I posted this on a.a.c., but so far no response over there.
Maybe someone here knows...
Suppose this:
Command: (setq var (vlax-make-variant))
#<variant 0 >
I see these functions in the manual:
(vlax-variant-change-type var type);Returns the value of a variant after
changing it from one data type to another
(vlax-variant-type var);Determines the data type of a variant
(vlax-variant-value var):Returns the value of a variant
but, I see no function to set the value
So, if you can't set the value, what good is it?
And if it is possible to do that, then it is possible to change the value of a variant once created.
But, I don't see a way to do it.
Am I missing something?
By contrast, we have:
(vlax-safearray-get-element var element...)
(vlax-safearray-put-element var index... value)
