As an example, draw a circle, then draw a 3 point arc that starts at the center of the circle (via osnap). The midpoint and other end of the of the arc should be outside the circle. I do electrical plans. For the example the circle represents a receptacle symbol and the arc would be a connection to the next receptacle.
I have a lisp that draws a new arc that uses getpoint to get the first endpoint for the arc. If I have osnap set to center and select the circle's center getpoint returns the center point of the arc, not the center of the circle. Any thoughts or suggestions on the best way to get the center of the circle, not the center of the arc? I can (and will) hack something together, but I'm thinking that someone else may already have a more elegant solution.
Thanks.
Martin
