Author Topic: Inactive Model/Layout Tab after Modal Application  (Read 4328 times)
wannabe
« on: June 25, 2009, 03:51:38 AM »
Not sure where to look in my code. But every time I use one of my modal form-based applications I cannot click the model or layout tabs with any functional success.
Typing Tilemode is the workaround, but I'd rather not have to ensure other users have to do this as well.
Are there any known causes for this?
Cheers
EDIT: Further information; I am calling it using the Application.ShowmodalDialog() method.
It's Alive!
  • Retired
  • AKA Daniel
Re: Inactive Model/Layout Tab after Modal Application
« Reply #1 on: June 25, 2009, 05:13:28 AM »
That's how modal is supposed to act, you should try using modeless. Don't forget to lock the document
wannabe
« Reply #2 on: June 25, 2009, 05:28:39 AM »
Upon closure of my form is when the problem happens. Every other command and button is fine, just the two tabs. Even when the modal is long gone into the sands of time :-)
I don't think adding a Document Lock would work here? Reckon I should give it a bash anyway?
Glenn R
« Reply #3 on: June 25, 2009, 05:55:29 AM »
Is your modal form being displayed by a command you've registered?
Glenn R
« Reply #4 on: June 25, 2009, 05:57:39 AM »
Also, without the usual info, as usual people will be guessing:
Code example (preferably one that can be run)
Acad version
.NET version
Framework version
Visual Studio version
etc.
:D
wannabe
« Reply #5 on: June 25, 2009, 07:14:03 AM »
Acad version
.NET version
Framework version
etc.
:D
this code was targetting .NET 2.0. Rest of the details as per my sig.
The code is fairly bulky, and I don't know what area could be causing the problem. But I'll post up later. I was just asking if there were any known issues tbh.
Nick
Glenn R
« Reply #6 on: June 25, 2009, 07:28:45 AM »
It sounds like you document is locked up. Do you have any document locks anywhere and are they always being released?
wannabe
« Reply #7 on: June 25, 2009, 10:15:34 AM »
To be honest, I don't use document lock when using a modal form; I don't this was part of the methodology used in the .NET labs (apologies if I'm wrong).
I'll scan the code tonight and post up some portions that look dubious.
Cheers
wannabe
« Reply #8 on: June 25, 2009, 10:40:29 AM »
It is quite strange, though. Every other button works and clicking the tiles or typing tilemode also achieves the same functionality as pressing the tab.
So this is isolated to the tabs. Would that be indicative of a document lock?
One thing I can think of is that the command will only add points to model space.
wannabe
« Reply #9 on: June 26, 2009, 03:08:53 AM »
The problem was that I wasn't actually using the Application.ShowModalDialog(). Please forgive me, it was one of my first projects.
« Reply #10 on: June 26, 2009, 03:46:15 AM »
That Sir, Is the very reason it's better to post your code :)
... someone would have noticed the Show Dialog call
/// kdub
wannabe
« Reply #11 on: June 26, 2009, 08:53:31 AM »
touche
Glenn R
« Reply #12 on: June 26, 2009, 10:02:06 AM »
I told you so  :-P seems appropriate me thinks.
