Author Topic: Dynamic Intelligent Leader !  (Read 180117 times)
Re: Dynamic Intelligent Leader !
« Reply #30 on: July 09, 2009, 11:01:09 AM »
Request for  text height change: 8-)
(setq DL_textsize (* (getvar "DIMTXT") (getvar "DIMSCALE"))) ; CAB
Andrea
« Reply #31 on: July 11, 2009, 10:34:41 PM »
Thanks Guys...
I'm a little busy right now....
But i've read all your comments and i'll be back soon.
Andrew and Gary...
Yes this can be done.
Thanks for the suggestion....i'll take it.  ;-)
Keep smile...
Andrea
« Reply #32 on: August 05, 2009, 03:20:17 PM »
Hi all..
Sorry for the delay.....to much work here.. :wink:
Well,..there we go...
DILEADER v.1.4
(Dynamic Intelligent Leader)
what's new on this release:
- Work with Block entities.
- Dimscale & Textsize readjusted.
- Multiple selection allowed.
- Text color adjusted with DIMCLRT variable.
- Leader position readjusted when Moved or stretched.
- MOVE,STRETCH,ROTATE,SCALE are now added to reactor.
- Reactor now work for block entities and/with multiple selection.
- DILEDIT remake to allow block recongnition.
- TEXT & MTEXT choice option addded.
As you can see below, you can now use multiple object selection, DiLeader will readjust all the thing.
Feel free to add your comments.
Enjoy !
(next step: annotative detection)
Keep smile...
GDF
« Reply #33 on: August 05, 2009, 04:47:14 PM »
Very nice Andrea. The only comment I have is for it to use the current text style, and the arrow head did not show up.
Andrea
« Reply #34 on: August 05, 2009, 04:50:29 PM »
Very nice Andrea. The only comment I have is for it to use the current text style.
thanks.
maybe it will be better if DiLeader use DIMTXSTY variable ?
Keep smile...
« Reply #35 on: August 05, 2009, 07:02:11 PM »
Impressive Andrea.
Andrea
« Reply #36 on: August 06, 2009, 09:14:55 AM »
Keep smile...
Andrea
« Reply #37 on: August 06, 2009, 01:16:28 PM »
Many people ask me..
"what is the difference between Mleader and DiLeader ?"
Mleader have some options who DiLeader don't have
but there is what I know.....
-Mleader do allow only Mtext entity
-Mleader do no tag an object but a point.
-Mleader can not tag any unproportionaly scaled Blocks.
-Mleader remove the connection between block object if it is unproportionaly scaled. (see gif)
-Mleader available from 2008 -> 2010 only vs DiLEADER tested on 2004 -> 2010.
Do I miss something ?
By the way....why we can't use any snap mode on unproportionaly scaled blocks ?
Keep smile...
Andrea
« Reply #38 on: August 06, 2009, 04:28:46 PM »
New Feature...
Block arrow Switch by pressing TAB key.
Keep smile...
ArgV
« Reply #39 on: August 08, 2009, 10:42:12 PM »
Just FYI, this thing is AWESOME! I tried to break it, but by version 1.4, every bug I'd found from version 1.0 was corrected. (as you know)
(autocad 2008)
Sweet!
Pad
« Reply #40 on: August 10, 2009, 11:27:35 AM »
hello I have a slight problem with 1.4 and 1.5:
Command: dil
(T)ext/(M)text ?<M>: M
Invalid option keyword.
(T)ext/(M)text ?<M>: T
Select Object...
Pick Text location...
Dileader Finish.
also the leader is not associated with the text.
Could this be because I am using 2004?
Andrea
« Reply #41 on: August 10, 2009, 01:19:56 PM »
Hi...
can you give this a try ?
(initget 0 "TEXT MTEXT")
(setq DLtextMode1 (getkword (strcat "\n(T)ext/(M)text ?<?>: ")))
(princ (vl-princ-to-string (ascii DLtextMode1)))
Keep smile...
Andrea
« Reply #42 on: August 10, 2009, 01:21:12 PM »
(autocad 2008)
Sweet!
Thanks ArgV.. ;-)
Keep smile...
Pad
« Reply #43 on: August 11, 2009, 05:41:00 AM »
Hello Andrea
On further investigation if i enter 'text' or 'mtext' in full then it will work properly.
I suppose 'text' and 'mtext' are very similar.
The other problem with moving the leader note in one I haven't been able to resolve (acad 2004)
thank you
Andrea
« Reply #44 on: August 11, 2009, 08:37:34 AM »
Hi PAD,
I'm working on it and be back with a new release.
(what is the bug on moving ?)
Keep smile...
