Author Topic: Area of Mpolygon  (Read 9226 times)
V-Man
Area of Mpolygon
« on: June 12, 2009, 08:09:20 AM »
How would you get in Lisp the area of a Mpolygon?
Matt__W
  • I like my water diluted.
Re: Area of Mpolygon
« Reply #1 on: June 12, 2009, 08:11:39 AM »
Marea??
What da funk is an Mpolygon??!?
Autodesk Expert Elite
V-Man
« Reply #2 on: June 12, 2009, 08:17:51 AM »
Marea??
No such command here.
VovKa
  • Ukraine
« Reply #4 on: June 12, 2009, 10:24:20 AM »
Matt W, this is it
'((-1 . <Entity name: 7ef79028>)
  (0 . "MPOLYGON")
  (330 . <Entity name: 7ef5fcf8>)
  (5 . "D5")
  (100 . "AcDbEntity")
  (67 . 0)
  (410 . "Model")
  (8 . "0")
  (100 . "AcDbMPolygon")
  (70 . 1)
  (10 0.0 0.0 0.0)
  (210 0.0 0.0 1.0)
  (2 . "_SOLID")
  (71 . 1)
  (91 . 1)
  (92 . 2)
  (73 . 0)
  (72 . 0)
  (93 . 4)
  (10 -40.6427 -2.83449 0.0)
  (10 0.945178 -37.9821 0.0)
  (10 40.6427 0.944829 0.0)
  (10 2.45746 37.9821 0.0)
  (76 . 1)
  (63 . 256)
  (11 141.553 98.8253 0.0)
  (99 . 0)
  (450 . 0)
  (451 . 0)
  (460 . 0.0)
  (461 . 0.0)
  (452 . 0)
  (462 . 0.0)
  (453 . 0)
  (470 . "")
it's a hatched closed polyline... sort of
dvarino,
the area can be grabbed like any other area
(vla-get-Area (vlax-ename->vla-object (car (entsel))))
Matt__W
« Reply #5 on: June 12, 2009, 10:27:53 AM »
Matt W, this is it
In all my years.... never heard of that before.  Huh!
VovKa
  • Ukraine
« Reply #6 on: June 12, 2009, 10:49:40 AM »
don't worry, Matt, it's Autodesk Map custom object :)
gile
  • Marseille, France
« Reply #7 on: June 12, 2009, 10:59:54 AM »
MPolygons  can be imported in Vanilla from MAP if AcMPolygonObj17.dbx is loaded.
They can be created too in Vanilla with .NET or LISP using entmake.
MPolygon DXF data are similar to Hatchs ones.
(defun c:makeMPolygon (/ filename)
  (setq filename (strcat "acmpolygonobj" (substr (getvar "ACADVER") 1 2) ".dbx"))
  (or (member filename (arx))
      (arxload filename)
  (entmake '((0 . "MPOLYGON")
     (70 . 1)
     (10 0.0 0.0 0.0)
     (210 0.0 0.0 1.0)
     (2 . "ANSI31")
     (71 . 0)
     (91 . 2)
     (92 . 2)
     (73 . 0)
     (72 . 0)
     (93 . 5)
     (10 62.6859 18.6225 0.0)
     (10 120.0 60.2636 0.0)
     (10 177.314 18.6225 0.0)
     (10 155.422 -48.7543 0.0)
     (10 84.5779 -48.7543 0.0)
     (92 . 2)
     (73 . 0)
     (72 . 0)
     (93 . 4)
     (10 20.0 100.0 0.0)
     (10 20.0 -100.0 0.0)
     (10 220.0 -100.0 0.0)
     (10 220.0 100.0 0.0)
     (76 . 1)
     (52 . 0.0)
     (41 . 2.0)
     (77 . 0)
     (78 . 1)
     (53 . 0.785398)
     (43 . 0.0)
     (44 . 0.0)
     (45 . -4.49013)
     (46 . 4.49013)
     (79 . 0)
     (11 0.0 0.0 0.0)
     (99 . 0)
     (450 . 0)
     (451 . 0)
     (460 . 0.0)
     (461 . 0.0)
     (452 . 0)
     (462 . 0.0)
     (453 . 0)
     (470 . "")
« Last Edit: June 12, 2009, 03:03:21 PM by gile »
V-Man
« Reply #8 on: June 12, 2009, 11:40:20 AM »
dvarino,
Thanks for the information.
Yea , me too. Very strange indeed.
gile
  • Marseille, France
« Reply #9 on: June 13, 2009, 10:14:28 AM »
Here's a .NET command which allows to create a MPOLYGON in Vanilla from a selection set .
NETLOAD AcadMoplygon.dll, type PL2MPG, select entities (closed lwpolylines or 2d polylines and circles), enter the hatch pattern name (or a dot for none).
namespace AcadMPolygon
    public class MpgClass : IExtensionApplication
        public void Initialize()
            Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule("AcMPolygonObj17.dbx", false, false);
        public void Terminate()
        [CommandMethod("PL2MPG")]
        public void PL2MPG()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            try
                Database db = HostApplicationServices.WorkingDatabase;
                TypedValue[] filter = { new TypedValue(-4, "<or"),
                                           new TypedValue(0, "CIRCLE"),
                                           new TypedValue(-4, "<and"),
                                           new TypedValue(0, "LWPOLYLINE"),
                                           new TypedValue(-4, "&"),
                                           new TypedValue(70, 1),
                                           new TypedValue(-4, "and>"),
                                           new TypedValue(0, "POLYLINE"),
                                           new TypedValue(-4, "<not"),
                                           new TypedValue(70, 120),
                                           new TypedValue(-4, "not>"),
                                           new TypedValue(-4, "or>"),
                SelectionFilter selFilter = new SelectionFilter(filter);
                PromptSelectionResult result = ed.GetSelection(selFilter);
                if (result.Status == PromptStatus.OK)
                    ObjectId[] selSet = result.Value.GetObjectIds();
                        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                        MPolygon mPolygon = new MPolygon();
                        foreach (ObjectId objId in selSet)
                            Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForWrite);
                            if (ent is Polyline)
                                mPolygon.AppendLoopFromBoundary((Polyline)ent, true, 1E-9);
                            else if (ent is Circle)
                                mPolygon.AppendLoopFromBoundary((Circle)ent, true, 1E-9);
                            else
                                mPolygon.AppendLoopFromBoundary((Polyline2d)ent, true, 1E-9);
                            ent.Erase();
                        PromptStringOptions pso = new PromptStringOptions("\nEnter the hatch pattern name or a dot (.) for none: ");
                        pso.AllowSpaces = false;
                        pso.DefaultValue = (string)Application.GetSystemVariable("HPNAME");
                        PromptResult pr = ed.GetString(pso);
                        if (pr.Status == PromptStatus.OK)
                            string pat = pr.StringResult;
                            if (pat != ".")
                                try
                                    Application.SetSystemVariable("HPNAME", pat);
                                    mPolygon.SetPattern(HatchPatternType.PreDefined, pat);
                                    mPolygon.PatternScale = (double)Application.GetSystemVariable("HPSCALE");
                                catch { }
                        mPolygon.BalanceTree();
                        mPolygon.BalanceDisplay();
                        btr.AppendEntity(mPolygon);
                        tr.AddNewlyCreatedDBObject(mPolygon, true);
                        tr.Commit();
            catch(Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("Error: " + ex.Message);
            catch (System.Exception ex)
« Last Edit: June 13, 2009, 10:26:39 AM by gile »
gile
  • Marseille, France
« Reply #10 on: June 17, 2009, 11:43:33 AM »
A new release of PL2MPG, source code here.
EDIT: Updated attached file. Now contains VanillaMPolygon_17.dll for AutoCAD 2007 to 2012 and VanillaMPolygon_19.dll for AutoCAD 2013 and later.
« Last Edit: January 27, 2015, 03:14:23 PM by gile »
vertamboz
« Reply #11 on: January 27, 2015, 05:59:47 AM »
It is possible to use this in autocad 2013 vanilla? I tried it, but it did't work. (My skills in .net are 0)
gile
  • Marseille, France
« Reply #12 on: January 27, 2015, 03:13:54 PM »
I updated the upper dowload: netload VanillaMPolygon_19.dll for AutoCAD 2013 or later.
vertamboz
« Reply #13 on: January 27, 2015, 04:06:48 PM »
Thank you very much, you've been really helpful to me! And sorry for my bad english. :)
xdcad
« Reply #14 on: November 22, 2023, 01:02:52 PM »
(xdrx-getpropertyvalue mp "area" "length")
查面积,长度
https://github.com/xdcad
http://bbs.xdcad.net
