Author Topic: Bricscad && .NET  (Read 91360 times)
Re: Bricscad && .NET
« Reply #180 on: November 09, 2010, 08:15:24 AM »
Try this one, note the paths at the command line  :-)
« Last Edit: November 09, 2010, 10:11:08 AM by __declspec »
Helios
« Reply #181 on: November 09, 2010, 08:37:51 AM »
Ok Daniel,
I replaced RxNet 1.0.1.4 with your debug one.
When starting Bricscad I see in the command prompt:
Loading .NET runtime v2.0.50727
RxLoader.txt = C:\Program Files\RxNet\V9\RxLoader.txt
  :? Shouldn't that be the path of the DLL I'm trying to load??
(D:\VOSS.NET\VOSS\VOSS.CAD.Bricscad.RxNet\bin\Debug\VOSS.CAD.Bricscad.RxNet.dll)??
Arno
« Reply #182 on: November 09, 2010, 09:38:56 AM »
what is the contents of RxLoader.txt?
D:\VOSS.NET\VOSS\VOSS.CAD.Bricscad.RxNet\bin\Debug\VOSS.CAD.Bricscad.RxNet.dll ?
« Reply #183 on: November 09, 2010, 09:39:42 AM »
Here is what I get when I run a sample
RxLoader.txt = C:\Program Files (x86)\RxNet\V11\RxLoader.txt
file = C:\Users\Daniel\Documents\Visual Studio 2010\Projects\RxNetTest\RxNetTest\bin\Debug\RxNetTest.dll
the file RxLoader.txt should reside in the same folder as RxNet.dll
the file RxLoader.txt should contain the paths to the DLLs you would like to load at startup.
Is this what you have?
« Last Edit: November 09, 2010, 09:45:35 AM by __declspec »
Helios
« Reply #184 on: November 09, 2010, 09:53:37 AM »
Yep,
RxLoader.txt is in the same folder as RxNet.dll.
RxLoader.txt contains the full name of my DLL
Nope, I get no
file = D:\VOSS.NET\VOSS\VOSS.CAD.Bricscad.RxNet\bin\Debug\VOSS.CAD.Bricscad.RxNet.DLL
at the command prompt.
 :-o
« Reply #185 on: November 09, 2010, 10:10:48 AM »
try this one
« Last Edit: November 09, 2010, 10:20:29 AM by __declspec »
Helios
« Reply #186 on: November 09, 2010, 10:31:02 AM »
Starting Bricscad now reports:
Failed to find RxLoader.txt at c:\Program Files\RxNet\V9\RxLoader.txt
while it actually is there....
file is attached.....
« Reply #187 on: November 09, 2010, 10:34:21 AM »
Does the file you have, have double extensions like the one you posted?
RxLoader.txt.txt
Helios
« Reply #188 on: November 09, 2010, 10:47:20 AM »
 :ugly:
How to keep each other occupied.....
Double extensions.... :realmad: what a waste of time.
Now it's working.  :-)
Thanks a lot for your patience.
Hope this hasn't screwed up your S'hai night too much!
TTYL
« Reply #189 on: November 09, 2010, 10:48:51 AM »
No worries, glad it's working for you  8-)
iraklis
Bricscad V11.1.14 build 20538 RxNet problem
« Reply #190 on: November 18, 2010, 04:04:56 AM »
Hallo,
I have recently upgrade to the Bricscad V11.1.14 build 20538 version and my RxNet commands do not work anymore.
the line:
 Dim acad As AcadApplication = RxNet.ApplicationServices.Application.AcadApplication
seems to create problems because the next code works:
 Public Shared Sub Test()
        MsgBox("1111")
        'Dim acad As AcadApplication = RxNet.ApplicationServices.Application.AcadApplication
        MsgBox("1111")
but when I uncomment the Dim line I get an error message (attached)
<CommandMethod("test")> _
        MsgBox("1111")
        MsgBox("1111")
Best regards,
Iraklis
iraklis
« Reply #191 on: November 18, 2010, 05:00:57 AM »
Hi again,
The problem seems to be caused because I have changed the Copy Local property of the RxNet dlls to be false. When I change this to true everything works OK.
« Reply #192 on: November 18, 2010, 06:58:41 AM »
I think there was a change in V11.1.14's COM settings. I will make a new build to fix this....
iraklis
« Reply #193 on: November 24, 2010, 06:09:23 AM »
Hi, sorry to bother I would like to ask if the new build you said is ready.
Best regards.
« Reply #194 on: November 24, 2010, 06:24:46 AM »
just curious, what version are you using now?  because I had removed the COM references in this latest version 1.0.1.4.  If you're using 1.0.1.3, you can just replace the COM DLLs in the RxNet/V11 folder  with the  yours (the ones from copy local).. if that make sense
