Author Topic: Dynamic Intelligent Leader !  (Read 180171 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #210 on: December 14, 2009, 01:13:13 PM »
Hi all..
Like promised...
DiLEADER 2.2.8
is now released !
Bug Fix:
   - Fix UCS-WCS and block rotation revised
   - Fix Wipeout for Leader UCS-WCS
New Features:
   - No more settings in registry -> replaced with dlconfig.cfg file
     Allowing user to have same config by sharing this file over a network
   - Reactor improved to allow to move stretch and scale any object and TEXT in the drawing.
   - DilAttach allow now crossing selection object.
   - DilConfig dialog Improved and use now ObjectDCL technology.(not provided)
   - New Auto-Numbering Leader allowing many diffrent auto-Numbering style.
   - New command list and features are in the help file provided in the installation zip.
     2 Help file (English and French)
   - Dialog Box can be edited via custom language files provided with the installation.
     (Included: English,Francais,Allemand,Albanais,Portugal,Italiano,Island)
     don't be shy to create your own language file and share with all.
Below, a gif showing DilAttach via crossing object.
Below, a gif showing New Dialog interface.
Note the Tab-Drop-Down menu at the top left.  ;-)
Below, some gif showing diffrent Auto-Numbering options and result.
To come...
   - Leader dimension custom variables and vertical line option (see below)
   - Block insertion (see below)
Enjoy !
Keep smile...
GDF
« Reply #211 on: December 14, 2009, 02:47:29 PM »
Great job
(1) how do you bring up the config dialog box?
(2) how do I keep the leader style from changing back to the default whenever I move the reactor object that the leader is pointing to?
(3) can you list all of the routines commands.
Andrea
« Reply #212 on: December 14, 2009, 03:41:10 PM »
thank you Gary..
Same as the older version..."DILCONFIG" command
I do not change any leader style. It must keep the existing leader style.
DiLEADER come with HELP file. "dileader_en.mht" and include all screen shot and detailled informations.
Keep smile...
GDF
« Reply #213 on: December 14, 2009, 03:49:15 PM »
How about selecting textstyle and leader layer option.
Thanks again for sharing your routine.
Andrea
« Reply #214 on: December 14, 2009, 04:24:40 PM »
Nice Idea..
do you have any suggestion on how you want to use the layer options and textstyle ?
Keep smile...
KOWBOI
« Reply #215 on: December 14, 2009, 04:46:11 PM »
I love this routine, great work, very impressive!!!!! :-o Is there any way to make the leader a curved spline?
« Reply #216 on: December 14, 2009, 04:50:18 PM »
Very impressive Andrea, I must say.
This program certainly out-does all your other free dynamic programs combined! And the huge amount of work, time and effort that you have ploughed into this project is evident. I admire your generosity with this program, as you could probably make quite a bit of money from it - like the others on your site.
And the suggestions keep on coming - you've certainly got your work cut out!
Lee
GDF
« Reply #217 on: December 14, 2009, 04:54:58 PM »
From a popup dialog list of styles and layers to choose from. Something like the small dialog pictured, maybe.
Andrea
« Reply #218 on: December 14, 2009, 05:23:29 PM »
I think yes..need to try that option.
thanks for the Idea.  :roll:
Keep smile...
Andrea
« Reply #219 on: December 14, 2009, 05:24:28 PM »
Lee
Thanks Lee, I admire also all your work !
Keep smile...
Andrea
« Reply #220 on: December 14, 2009, 05:25:50 PM »
Yes Gary, This can be done..
thanks for the suggestions.
How about to manage Leader Layer ?
Keep smile...
« Reply #221 on: December 14, 2009, 05:31:56 PM »
I would have both as popup_lists instead of list_box - as these can take up less room and can be nestled into a boxed_column/row on the dialog - but then perhaps more can be done with ObjectDCL  :wink:
Andrea
« Reply #222 on: December 14, 2009, 06:08:32 PM »
thanks Lee.
Maybe by having a choice to add some string in current layer ?
eg:
New string "LEAD"
current layer: M-PLUM-E  (Mechanical-Plumbing-Existing)
demanded layer: M-PLUM-*-E
result:=  M-PLUM-LEAD-E
and also add Suffix and Prefix...
or replacing some string in existing Layer name.
eg:
New String:"LEAD"
demanded string to replace: PLUM
result:= M-LEAD-E
Because often some cie standard draw TEXT and LEADER on diffrent layer but in same discipline.
M-HVAC-UNIT-E
M-HVAC-TEXT-E
M-HEATING-DUCT-N
M-HEATING-TEXT-N
Hmmm..!!?  is that make sense ?   :?
Keep smile...
« Reply #223 on: December 14, 2009, 06:14:08 PM »
Yes, but I wouldn't overcomplicate things  :wink:
Andrea
« Reply #224 on: December 14, 2009, 06:20:52 PM »
It is not very important how complicated it is for me to develop a program...
I always learn and growing in my knowledge..   ;-)
I think the most important is that must be easy to use and offer more flexibility for the user.
 :angel:
I have made some test with Spline Leader..
and seem to work..
Keep smile...
