Author Topic: Exploding MText entities through VBA  (Read 4207 times)
msasu
  • Mosquito
« on: June 11, 2009, 01:02:06 AM »
Hello,
Since the MText entities in AutoCAD’s VBA doesn’t support the .Explode method I’m trying to get them converted to Text type by using SendCommand – something that avoided at all in the past, so lack of clues.
Can someone tell me how to pass the current entity from a selection set to SendCommand statement?
Dim ItemsSSet As AcadSelectionSet
Dim FType(0) As Integer
Dim FData(0) As Variant
Dim theItem As Variant
FType(0) = 0
FData(0) = "MTEXT"
Set ItemsSSet = CrDrawing.SelectionSets.Add("SS1")
ItemsSSet.Select Mode:=5, FilterType:=FType, FilterData:=FData
For Each theItem In ItemsSSet
    CrDrawing.SendCommand "EXPLODE" & vbCr & ????? & vbCr
Next theItem
Thank you!
Bryco
Re: Exploding MText entities through VBA
« Reply #1 on: June 15, 2009, 08:38:55 PM »
ThisDrawing.SendCommand "EXPLODE" & vbCr & SendCommandSelection(t) & vbCr & vbCr
where t is the mtext
Function SendCommandSelection(ent As AcadEntity) As String
    SendCommandSelection = "(handent " & Chr(34) & ent.Handle & Chr(34) & ")"
End Function
(Function stolen from the swamp probably Jeff?? )
