLEASE, CORRECT
                  (CADDR p1)
TO
                  (CADDR p1)
e.fernal
e.fernal
efernal
« Reply #32 on: March 24, 2010, 01:42:49 PM »
ooops, not extensively tested...
correct
          (PRINC numero arq)
          (PRINC ")\n" arq)
   nil
to
          (PRINC numero arq)
          (PRINC ")\n" arq)
   nil
and sorry for not a king's english...
e.fernal
e.fernal
HasanCAD
« Reply #33 on: March 24, 2010, 08:49:02 PM »
efernal
Is there an english version of this website?
efernal
« Reply #34 on: March 24, 2010, 09:39:10 PM »
not yet...
will try to translate something...
e.fernal
e.fernal
HasanCAD
« Reply #35 on: March 25, 2010, 02:38:38 AM »
not yet...
e.fernal
I think that It will better to start with the lisp name.
PS the lisp not working?
efernal
« Reply #36 on: March 25, 2010, 07:23:18 AM »
try it by yourself...
type POINTS to run...
e.fernal
e.fernal
