Author Topic: Dynamic Intelligent Leader !  (Read 180115 times)
Re: Dynamic Intelligent Leader !
« Reply #180 on: September 16, 2009, 10:13:14 PM »
Then , if you explode the Leader, and investigate the arrow block ;
LIST
Select objects: 1 found
Select objects:
                  BLOCK REFERENCE  Layer: "0"
                            Space: Model space
                   Handle = 262c
       Block Name: "_Dot"
                at point, X=   0.4573  Y=   0.4044  Z=   0.0000
   X scale factor:    0.2000
   Y scale factor:    0.2000
   rotation angle:    196
   Z scale factor:    0.2000
  Scale uniformly: No
  Allow exploding: Yes
Andrea
« Reply #181 on: September 16, 2009, 10:38:40 PM »
There it is...
ScaleFactor = 0.2
thanks Kerry.
Keep smile...
Hugo
« Reply #182 on: September 21, 2009, 06:22:48 AM »
Hallo Andrea
There it is...
ScaleFactor = 0.2
thanks Kerry.
Und was muss ich jetzt einstellen, damit es klappt mit der Pfeilgösse.
Danke
Andrea
« Reply #183 on: September 21, 2009, 10:34:25 AM »
Hallo Andrea
There it is...
ScaleFactor = 0.2
thanks Kerry.
Danke
Hallo Hugo..
please be patient...I am currently working on a new version. Thanks.
Keep smile...
Hugo
« Reply #184 on: September 21, 2009, 12:20:16 PM »
Hallo Andrea
Ok
Danke für rückmeldung
Aerdvark
« Reply #185 on: September 22, 2009, 01:57:09 AM »
Hi Andrea,
I still am following this thread! Still like the discussion and I try every new update.
There is a thing that I would like to know, and maybe you can help me clear it up.
Is it possible to change the angle of the leader? I mean like 90 degrees or 0 degrees?
You should not alter the code only for my request but maybe you can show me where to look to alter it myself.
Or maybe that it works kinda "ortho"-like.
And also: the routine places the text left or right of the arrow leader. When moving the  leader at one point it flips the text over to the other side.
It would be nice to have a switch in there, ie. when the arrow is placed the text appears on the left or right.
With TAB you can choose wich arrow head you want. And maybe with SPACE flip it left <-> right.
Maybe I'm not to clear... Dutch ah... :ugly:
Andrea
« Reply #186 on: September 22, 2009, 08:16:55 PM »
Hi Aerdvark,
Thanks for your suggestions...
I'm a little busy at the moment (working on a new Project)
so i'll give a look soon on your request.
By the way....I do not understand what is the advantage to flip Left->Right the text entity..
can you provide any exemple ?
for the moment...there is some fix.
DiLEADER 2.2.5
also, you will see a new icon when the cursor crosses over a Leader entity created by QLEADER.
This new icon will allow me to transform this entity to a DiLeader Object on request for the next release.
 :kewl:
Keep smile...
Hugo
« Reply #187 on: September 23, 2009, 06:23:25 AM »
Hallo Andrea
Danke jetzt sind meinen Pfeilspitzen ok.
Super Tool
kevinpo
« Reply #188 on: September 23, 2009, 10:18:10 AM »
Very Nice Program Andrea.  What about typing in the text after the leader is placed instead of at the command line?
And, what about using up and down arrow keys to adjust the arrow size on the fly?
Great Work!
Andrea
« Reply #189 on: September 23, 2009, 12:05:15 PM »
thanks  ;-)
Not sure about your request.....
DiLeader allow Both.
if you don't enter any text at the command line it will ask on the graphic screen.
Nice Idea..
But is this will not interfer with the Company size standard ?
sure..I can get the + - key code or the arrowKey on the numPad
but can't get the arrow Key.
Keep smile...
« Reply #190 on: September 23, 2009, 12:56:20 PM »
Nice Idea..
Put a variable to flag the feature On / OFF so the admin can control it. 8-)
Andrea
« Reply #191 on: September 25, 2009, 03:13:46 PM »
Hi all,...
I would like to thank you about all your comments, bug report and suggestions.
I realy appreciate.
There is a New release.
DiLEADER 2.2.6
Bug Fix:
- Fix for dilATTACH : Arrow End Point
- Fix for Multi-Leader : Arrow End Point
- Princ test messages removed.
What's new?:
- Configuration panel have now 2 more flags.
   1) Allow Dynamic arrow resizing:
       this allow user to use + or - key to change the arrow size in real time
   2) Auto-Convert Qleader->DiLEADER:
       this allow user to use DiLEDIT with Qleader entity.
       it detect the nearest object entity of the arrow start point.
       if there is no object, Auto-Convert do nothing.
- DiLEADER will now draw the Leader perpendicular to the object.
- Object switch !  this new feature was added on Qleader entity and allow user to
   replace object pointed by the Leader.
I think that last feature is cool, and i'll work on it to improve this tool.
Enjoy ! and have a nice weekend all !
« Last Edit: September 25, 2009, 03:18:54 PM by Andrea »
Keep smile...
kevinpo
« Reply #192 on: September 25, 2009, 03:44:34 PM »
WOW! you have outdone yourself again.
All works great.  I need to find out how you put the little arrow at the cursor on DiLedit.
Very Nice.
Kevin
Aerdvark
« Reply #193 on: September 26, 2009, 01:07:23 PM »
OMG yes the perpendicular thingy is very cool ! :lol:
Must say it gets better every time !
I have tried to give you an example "of the switch I mentioned" but I could not create a situation in wich it would be needed. I have come across a situation once where it did not do what I wanted but since I can't create such situation myself: please ignore my silly idea, it was maybe a bit too far. (Modify the code for such small thingy... :pissed:)
Great work !
I (and many others) allready await your new project whatever that me be !
rhino
« Reply #194 on: September 27, 2009, 01:02:39 PM »
simpl awesome andrea -- Thanks!!!
