Author Topic: Ascertaining Relative Location To Curve  (Read 6009 times)
Spike Wilbury
Re: Ascertaining Relative Location To Curve
« Reply #15 on: June 29, 2009, 10:24:20 AM »
you need to check if the objects are valid first, before doing anything, and I never had use the call to trans.Abort();
wannabe
« Reply #16 on: June 29, 2009, 10:41:58 AM »
The curve is being offset, hence the curveLCollection being populate with the single curve offset on the one side. However, the offset to the other is failing.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: June 29, 2009, 06:22:27 PM »
Have alook at AcDbCurve::getOffsetCurves in the ARX docs. Aslo have you tried what sinc posted?
