How does it work with "%UserProfile%\\Application Data\\Autodesk\\MEP 2010\\enu\\Support" ?
I have workstations inadvertently unloading Express tools in 2010, still trying to figure out the why.
Regardless it leaves the workstations with an unable to load customization file command line prompt.
Makes quite a few bugs occur with publishing especially.
But when I try to make a check for it and reload it isn't working.
(if (null (menugroup "express"))
(command "menuload" "express")
Maybe null is the wrong check to use?
