Author Topic: Bricscad && .NET  (Read 91835 times)
0 Members and 3 Guests are viewing this topic.
It's Alive!
  • Retired
  • AKA Daniel
Re: Bricscad && .NET
« Reply #135 on: October 04, 2010, 08:46:54 AM »
Anyone still using .NET 2.0.. can I drop it?
jgr
« Reply #136 on: October 04, 2010, 09:20:09 AM »
how about I add a global function getWorkingDatabase() as an IntPtr   :-o
sounds dangerous  :laugh:
That's what I need. It is possible or not?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #137 on: October 04, 2010, 10:14:38 AM »
Its untested but here is the sig
GlobalFunctions::GetWorkingDatabasePtr();
jgr
« Reply #138 on: October 04, 2010, 12:02:40 PM »
Thank you very much.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #139 on: October 04, 2010, 12:07:04 PM »
You're welcome, its attached to the first post in this thread : )
jgr
« Reply #140 on: October 07, 2010, 01:06:31 PM »
I tested GetWorkingDatabasePtr with acdbSaveAs2000, acdbDxfOutAs2004 and acdbGetCurVportId :
- acdbSaveAs2000, acdbDxfOutAs2004 retun eFileAccessErr
-adjustAlignment retun eNotHandled
- acdbGetCurVportId seems to work
And... acdbTextFind does not exist. I was wrong :oops:
And a question:
Is it possible to execute code when loading an assembly?, As in autocad with IExtensionApplication.Initialize (or delphi dll's with DLL_PROCESS_ATTACH), but without using IExtensionApplication.
If it is possible: how?
Thanks.
SimonPapadopoulos
« Reply #141 on: October 18, 2010, 06:18:30 AM »
Hi !
Are there any equivalent events in BricsCAD to the following AutoCAD events?
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentBecameCurrent
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentDestroyed
Thanks,
Simon
It's Alive!
  • Retired
  • AKA Daniel
« Reply #142 on: October 18, 2010, 07:54:38 AM »
And a question:
Thanks.
No, IExtensionApplication.Initialize is not coded. I had planned to add something similar, but at this point I suspect a more official version is around the corner. There is probably an event you can capture from the framework, maybe AssemblyLoadEventHandler?
FYI acdbGetCurVportId is already wrapped @ RxNet.RxGlobal.GlobalFunctions.GetCurViewportObjectId()
If you need a simple static function wrapped. let me know, as some of these will be usable in the future
It's Alive!
  • Retired
  • AKA Daniel
« Reply #143 on: October 18, 2010, 08:10:34 AM »
Hi !
Thanks,
Simon
Huh! I don't see those  :-o  hmmm let me think abou this.
SimonPapadopoulos
« Reply #144 on: October 19, 2010, 03:18:42 AM »
Hi Daniel,
I use these events (DocumentBecameCurrent,DocumentDestroyed) in AutoCAD to update a Palette
when I select an other document or close the current document in the MDI interface.
In BricsCAD .NET are there any palette/paletteset classes? Ι think not.
So I want these events to update a modeless form with the current document's data when a user clicks another document or closes the
current doument in the MDI interface.
I hope that this info helps,
Simon
jgr
« Reply #145 on: October 19, 2010, 03:57:30 AM »
You can subclass the MDIClient. (WM_MDIDESTROY, WM_MDICREATE ... messages).
It's Alive!
  • Retired
  • AKA Daniel
« Reply #146 on: October 19, 2010, 09:42:12 AM »
you might be able to poll one of these
document.BeginClose;
document.BeginDocClose;
application.SysVarChanged;
application.SysVarChanged might be useful as I think there is a system var for the current document.
sorry, no wrappers for palettes
jgr
« Reply #147 on: October 19, 2010, 10:23:55 AM »
I still use it, but I can use 4.0.
Sorry.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #148 on: October 20, 2010, 08:25:12 PM »
Sorry.
No problem, I will keep it updated as long as people are using it  :-)
FYI, I have updated the modules to support Bricscad V11
Helios
« Reply #149 on: October 21, 2010, 03:31:33 AM »
Daniel,
I was just about to drop you line regarding V11, but it seems I was already way to late... :lmao:
Thanks,
Arno
(Leaves me more time to check out TST, LKF... greez from HKG)
