Author Topic: Dynamic Intelligent Leader !  (Read 180119 times)
ROBBO
Re: Dynamic Intelligent Leader !
« Reply #330 on: November 21, 2014, 01:56:47 AM »
Before Step6
; error: bad argument type: streamp nil
appears on clicking the  'Ok' or 'Cancel' button within the  DiLeader config Panel.
Hope this helps. Robbo.
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Andrea
« Reply #331 on: November 23, 2014, 10:32:04 PM »
Thank you Robbo for helping me..
attached a new debug file..
1 alert box only showing some string...
please take time to make a screnshot and provide it..
second step...
windows explorer will bring you the log file...
please provide it as well.
this will help me alot.
Thank you.
Keep smile...
bilançikur
« Reply #332 on: November 24, 2014, 04:00:42 AM »
Just to help, here's some extra info (I think)...
This version of the program runs like normal, only the difference in this "debug version" is when you try the command "dilc" or "dilconfig". Then the alert box will appear. Also, according to this part:
(setq debugf (open (setq logfilez (strcat Dil_installdir "\\DiLeader_Debug.log")) "w"))
there should be a log file in the folder "c:\Program Files\Ductisoft\DiLeader" at some point...
In AutoCAD 2015 it does run like it should, all fine thanks!
There is no log file however.
In case of ZWCAD:
See attachement, for what happens. The program does not work.
It seems the project is not loaded correctly.
Also, there is no log file in the folder.
ROBBO
« Reply #333 on: November 24, 2014, 04:05:16 AM »
Andrea,
Step1 image attached, but no DiLeader_Debug.log file created I am afraid.
Kr. Robbo.
Oscar Wilde
Andrea
« Reply #334 on: November 24, 2014, 11:53:07 AM »
In case of ZWCAD:
thank you for the Info bilançikur
few questions if you don't mind..
-is the ZRX load correctly in ZWCAD ?
-is the dialogbox appear ?
-do you have same error as Robbo ?
thank you.
Keep smile...
Andrea
« Reply #335 on: November 24, 2014, 11:54:38 AM »
Please guys,..may you run the debug2 version... ?
Keep smile...
ROBBO
« Reply #336 on: November 25, 2014, 02:29:29 AM »
Andrea, Snap shots of pop-ups attached below.
Please note I am unable to exit the DiLeader config Panel with the Ok button. Only Cancel will exit the dialog.
Hope this helps. Cheers, Robbo
Oscar Wilde
Andrea
« Reply #337 on: November 25, 2014, 11:19:37 AM »
Thank you Robbo for all your help and your patience..
this help me for sure..
attached a zip file containing some updated file.
please unzip in your installation folder and load the Dileader_debug.lsp file.
please provide all screenshot and error message if any.
thank you.
Keep smile...
ROBBO
« Reply #338 on: November 25, 2014, 11:49:41 AM »
Andrea,
Are you ready?
Oscar Wilde
ROBBO
« Reply #339 on: November 25, 2014, 11:51:46 AM »
...continued.
Cheers, Robbo.
Oscar Wilde
Andrea
« Reply #340 on: November 27, 2014, 09:06:07 AM »
Thank you Robbo,..:)
Please check this last version..
thank you.
Keep smile...
ROBBO
« Reply #341 on: November 27, 2014, 09:41:52 AM »
Andrea,
unfortunately get a similar error with v.14.331. Debug version v.14.285 works as expected.
Command: (LOAD "C:/Program Files/DuctiSoft/DiLeader/DiLeader.LSP")
DiLEADER version v.14.331 par: Andrea Andreetti - DuctiSoft inc.#<VLR-Command-Reactor>
Command: DILC
ODCL_LM version 14.285 by DuctiSoft inc. - Enabled done.
T
Command:
Command:
Command: (LOAD "C:/Program Files/DuctiSoft/DiLeader/DiLeader_debug.LSP")
DiLEADER version v.14.323 par: Andrea Andreetti - DuctiSoft inc.#<VLR-Command-Reactor>
Command: DILC
T
All the best, Robbo.
Oscar Wilde
Andrea
« Reply #342 on: November 27, 2014, 09:11:36 PM »
perfect.. :)
It seem that the error come when trying to write in the cfg file.
(setq cfgo (open (strcat Dil_installdir "\\dlconfig.cfg") "w"))
My you tell me the result of  !Dil_installdir  variable ?
Keep smile...
ROBBO
« Reply #343 on: December 01, 2014, 01:58:56 AM »
Andrea,
Command: (setq cfgo (open (strcat Dil_installdir "\\dlconfig.cfg") "w"))
nil
Command: !Dil_installdir
"c:\\Program files\\DuctiSoft\\DiLeader"
« Last Edit: December 01, 2014, 02:07:25 AM by ROBBO »
Oscar Wilde
ribarm
  • Marko Ribar, architect
« Reply #344 on: December 01, 2014, 02:03:25 AM »
ROBBO, I think Andrea is asking for what do you get after typing : !Dil_installdir at command prompt...
M.R. on Youtube
