Author Topic: Bricscad && .NET  (Read 91922 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Bricscad && .NET
« Reply #120 on: September 23, 2010, 10:50:48 AM »
Excellent  8-)
Kind of a kludge, but I might setup a couple of XRecords or Dictionaries (in/out) to pass data.
octavio
« Reply #121 on: September 28, 2010, 02:22:27 PM »
Hi ppl, I just did a application with .NET and it seams to work ok, now I have been wondering how can I tell briscad to load the .net assembly at the startup.
I am new to briscad and lisp but I saw in a lisp example the way they do it is they put the files "on_start.lsp" and "on_doc_load.lsp" at the root of Bricscad. Now I tried to modify those files and I added (load "bsx_netload.lsp"). And that file just has the code (command "netload [assembly-path]"). I tried with the full path and with just the name copying the assembly to the root Bricscad folder but it did not work.
Does any one know how can I load an assembly at the startup?
Thanks in advance.
SimonPapadopoulos
« Reply #122 on: September 29, 2010, 05:23:32 AM »
Hi! I am new to BricsCAD. I am trying to write into the DWG database some XRecords. I want to write an integer and a string.
I wrote the following code. Is it correct?
<CommandMethod("chaos")> _
    Public Shared Sub foit()
        Dim acadapp As AcadApplication = RxNet.ApplicationServices.Application.AcadApplication
        Dim doc As AcadDocument = acadapp.ActiveDocument
        Dim db As AcadDatabase = doc.database
        'get the dictionary collection
        Dim dictCollection As AcadDictionaries = db.Dictionaries
        'create a new dictionary for my data
        Dim dicto As AcadDictionary = dictCollection.Add("myfirstdictionary")
        'create an integer XRecord
        Dim rec1 As AcadXRecord = dicto.AddXRecord("myinteger")
        rec1.SetXRecordData(VariantType.Integer, 16)
        'create a string XRecord
        Dim rec2 As AcadXRecord = dicto.AddXRecord("mystring")
        rec2.SetXRecordData(VariantType.String, "this is a very small string")
        MsgBox("it worked re!! " & dictCollection.Count & " : " & dicto.Count)
        'save the changes to the document
        doc.Save()
    End Sub
I wrote another command to read those XRecords but I cannot understand how to use GetXRecordData sub...
Could someone help me? The following code is the command that tries to read the integer and raises many exceptions when GetXRecordData is called..
<CommandMethod("maos")> _
    Public Shared Sub doit()
        'open the database
        'select my custom dictionary
        Dim dicto As AcadDictionary = dictCollection.Item("myfirstdictionary")
        'get my integer record
        Dim rec As AcadXRecord = dicto.Item("myinteger")
        Dim komos As Integer
        rec.GetXRecordData(VariantType.Integer, komos)
        MsgBox(komos)
    End Sub
Thank you for your time,
Simon
« Last Edit: September 29, 2010, 05:51:14 AM by SimonPapadopoulos »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #123 on: September 29, 2010, 06:27:29 AM »
Thanks in advance.
try putting a file called RxLoader.Txt in C:\Program Files\RxNet\V10, inside RxLoader.Txt, put the path to your module
It's Alive!
  • Retired
  • AKA Daniel
« Reply #124 on: September 29, 2010, 06:48:55 AM »
Hi Simon,
I'll take a look after dinner. At first glance, I see you need to may replace VariantType.XXX with the DXF type
octavio
« Reply #125 on: September 29, 2010, 12:05:01 PM »
Thanks in advance.
Hi, that worked just right thank you very much. I had been looking for that 2 days and now it working thanks.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #126 on: September 29, 2010, 07:11:55 PM »
FYI, There should be an anemic help file in there  :-)
SimonPapadopoulos
« Reply #127 on: September 30, 2010, 01:48:17 AM »
Hi Daniel,
There no DXF types in your libraries. AutoCAD has its DXF types in enumerators like DXFType.Text = 1.
I put the value 1 (dxftype text) in the SetXRecordData and GetXRecordData subs and it does not work..
It's Alive!
  • Retired
  • AKA Daniel
« Reply #128 on: September 30, 2010, 03:58:45 AM »
see if this helps you
[CommandMethod("execa")]
    public static void execa()
      AcadApplication application = Application.AcadApplication as AcadApplication;
      AcadDocument document = application.ActiveDocument;
      AcadDatabase database = document.database;
      try
        AcadDictionaries dictionaries = database.Dictionaries;
        AcadDictionary dictionary = dictionaries.Add("SWAMP");
        AcadXRecord xRecord = dictionary.AddXRecord("SWAMPEXR");
        List<Int16> types = new List<Int16>();
        List<object> values = new List<object>();
        types.Add(1);
        values.Add("Hola");
        types.Add(1);
        values.Add("Swampers");
        xRecord.SetXRecordData(types.ToArray(), values.ToArray());
      catch (System.Exception ex)
        document.Utility.Prompt(String.Format("\n{0}", ex.Message));
    [CommandMethod("execb")]
    public static void execb()
      try
        AcadDictionary dictionary = dictionaries.Item("SWAMP") as AcadDictionary;
        AcadXRecord xRecord = dictionary.Item("SWAMPEXR") as AcadXRecord;
        object otypes;
        object ovalues;
        xRecord.GetXRecordData(out otypes, out ovalues);
        Int16[] types = (Int16[])otypes;
        object[] values = (object[])ovalues;
        for (int i = 0; i < types.Length; i++)
          document.Utility.Prompt(String.Format("({0} . {1})", types[i], values[i]));
jgr
« Reply #129 on: September 30, 2010, 07:59:05 PM »
There any way to get a pointer to the database of the active document?
(database.UnmanagedObject of the AcadApplication.Activedocument? for PInvoke)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #130 on: September 30, 2010, 08:03:59 PM »
Possibly,  but .NET would only see a IntPtr type.  What are you needing to do?
jgr
« Reply #131 on: September 30, 2010, 08:20:51 PM »
Thanks for replying.
I would like to use acdbTextFind.
Thanks.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #132 on: October 01, 2010, 12:35:09 AM »
how about I add a global function getWorkingDatabase() as an IntPtr   :-o
sounds dangerous  :laugh:
SimonPapadopoulos
« Reply #133 on: October 01, 2010, 03:49:59 AM »
Daniel thank you !
The code with the XRecords worked!
Is there a way set Visual Studio to debug with BricsCAD?
This is possible with AutoCAD and speeds up development process..
Simon
Helios
« Reply #134 on: October 01, 2010, 09:22:05 AM »
Simon,
I netload my RxNet.DLL in Bricscad..
Set the break point(s) in the code and use Tools/Attach to proces in VS to select Bricscad from the list.
Then fire up the command....
Hope this helps,
Arno
