Author Topic: Bricscad && .NET  (Read 91266 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Bricscad && .NET
« Reply #45 on: January 22, 2010, 07:39:29 AM »
netburst
using System;
using System.Threading;
using BricscadApp;
using BricscadDb;
using RxNet.Geometry;
using RxNet.ApplicationServices;
using RxNet.Runtime;
namespace RxNetTest
  public static class Commands
    [CommandMethod("netburst")]
    public static void netburst()
      AcadApplication app = Application.AcadApplication as AcadApplication;
      AcadDocument document = app.ActiveDocument;
      AcadDatabase database = document.database;
      AcadSelectionSet selection = document.SelectionSets.Add("sset");
      int[] var = new int[] { 0 ,66};
      object[] val = new object[] { "INSERT" ,1 };
      selection.SelectOnScreen(var, val);
      foreach (IAcadBlockReference blk in selection)
        if (blk.HasAttributes)
          IAcadBlock space = database.ObjectIdToObject(blk.OwnerID) as IAcadBlock;
          foreach (AcadEntity ent in (object[])blk.Explode())
            AcadAttribute attribute = ent as AcadAttribute;
            if (attribute != null)
              AcadText txt = space.AddText(attribute.TextString,
                                           attribute.InsertionPoint,
                                           attribute.Height);
              txt.Alignment = attribute.Alignment;
              txt.Backward = attribute.Backward;
              txt.color = attribute.color;
              txt.HorizontalAlignment = attribute.HorizontalAlignment;
              txt.Normal = attribute.Normal;
              txt.ObliqueAngle = attribute.ObliqueAngle;
              txt.Rotation = attribute.Rotation;
              txt.ScaleFactor = attribute.ScaleFactor;
              txt.StyleName = attribute.StyleName;
              txt.TextAlignmentPoint = attribute.TextAlignmentPoint;
              txt.VerticalAlignment = attribute.VerticalAlignment;
              txt.UpsideDown = attribute.UpsideDown;
              //add what you need
              attribute.Erase();
          blk.Erase();
      selection.Delete();
« Last Edit: January 25, 2010, 08:35:20 PM by Daniel »
« Reply #46 on: January 22, 2010, 07:50:08 AM »
Looks like it's coming along for you Dan.
Pity that it needs to be COM (untill they get the BRX stuff wrapped.)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #47 on: January 25, 2010, 09:39:55 PM »
Thanks!
COM isn't so bad when you can use C#, you don't have to deal with variants and all that carp...
I would rather write my own API then use VBA  :laugh:
FYI, I'm in the source fixing a couple of bugs I found, lf anyone needs something fixed or added, let me know
« Reply #48 on: January 25, 2010, 09:48:45 PM »
Thanks!
I'd rather YOU write the API  than me use VBA also.  :)
« Last Edit: January 26, 2010, 02:51:30 AM by Kerry Brown »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #49 on: January 26, 2010, 01:54:23 AM »
Talking with lisp  :kewl:
(defun thisisatest (a)
 (reverse a)
(vl-acad-defun 'thisisatest)
[CommandMethod("doit2")]
    static public void doit2()
      ResultBuffer rbOut = new ResultBuffer();
      rbOut.Add(new TypedValue((int)LispDataType.Text, "thisisatest"));
      rbOut.Add(new TypedValue((int)LispDataType.ListBegin));//list
      rbOut.Add(new TypedValue((int)LispDataType.Int32, 1));
      rbOut.Add(new TypedValue((int)LispDataType.Int32, 2));
      rbOut.Add(new TypedValue((int)LispDataType.Int32, 3));
      rbOut.Add(new TypedValue((int)LispDataType.Int32, 4));
      rbOut.Add(new TypedValue((int)LispDataType.ListEnd)); //endlist
      GlobalFunctions.Printf(string.Format("\n{0}",rbOut));
      ResultBuffer rbIn = GlobalFunctions.Invoke(rbOut); // acedinvoke
      GlobalFunctions.Printf(string.Format("\n{0}",rbIn));
« Reply #50 on: January 26, 2010, 03:00:27 AM »
Dan,
so you're calling a Lisp Command from C# .... that has some potential !!
Where is the  GlobalFunctions definition ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #51 on: January 26, 2010, 05:26:24 AM »
I thought you might like that.  ^-^
the namespace is RxNet.RxGlobal. GlobalFunctions.Invoke
but don't try it yet because I have not uploaded the latest version yet
It's Alive!
  • Retired
  • AKA Daniel
« Reply #52 on: January 26, 2010, 05:36:15 AM »
here is how you would do it in acad
using System;
using System.Runtime.InteropServices;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
[assembly: CommandClass(typeof(ExecMethod.Commands))]
namespace ExecMethod
   [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
   extern static int acedInvoke(IntPtr rbIn, out IntPtr rbOut);
   public static ResultBuffer Invoke(ResultBuffer rbIn)
     IntPtr pRb = IntPtr.Zero;
     acedInvoke(rbIn.UnmanagedObject, out pRb);
     return DisposableWrapper.Create(typeof(ResultBuffer), pRb, true) as ResultBuffer;
   [CommandMethod("doit")]
   public static void MyCommand()
     ResultBuffer rbIn = Invoke(rbOut);
     List<TypedValue> list = new List<TypedValue>(rbIn.AsArray());
     list.ForEach(X =>
      AcAp.Application.DocumentManager.
      MdiActiveDocument.Editor.WriteMessage(X.Value.ToString()));
It's Alive!
  • Retired
  • AKA Daniel
« Reply #53 on: January 26, 2010, 05:42:01 AM »
A warning though, some arguments may be interpreted by lisp I.e. lisp might see a list of three doubles as a RT3DPOINT, so be careful  :police:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #54 on: January 26, 2010, 05:52:52 AM »
arx version  :lol:
  static void arx_doit(void)
    resbuf *pRbOut = acutBuildList(RTSTR,_T("thisisatest"),
                                   RTLB,
                                   RTSHORT, 1,
                                   RTSHORT, 2,
                                   RTSHORT, 3,
                                   RTSHORT, 4,
                                   RTLE,
                                   NULL);
    resbuf *pRbIn = NULL;
    acedInvoke(pRbOut,&pRbIn);
    for(resbuf*pTmp = pRbIn;pTmp!=NULL;pTmp = pTmp->rbnext)
      acutPrintf(_T("%ld"),pTmp->resval.rint);
    acutRelRb(pRbIn);
    acutRelRb(pRbOut);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #55 on: February 01, 2010, 02:07:09 AM »
Updated,
removed some of the hacks and workarounds for items that were not implemented in BRX and now are. Fixed a few bugs, wrapped a few more items.  :-)
I Also modified the installer to install for all users.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #56 on: February 04, 2010, 01:33:52 AM »
A really quick sample of how to make a table and how to edit a cell  :laugh:
« Reply #57 on: February 04, 2010, 01:36:41 AM »
You've been reading my mail ??
I had planned on investigating that tonight   ... you just keep on doing my homework  !!  :wink:
MickD
« Reply #58 on: February 04, 2010, 01:54:15 AM »
Maybe you won't have to write anything - http://www.opendwg.org/the_oda_platform/dwgdirect.net
I'm not sure if you can just mix the assemblies in with Bricscad or not but if you could  that would save a fair chunk of the work :)
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
« Reply #59 on: February 04, 2010, 02:01:02 AM »
I've wondered what would happen if I netloaded those. I'm not an ODA member though  :|
I'm sure Bricsys will be adding em at some point though
« Last Edit: February 04, 2010, 02:09:53 AM by Daniel »
