Author Topic: deleting files via lisp  (Read 12787 times)
vinnyg
« on: November 19, 2003, 10:09:24 AM »
Is it possible to delete a file from any directory using lisp?
If so, how can this be accomplished?
I'm new at lisp, so any info regarding a procedure like this would
be helpful!
Thanks :roll:
Craig
« Reply #1 on: November 19, 2003, 10:16:59 AM »
Yep, you sure can
(vl-file-delete filename)
There will be many more post coming soon and I would really love to start something for you but I am in the middle of a project of my own so just hang in there.
« Reply #2 on: November 19, 2003, 10:30:11 AM »
How about this
(if (setq fn (getfiled "Select File To Delete" "" "" 8))
    (if (vl-file-delete fn)
      (alert (strcat fn " Deleted..."))
Craig
« Reply #3 on: November 19, 2003, 11:12:54 AM »
Vinny,
What version of Autocad are you running? The routine Mark posted will only run in 2000+.
Craig
« Reply #4 on: November 19, 2003, 11:24:10 AM »
Mark, if this runs on its own merit when pasting it on the command line, why in some situations you have to have (vl-load-com) at the start of the program to make it work :?:
« Reply #5 on: November 19, 2003, 11:32:42 AM »
If you have loaded a program that has (vl-load-com) in it, that will work for the whole ACAD session.
Looks like I'm in violation of the Daron Act.
let me go edit that post real quick before Daron see's it
Craig
« Reply #6 on: November 19, 2003, 11:36:23 AM »
So what you're telling me is I could possibly have Autocad load the (vl-load-com) automatically at the start of a new session
« Reply #7 on: November 19, 2003, 11:40:13 AM »
sure, do you a custom menu, put (vl-load-com) in your .mnl file. Or any other lisp that runs when ACAD opens.
Craig
« Reply #8 on: November 19, 2003, 11:45:09 AM »
So, have you figured out a way to make mutliple selections in a DCL file list box like such
: list_box {
            key = "box_list";
            fixed_width = true;
            allow_accept=true;
            alignment = centered;
            width = 40;
I know how to get single selections but not multiple. Any ideas?
Craig
« Reply #9 on: November 19, 2003, 12:00:24 PM »
Or, is there a vl- comparible to getfiled that will let you select multiple files?
« Reply #10 on: November 19, 2003, 12:03:38 PM »
multiple_select = true-false;
Specifies whether multiple items in the list_box can be selected (highlighted) at the same time. Possible values are true or false (default: false). If true, multiple items can be selected at a time.
that should work in your DCL.
Craig
« Reply #11 on: November 19, 2003, 12:04:43 PM »
Damn, where the hell did you run across that. I have been looking and found nothing. You got a book or something?  :o
Thats exactly what I was after. You are my hero!
« Reply #12 on: November 19, 2003, 12:08:42 PM »
<acad install>\Help\acad_dev.chm I have a shortcut to it in my Taxkbar.
see Programmable Dialog Box Reference
daron
« Reply #13 on: November 19, 2003, 12:31:39 PM »
What do you mean, The Daron act?
« Reply #14 on: November 19, 2003, 12:41:13 PM »
heyheyhey....... you forgot!
see my wise a$$ response about 1/2 way down.
http://www.cadalog.com/phpbb2/viewtopic.php?t=15768&highlight=daron+act
