Author Topic: lisp not loading at startup  (Read 5782 times)
andrew_nao
« on: July 07, 2009, 04:12:16 PM »
hello experts
would anyone know why this code wouldnt work at startup?
or maybe have a better way to explode all mtext in a dwg  upon opening.
this is placed in my acaddoc.lsp it shows as it being loaded but doesnt do what it supposed to, which is explode all mtext when it loads
(defun s::startup ()
(if ss (ssget "x" '((0 . "mtext")))
(setvar "qaflags" 1)
(command ".explode" "p" "")
(setvar "qaflags" 0)
thanks for any and all help
Re: lisp not loading at startup
« Reply #1 on: July 07, 2009, 04:16:49 PM »
Give this a try:
(defun c:kaboomkaboom? (/ ss)
  (if (setq ss (ssget "x" '((0 . "mtext"))))
    (progn (setvar "qaflags" 1) (command ".explode" ss "") (setvar "qaflags" 0))
;;Need to call the lisp
(c:kaboomkaboom?)
« Reply #2 on: July 07, 2009, 04:18:09 PM »
Quote from: andrew_nao link=topic=29400.msg349538#msg349538 date=1246997536
[code
[/code]
Could be you missed (Setq...
andrew_nao
« Reply #3 on: July 07, 2009, 04:28:17 PM »
@ ron, it doesnt work that way either i tried that and was suggested to put it in s::startup
@ lee no setq shouldnt be needed. it works when loaded manually
so the there is nothing wrong with the code. it just wont load at startup
« Reply #4 on: July 07, 2009, 04:31:18 PM »
Of course if loads, as the ' if ' statement is a valid one, but the code won't do what you think it should be.  If you run the code without a global variable ' ss ' then the code will try and explode the previous selection set, but if ' ss ' is defined, it will only select all mtext entities, then end the code.  Lee makes a good point.
« Reply #5 on: July 07, 2009, 04:49:47 PM »
Works fine here?  :?
« Reply #6 on: July 08, 2009, 08:30:34 AM »
I'm with Tim.
  (if ss
The code does this:
Check for variable ss
If ss exist get a selection set of ALL mtext in the drawing & exit
if ss is nil then explode the Previous Object(s)
The problem with Ron's version is that ssget ALL mtext in the drawing & then execute a COMMAND witch
I think will not work unless you feed it mtext in the current space.
Off to test this...  8-)
« Reply #7 on: July 08, 2009, 08:34:51 AM »
In my test the explode does work for mtext in the current space & ignores mtext not in current space.
Tested in ACAD2000
andrew_nao
« Reply #8 on: July 08, 2009, 08:56:16 AM »
ok so even if i still change it to what lee suggested, i still cant get this to execute when a dwg is opened.
« Reply #9 on: July 08, 2009, 08:59:58 AM »
what file are you putting the code in?
« Reply #10 on: July 08, 2009, 12:31:13 PM »
Picky picky  :-P
(defun c:kaboomkaboom? (/ ss n)
  (setq n -1)
  (if (setq ss (ssget "_x" '((0 . "MTEXT"))))
    (setq n -1)
    (while (setq e (ssname ss (setq n (1+ n))))
      (vl-catch-all-apply 'vla-explode (list (vlax-ename->vla-object e)))
(c:kaboomkaboom?)
Apparently vla-explode does not work with MTEXT.....I give up  :-D
« Last Edit: July 08, 2009, 12:34:30 PM by ronjonp »
« Reply #11 on: July 08, 2009, 01:43:55 PM »
Yeah, its pretty annoying  ;-)
Crank
« Reply #12 on: July 09, 2009, 06:21:32 AM »
With every new release the behaviour of existing commands may change. So when certain commands (for example EXPLODE) are issued in the Lisp routine, they may not behave as in previous version.  The workaround is to add (initcommandversion 2) before the command is called. You can try this:
(if (ssget "X" '((0 . "MTEXT")))
; (setvar "qaflags" 1)
[color=red](initcommandversion 2)[/color]
(command "._explode" "P" "")
; (setvar "qaflags" 0)
BTW... I wonder why you are turning off the grips? If you start a new drawing it seems to me that nothing is selected...
« Reply #13 on: July 09, 2009, 08:52:50 AM »
Crank,
What version of ACAD was initcommandversion introduced?
« Reply #14 on: July 09, 2009, 09:01:57 AM »
Crank,
I believe it was introduced in AutoCAD 2009
