Author Topic: Pipe Rule Set Settings  (Read 1507 times)
bdough15
« on: June 15, 2009, 11:19:36 AM »
Has anyone ever figured out how to change your options in the pipe rule set for the "Match Location" under "Pipe to Pipe Match".  We do not use invert, Crown or centerline for our Sanitary but those are the only options that they give you, we use .8d as the method.  Is there a way to add this as an option?
Re: Pipe Rule Set Settings
« Reply #1 on: June 15, 2009, 12:24:19 PM »
What one will want to do here is a way that should resolve this without resorting to redefining the pipe(s) insertion parameters.
For each Pipe size N create a rule that equals Pipe size N minus X (entered as DROP value).
