Author Topic: Dynamic Intelligent Leader !  (Read 180121 times)
kruuger
Re: Dynamic Intelligent Leader !
« Reply #375 on: March 31, 2015, 04:51:00 AM »
Andrea, thank you for your quick response
The raison of mleader is that I have autocad 2013 and multileader has been enhanced with additional tools. So if your lisp dileader would be implemented with mleader it would be top.
Regards
Francine
hi
mleader is crap since dbl sided leaders stretch bug.
k.
DuanJinHui
« Reply #376 on: March 31, 2015, 06:41:31 AM »
Dear Andrea.
I want to know where can download this routine? Thanks for sharing.
Andrea
« Reply #377 on: March 31, 2015, 11:03:07 PM »
Hi DuanJinHui,..Welcome to theswamp ! :)
the new version of DiLeader will be out shortly. I'll put the download link here.
Kruuger,..
may I ask you wich stretch bug you have with Mleader ? my streetch work fine here.
bilançikur,..
Thank you very much...very appreciated.
Francine,
DiLeader allow more flexibility that all other leader type.
also, DiLeader follow the Dimension style settings..instead of Mleader who have his own setting....and to be honest , I never understood why autoCAD created two different ways to configure Leader instead adding options for current one.
but I'm curious to know wich option Mleader have that DiLeader do not allow..?
Keep smile...
kruuger
« Reply #378 on: April 01, 2015, 01:34:05 AM »
Hi Andrea
Please draw mleader with with 2 arrows - left and right. Than try to stretch all with "full window".
Whole mleader should start move but isn't. Noticed that text/block move dbl distance (green) compare to arrows (red).
it is similar to qleader streatch in dynamic block (see image). almost 10 years and still not fixed !!
kruuger
« Reply #379 on: April 01, 2015, 09:01:15 AM »
And a video :)
77077
« Reply #380 on: April 01, 2015, 09:42:48 AM »
And a video :)
very beautiful , ronjonp.
Andrea
« Reply #381 on: April 01, 2015, 09:46:01 AM »
oookkkey ! :|
never realized that..
so...
+1 for DiLeader !
Keep smile...
kruuger
« Reply #382 on: April 01, 2015, 03:34:38 PM »
oookkkey ! :|
so...
+1 for DiLeader !
yep :)
ROBBO
« Reply #383 on: June 03, 2015, 02:15:31 AM »
Hello Andrea,
Is your new version of DiLeader available?
Kr. Robbo.
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Andrea
« Reply #384 on: June 03, 2015, 06:55:01 AM »
oops,...sorry...I forgot. :)
the link is Here
Any comment or suggestion are welcome.
Keep smile...
ROBBO
« Reply #385 on: June 03, 2015, 07:45:08 AM »
the link is Here
Thank you Andrea. Unfortunately I am unable to unzip the file. Is it password protected?
Oscar Wilde
77077
« Reply #386 on: June 03, 2015, 07:47:41 AM »
the link is Here
Hi ROBBO ,unzip  no problem.
You sure download normal completion ?   file size :15.2 MB
BTW, I use "winrar "
ROBBO
« Reply #387 on: June 03, 2015, 07:56:57 AM »
Mm. Strange 77077!
Please attachments below when I use PeaZip and not the windows default.
« Last Edit: June 03, 2015, 08:05:15 AM by ROBBO »
Oscar Wilde
ROBBO
« Reply #388 on: June 03, 2015, 07:58:14 AM »
I think it may of been corrupted on download. I will download again. My internet link here is terrible at the moment.
Unable to download fully at the moment although 15.3MB, the best I have download at the moment is 1,745KB - I will keep trying!
« Last Edit: June 03, 2015, 08:04:26 AM by ROBBO »
Oscar Wilde
77077
« Reply #389 on: June 03, 2015, 08:13:14 AM »
Good Luck!
