Author Topic: Dynamic Intelligent Leader !  (Read 181778 times)
Andrea
Re: Dynamic Intelligent Leader !
« Reply #105 on: September 03, 2009, 02:48:23 PM »
Hi Gary.. you'r right.  sorry for that..
Please replace the DLCUSTOMARROW  function by this one..
(defun c:DLCUSTOMARROW (/ DLCA)
(if (setq DLCA (getenv "DiLEADERcustomArrow"))
  (setq DLCA (strcat DLCA "\\"))
(setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
(setq folder (vlax-invoke sh 'browseforfolder 0 (strcat "Custom Arrow Folder...\nCurrent = " DLCA) 0 ))
(vlax-release-object sh)
(if folder
    (setq Dir (vlax-get-property (vlax-get-property folder 'Self) 'Path))
    (setenv "DiLEADERcustomArrow" Dir)
This will be added on the revised code with other fixes..
thanks.
Keep smile...
GDF
« Reply #106 on: September 03, 2009, 02:50:22 PM »
Ok, I got it working. I had a broken custom dimstyle routine that needed fixen that was causing the trouble.
Works great now. And I had to modify my path:
(setenv "DiLEADERcustomArrow" "V:\\ARCH\\Custom_Architettura\\Dims\\")
Thanks Andrea for a great routine. Love it!!!
GDF
« Reply #107 on: September 03, 2009, 02:52:59 PM »
(if folder
thanks.
Much better!!! Thanks.
Andrea
« Reply #108 on: September 03, 2009, 02:58:03 PM »
i'm glad you like it !  :-)
Keep smile...
GDF
« Reply #109 on: September 03, 2009, 03:20:09 PM »
Andrea
Your routine will not accept another textstyle other than "standard". I am pretty sure it is something that I am doing wrong...
Enclosed is how I set up my dim and text styles from the "FILE" dialog box:
These are old clunky routines from version 12, that someday I will have to clean up.
Andrea
« Reply #110 on: September 03, 2009, 04:02:06 PM »
Nice Catch....I didn't test with other dimstyles.. :evil:
But it is now fixed !  thanks !
Any other bug before I post 2.2.3 ?
Keep smile...
mdbdesign
« Reply #111 on: September 03, 2009, 04:38:35 PM »
Dialog box... :angel:
Marek
Hugo
« Reply #112 on: September 04, 2009, 12:47:37 AM »
Hallo Andrea
Ich glaube die Pfeilgröße wird falsch berechnet.
zanze02
  • Mosquito
« Reply #113 on: September 04, 2009, 06:15:47 AM »
My compliments for your work Andrea!
I found a problem when I use a new UCS.
If not set as current WCS, at the prompt "Pick Text location..." text is positioned away from the cursor.
I have not found where to enter the function
(trans pt from 0 1)
« Reply #114 on: September 04, 2009, 08:42:17 AM »
Welcome to the Swamp Hugo and zanze02. 8-)
Andrea
« Reply #115 on: September 04, 2009, 10:31:54 AM »
Hi Hugo and zanze02...
First,...thank you taking time to register to theswamp and welcome.!
Second..Thank you for your bug report,...I didn't check the ucs....
...Take a look on this post i'll be back with the fix shortly.
Hugo:
Danke werde ich überprüfen und kehren mit einer neuen Version zurück
Keep smile...
Andrea
« Reply #116 on: September 04, 2009, 11:14:02 AM »
Yes,..this can be done.. thanks.   :kewl:
But,..maybe I can ask..?
Dialog DiLEADER contest ?
something like....:
« Last Edit: September 04, 2009, 11:35:32 AM by Andrea »
Keep smile...
Hugo
« Reply #117 on: September 04, 2009, 12:17:52 PM »
Hallo CAB & Andrea
Ich kann aber leider kein Englisch, und muss alles auf Deutsch schreiben, hoffe das ist ok.
Andrea
« Reply #118 on: September 04, 2009, 12:25:14 PM »
Hugo ist kein Problem, gibt es Seiten .. Online-Übersetzung mach dir keine Sorgen, dass vor allem für
 :wink:
For who want to know...
He say that he is sorry,...cause he don't know any word in english..
I have answered that it is not a problem because there is many online website traductor..
I use : http://translate.google.fr/#
« Last Edit: September 04, 2009, 12:28:42 PM by Andrea »
Keep smile...
Chris
« Reply #119 on: September 04, 2009, 12:32:00 PM »
Hallo CAB & Andrea
Diese Seite scheint gut für mich arbeiten : http://www.google.com/ig?hl=en&referrer=ign_n
This site seems to work fine for me: http://www.google.com/ig?hl=en&referrer=ign_n
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
