Author Topic: Dynamic Intelligent Leader !  (Read 180023 times)
Andrea
« on: June 21, 2009, 09:27:43 PM »
Hi all..
I need beta-tester for my new routine..
DILEADER v.1.0
(Dynamic Intelligent Leader)
Allow user to quickly put/tag some object.
Need comments on the idea and concept.
thanks.
There is Some animation...
Easy to use...you can put any DIL you want on a simple object.
You can edit the Text leader, Move , stretch...
The Leader is intelligent and know what Object is tagged.
so if it was moved, stretched,rotated etc...DIL will know and will readjust the leader on it.
« Last Edit: June 21, 2009, 09:33:01 PM by Andrea »
Keep smile...
Re: Dynamic Intelligent Leader !
« Reply #1 on: June 21, 2009, 09:57:48 PM »
Very Nice!   :kewl:
I could learn a great deal from this program, thanks for posting Andrea.  :-)
As an aside, may I ask what program you used to create the GIF images?
Thanks,
Lee
KewlToyZ
« Reply #2 on: June 21, 2009, 10:07:49 PM »
Fantastic tool sir! Thank you so much for sharing.
Andrea
« Reply #3 on: June 21, 2009, 10:28:32 PM »
Thanks Guys....
LEE MAC..
I use THIS
Keep smile...
« Reply #4 on: June 21, 2009, 11:55:44 PM »
Nice work Andrea!
After the Leader is created, using ACAD2000 & moving the text the leader is not updated. I know this is a function of ACAD but thought
the routine would account for it.
Moving the associated object from left to right does not change Left / Right attachment point to the text.
hermanm
« Reply #5 on: June 22, 2009, 12:42:06 AM »
(setq DL_textsize (getvar "textsize"))
results in very small text size :(
suggest:
(setq DL_textsize (* (getvar "DIMSCALE") (getvar "DIMTXT")))
unless current dimension style has fixed text height, yada yada
« Reply #6 on: June 22, 2009, 07:06:31 AM »
Just a small one, but I would add a (princ) after (princ "\nDleader Finish."), to get rid of the "nil" return.
Oh, and it doesn't like Arcs too much :P
m4rdy
« Reply #7 on: June 22, 2009, 09:10:51 AM »
That's amazing.
Its just my curiosity, how long do you spent your time to make this DLEADER V.1.0?  :-)
Autocad 2007, Windows XP
Andrea
« Reply #8 on: June 22, 2009, 11:01:53 AM »
around
2 days to think on how I want the program run...
2 day conception and bug fix.
 :roll:
Keep smile...
Andrea
« Reply #9 on: June 22, 2009, 11:07:33 AM »
DiLEADER 1.1
Update 1
I have replaced the DL_textsize variable to take the existing
DIMTXT when Updated and the DIMTXT against TEXTSIZE when created.
(setq DL_textsize (vla-get-Height (vlax-ename->vla-object TXTobj)))
(setq DL_textsize (getvar "DIMTXT"))
Update 2
I use vlax-curve-getClosestPointTo
against vla-intersectwith This modification show diffrent leader reaction...but work better.
Update 3
I also updated the code to put the Arrow size as per DIMASZ
(vla-put-ArrowheadSize (vlax-ename->vla-object Llead) (getvar "DIMASZ"))
Update 4
Left/Right justification text was improved when object as been updated.
Update 5
and finaly..
the "NOTE" in the Mtext still there when moving the mouse to show dinamicly a preview..
but it will be gone when picking the loccation text.
(entmod (subst (cons 1 "") (assoc 1 (entget Ltext)) (entget Ltext)))
Let me know if all work ok.
thanks.
CAB.
I need to install 2000 for test..
Keep smile...
KewlToyZ
« Reply #10 on: June 22, 2009, 11:17:56 AM »
Nice Andrea!
I was just reading through trying to find a way to set the Standard Dimstyle & text style to update key measurements according to dimscale from an autolisp function call. So far it is looking like an issue many have looked at with differing results.
« Reply #11 on: June 22, 2009, 11:42:41 AM »
Excellent Andrea - I thought you may opt for the vlax-curve-getClosestPointto... much better results with much less coding   :wink:
GDF
« Reply #12 on: June 22, 2009, 02:12:32 PM »
Using 2008 here, and I don't get the same results. When I move the circle the leader does not follow.
Also the word NOTE becomes part of the text. And I can not get the leader and text to move inside the circle.
Andrea
« Reply #13 on: June 22, 2009, 02:20:09 PM »
DiLEADER 1.2
Little Bug Fix
as Gif below....extension entity was removed..  ;-)
Keep smile...
Andrea
« Reply #14 on: June 22, 2009, 02:21:52 PM »
Hi Gary.
eaven with 1.2 ?
Keep smile...
