Author Topic: Dynamic Intelligent Leader !  (Read 180264 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #195 on: September 27, 2009, 08:22:38 PM »
Thanks to you guys...you comments and suggestions was helpful.
Many other project on the table....
But I think that LeeMac have same project list ! ;-)
Time is missing a bit....but I"ll be back with more soon.
thanks.
Andrea
Keep smile...
« Reply #196 on: September 28, 2009, 05:05:24 AM »
Definitely  :wink:
Great work here Andrea, I look forward to seeing your next projects  :-)
Aerdvark
« Reply #197 on: September 29, 2009, 01:31:05 AM »
Hi Andrea,
I am sorry to say but I tried the code and there is something wrong ... can't help you to find out where it goes wrong but this is what happens:
Command:
DILA
(T)ext/(M)text ?<M>:
Do you want Multiple Object Selection ?(Y)es/(N)o ?<NO>:
Text: TEST
Select Object...
Pick Text location...
bad DXF group: (10)
In my case this happens on a pline whenever the dila gets to 0 degrees or to 180degrees.
If it is a Pline on the x axis it's okay. Dila on a pline other than that don't seem to work.
Here is a link to a short video of what happens, maybe it is useful for you.
http://www.freewebtown.com/engl/dila_prob.avi (Rightclick and save as)
The 90 degree angle is very nice, can that be done to on vertical lines?
Andrea
« Reply #198 on: September 29, 2009, 05:40:13 AM »
ok thanks....
i'll be back with the fix..  ;-)
Keep smile...
Andrea
« Reply #199 on: September 29, 2009, 09:04:51 AM »
There we go...
DiLEADER v.2.2.7
D y n a m i c   I n t e l l i g e n t   L e a d e r
The problem was with the wipeout on horizontal Leader. ;-)
I also add an English/French translation messages.
 :police:
Keep smile...
Aerdvark
« Reply #200 on: October 01, 2009, 02:00:20 AM »
You did it. Great Work, Tnx.
Aerdvark
« Reply #201 on: October 21, 2009, 03:11:39 AM »
Hello Andrea,
Do you have any idea why I encounter the following problem?
Whenever I open a new drawing (from scratch) the DILA leader is perpendicular to the line / object as it is supposed to be. So that's good.
In some occasions, for example existing drawings in wich I used an early version of "dileader", the dileader stays the way it was / is. So not perpendicular.
I tried to erase all the dileaders and apply new ones but it don't seem to work. They stay not-perpendicular.
I figure you have set something in the windows register... true? And how can I (or you) fix this? For the perpendicular dileaders are much more attractive to see on an actual drawing when it is plotted.
Maybe it is a drawing specific parameter, but I can't find out which.
So please help, so I can continue using the dileader. It is stil a great routine!
Andrea
« Reply #202 on: October 21, 2009, 03:57:08 PM »
Hello Andrea,
Hi, could you provide a drawing who have the problem ?
i'll check that soon.
thanks.
Keep smile...
flopo
« Reply #203 on: November 16, 2009, 07:56:55 AM »
Hello Andrea,
Attached i send a lisp that make automatic numbering, 1,2,3...etc. Can you modify your lisp to do automatic numbering when Dynamic Intelligent Leader is inserted? I mean, to insert an Dynamic Intelligent Leader with "1" text, then 2, 3.... Thanks!
cmwade77
« Reply #204 on: November 16, 2009, 12:21:43 PM »
Andrea, I would love to see this use mleaders instead of standard leaders, as they tend to work better with annotation scaling.
Andrea
« Reply #205 on: November 16, 2009, 06:24:33 PM »
Hi Flopo and. Mr. Wade
thanks for your suggestions...
DiLeader will be improved soon to allow more flexibility and more options..
at the moment...i'm trying to fix some little bug and be back with a new release.
Thanks.  :-)
Keep smile...
flopo
« Reply #206 on: November 26, 2009, 05:59:28 AM »
nothing new here? :)
Andrea
« Reply #207 on: November 26, 2009, 11:34:03 AM »
Yep !..
DiLEADER will be remake to allow user more flexibility and productivity.
first, the DiLConfig panel will be improved and allow more options.
Below, a Gif showing you 2 more modif.
- Reactor on Text Moved, scaled and/or rotated will be added
- DilAttach command will allow user to select via "crossing" objects.
also, I take this moment to announce you that I have grouped all my Dynamic Routine on my server.
http://www.ductisoft.com/FreeLisp/freelispwebsiteEN.html
For now,.. I am still working on DilLeader and come back shortly.
thanks all.
« Last Edit: December 12, 2010, 08:37:10 PM by Andrea »
Keep smile...
xianaihua
« Reply #208 on: December 06, 2009, 12:24:08 AM »
Great work !
thanks very much
Andrea
« Reply #209 on: December 06, 2009, 06:31:26 PM »
Great work !
thanks very much
Thank  you Xianaihua ! and welcome !
I thing that DiLeader is popular ...or will be.
It bring some new user on theswamp !
aerdvark, zanze02, hugo, measureup, and now you Xianaihua.
Thanks to you guys for taking time to register to theswamp and put at the first post a comment like you did.
I won't let you down ..and I'll be back with a new version shortly.
Andrea.
« Last Edit: December 06, 2009, 06:35:31 PM by Andrea »
Keep smile...
