(defun ARCH:QUESTION-5 (TT LN1 LN2 LN3 LN4 LN5 / X1 X2 txmsg buttons)
(setq X1 " Please Make a Selection\n")
(setq X2
"-----------------------------------------------------------------------------------------------------------------------\n")
(setq txmsg (strcat X1 X2 LN1 LN2 LN3 LN4 LN5))
(setq buttons (list "Option [ 1 ]" "Option [ 2 ]"))
(dos_msgboxex txmsg (strcat ARCH#LOGO " : " TT) buttons 4))
(defun TOOLIT (/ tmp)
(defun A_P-TP (/ pathstr)
(setq pathstr "V:\\ARCH\\ToolPalette")
(command "*_toolpalettepath" pathstr))
(defun BLK-TP (/ pathstr)
(setq pathstr "V:\\ARCH\\Custom_Architettura\\Bloc\\ToolPalette_Blks")
(defun CUS-TP (/ pathstr)
(setq pathstr "C:\\ARCH_Custom\\ToolPalette")
(defun DTL-TP (/ pathstr)
(setq pathstr "V:\\ARCH\\Custom_Architettura\\Bloc\\ToolPalette_Dtls")
(defun HAT-TP (/ pathstr)
(setq pathstr "V:\\ARCH\\Patterns\\ToolPalette")
(defun TOOL-IT (/ result)
(initget "A B C D H")
(setq tmp (getkword
"\n* Select Tool Palette Path: <A>rch Program <B>locks <C>ustom <D>etails <H>atches *"))
(initget 7)
;;disallow null,zero & negative
(cond ((= tmp "A") (A_P-TP))
((= tmp "B") (BLK-TP))
((= tmp "C") (CUS-TP))
((= tmp "D") (DTL-TP))
((= tmp "H") (HAT-TP))
(command "_ToolPalettes") ;;_ToolPalettesClose
(setq result (ARCH:QUESTION-5
"Tool Palettes"
" Set the ''Tool Palette File Location'' for AutoCAD\n"
" Select an option below..\n\n"
" [ 1 ] Set a Tool Palette\n"
" [ 2 ] Cancel routine...\n" ""))
(cond ((= result 1)
(princ "\n*** ///////// Program CANCELLED ///////// ***"))
((= result 0) (TOOL-IT)))
(princ))
