Please send me a copy of your template to investigate...
It might be a saved (internal) query that is looking for a Source file, and as you have no drawings attached the error pops up.
Check your Map task pane carefully. As such the error might not show up on my system.
Set the path for the Default Query File Directory to a valid path (valid path is the path where the acadmap.ini is located).
Open the acadmap.ini file with a text editor, such as Notepad, and make sure the line "QueryFileDirectory" contains a valid path (should be the path where the acadmap.ini file resides and specified in Autodesk Map).
To resolve this problem in older versions of AutoCAD Map and AutoCAD Land Development Desktop:
From the Map menu, choose Utilities.
In the Source File dialog box, select the Query tab.
Set the path for the Query File Directory to a valid path (Open the acadmap.ini file with a text editor, such as Notepad, and make sure the line "QueryFileDirectory" contains a valid path (should be the path where the acadmap.ini file resides and specified in Autodesk Map).
