Author Topic: Using VB to select layers  (Read 3460 times)
systech
« on: June 17, 2009, 09:28:57 AM »
Guys,
I know that you can turn on/off layers with specific names, but is it possible to do this without knowing the layer names?
Matt__W
  • I like my water diluted.
Re: Using VB to select layers
« Reply #1 on: June 17, 2009, 10:09:04 AM »
You can use the LIKE function.
    For Each lay In lays
        Set color = New AcadAcCmColor
        With color
            .ColorMethod = acColorMethodByACI
            .ColorIndex = "2"
        End With
        [color=red]If UCase$(lay.Name)[/color] [color=blue]Like[/color] [color=red](("*") & ("ALIGN") & ("*")) Then[/color]   [color=green]'This will freeze all layers that contain the word 'align'
        'Wildcards are used before and after the word[/color]
            lay.TrueColor = color
            lay.Freeze = False
            lay.LayerOn = True
        End If
    Next
Autodesk Expert Elite
systech
« Reply #2 on: June 17, 2009, 10:15:58 AM »
That's cool, but what they're wanting is say you have 10 layers, all named different in different drawings, turn on 1 & turn off the others, then turn on 2 & all others off and so on.  As it was just explained to me after the first conversation about it. :realmad: I love ever changing specs with software development.
Matt__W
« Reply #3 on: June 17, 2009, 10:19:36 AM »
I don't quite understand why you'd want to do that.  But okie-dokie!
systech
« Reply #4 on: June 17, 2009, 10:42:14 AM »
me neither
Bobby C. Jones
« Reply #5 on: June 17, 2009, 01:11:36 PM »
sounds like the LAYWALK command
Bobby C. Jones
vegbruiser
« Reply #6 on: August 03, 2009, 09:55:31 AM »
That was my first thought on looking at this post.
He really needs to get the spec. nailed down before going any further with this.
