Author Topic: searching a list  (Read 2325 times)
andrew_nao
searching a list
« on: June 11, 2009, 11:35:35 AM »
i have the following code to search a text file for a keyword
and makes a list of those keywords, it works but im looking to modify it to search a list for keywords and then make a new list of the keywords
can anyone help?
i appreciate any help and guidance
(setq TextFile "test.txt"))
   (setq SearchStr "revision")
   (setq Opened (open Textfile "r"))
  (while (setq tmpLine (read-line Opened))
   (if (vl-string-search (strcase SearchStr) (strcase tmpLine))
    (setq EndList (cons tmpLine EndList))
Re: searching a list
« Reply #1 on: June 11, 2009, 11:45:12 AM »
Not sure if maybe this would work:
(setq kLst  (mapcar 'strcase '("revision" "key2" "key3"))
      ofile (open "test.txt" "r"))
(while (setq nl (read-line ofile))
  (if (vl-some
        (function
          (lambda (x)
            (vl-string-search x (strcase nl)))) kLst)
    (setq EndList (cons nl EndList))))
(close ofile)
andrew_nao
« Reply #2 on: June 11, 2009, 11:59:29 AM »
thanks for your reply
i guess i wasnt detailed enough
what im looking for is to search and existing list,
not open a text file and search it.
« Reply #3 on: June 11, 2009, 12:04:37 PM »
Use ' vl-remove-if-not ' and test each item for what you want.  If it doesn't match, then it will be removed from the list.
Example
(vl-remove-if-not '(lambda ( x ) (equal x 1)) '(1 2 3 5 1 2 4 5 9 12))
return = (1 1)
« Reply #4 on: June 11, 2009, 12:13:50 PM »
Andrew, You're request is not clear to me.
Would you post a before list & an after list so we can see what you want?
« Reply #5 on: June 11, 2009, 12:20:27 PM »
<ding> <ding>
andrew_nao
« Reply #6 on: June 11, 2009, 01:17:00 PM »
example would be
the text file would contain:
something     something    revision1
something     something    revision2
something     something    revision3
something     something
something     something
if the code i posted is loaded it would return
i would like to to do the same thing but search a list not a text file and make a new list with the keyword
andrew_nao
« Reply #7 on: June 11, 2009, 01:21:26 PM »
Example
return = (1 1)
thanks Tim,
if my list is in a variable
how would i put my list in this formula?
« Reply #8 on: June 11, 2009, 01:38:30 PM »
As Tim said:
(setq lst '("something     something    revision1"
            "something     something    revision2"
            "something     something    revision3"
            "something     something             "
(vl-remove-if-not '(lambda (x) (wcmatch (strcase x) "*REVISION*")) lst)
Returns this
andrew_nao
« Reply #9 on: June 11, 2009, 01:56:50 PM »
never mind, i see what i did wrong
thanks for everyones help
1 more small questioncan someone explain what lambda means?
« Last Edit: June 11, 2009, 02:08:51 PM by andrew_nao »
« Reply #10 on: June 11, 2009, 07:40:28 PM »
Lambda is just an anonymous function defined to perform an operation.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #11 on: June 11, 2009, 07:51:29 PM »
hehe .. easy to say :)
.. but like juggling with knives in the dark, sometimes not so easy ..  without lots of practice ..  :|
Called Kerry in my other life
I live at UTC + 13.00
ziko30
« Reply #12 on: June 11, 2009, 07:57:02 PM »
============== Acad Map 3D 2009================
