Author Topic: mapcar - remove z from points - lambda?  (Read 3615 times)
curmudgeon
« on: July 08, 2009, 09:30:59 AM »
I want to make a routine to use 3 point input to create arcs and/or lwpolys. I have
(setq c (getpoint (setq b (getpoint (setq a (getpoint "\n Pick beginning point: ")) "\n Pick point on arc :" )
   ) "\n Pick ar endpoint: " ))
to get my points, and
(list a b c)
gives me
((-300.904 670.919 0.0) (-325.601 846.356 0.0) (-473.783 879.25 0.0))
as an example.
I am wanting to strip out the z component, and I think I am close with
(mapcar  '(lambda (x) (list (car x)(cadar x))  (list a b c)))
but I get errors.
help?
Never express yourself more clearly than you are able to think.
ElpanovEvgeniy
  • Moscow (Russia)
Re: mapcar - remove z from points - lambda?
« Reply #1 on: July 08, 2009, 09:35:03 AM »
(mapcar  '(lambda (x) (list (car x)(cadr x)))  (list a b c))
curmudgeon
« Reply #2 on: July 08, 2009, 09:38:51 AM »
YES !
many thanks.
roy
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: July 08, 2009, 09:40:46 AM »
variant 2
(mapcar 'list (mapcar 'car l) (mapcar 'cadr l))
gile
  • Marseille, France
« Reply #4 on: July 08, 2009, 09:44:23 AM »
First they're 2 mistakes in this expression cadar instead of cadr and a misplaced parent.
Should have been:
(mapcar  '(lambda (x) (list (car x) (cadr x)))  (list a b c))
But this expression will return a 2d points list but never change a, b, c values
If you want to change the variables values you can write:
with mapcar and 2lists
(mapcar
  '(lambda (v x) (set v (list (car x) (cadr x))))
  '(a b c)
  (list a b c)
with mapcar and a single list
(mapcar
  '(lambda (x / val)
     (setq val (eval x))
     (set x (list (car val) (cadr val)))
  '(a b c)
with foreach
(foreach x '(a b c)
  ((lambda (val)
    (eval x)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: July 08, 2009, 09:47:49 AM »
variant 3
(mapcar '(lambda (x) (mapcar '+ x '(0 0))) l)
variant 4
(mapcar '(lambda (x) (reverse (cdr (reverse x)))) l)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: July 08, 2009, 09:51:13 AM »
variant 5
(apply 'mapcar (cons 'list (reverse (cdr (reverse (apply 'mapcar (cons 'list l)))))))
curmudgeon
« Reply #7 on: July 08, 2009, 10:03:49 AM »
when you say things like
First they're 2 mistakes in this expression ..
you have my full attention.
but you had that anyway.
the cadar was, I believe, a typographical error introduced while I was trying different ways to get new errors.
 :-D
again, thanks.
I will play with each of the variants to try to comprehend ( get my head around ) the why of it all.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: July 08, 2009, 10:06:40 AM »
variant recursion...
(defun fun (l)
 (if l
  (cons (list (caar l) (cadar l)) (fun (cdr l)))
 ) ;_  if
) ;_  defun
(fun l) =>> ((-300.904 670.919) (-325.601 846.356) (-473.783 879.25))
